Hi, I am new in Garuda and Linux in general
I wondered if there was any way to use the footprint reader to unlock the PC?
Garuda-inxi:
Kernel: 5.19.13-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=b9e145a5-d04a-43c1-9ee6-48d663bc4857 rw rootflags=subvol=@
Type: Laptop System: LENOVO product: 82KT v: IdeaPad 3 14ALC6
serial: Chassis: type: 10 v: IdeaPad 3 14ALC6
serial:
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial:
UEFI: LENOVO v: GLCN46WW date: 04/29/2022
ID-1: BAT0 charge: 23.2 Wh (68.4%) condition: 33.9/38.0 Wh (89.2%)
volts: 7.9 min: 7.7 model: SMP L20M2PF0 type: Li-poly serial:
status: discharging cycles: 253
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x68 (104) stepping: 1 microcode: 0x8608103
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1399 high: 1400 min/max: 1400/4056 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1400
3: 1400 4: 1400 5: 1397 6: 1400 7: 1397 8: 1397 9: 1400 10: 1400 11: 1400
12: 1400 bogomips: 50307
protection
Device-1: AMD Lucienne vendor: Lenovo driver: amdgpu v: kernel
arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie:
active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 04f2:b725 class-ID: fe01 serial:
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x09ae built: 2020
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
diag: 355mm (14") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.47 5.19.13-zen1-1-zen)
v: 4.6 Mesa 22.1.7 direct render: Yes
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
snd_pci_acp6x, snd_acp_pci, snd_sof_amd_renoir pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.19.13-zen1-1-zen running: yes
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 01:00.0 chip-ID: 168c:003e class-ID: 0280
IF: wlp1s0 state: up mac:
Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
v: 0.8 bus-ID: 3-4:3 chip-ID: 0cf3:e300 class-ID: e001
address:
Local Storage: total: 1.36 TiB used: 23.97 GiB (1.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNVS500G
speed: 31.6 Gb/s lanes: 4 type: SSD serial: rev: S8I40100
temp: 26.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: rev: 2E scheme: GPT
ID-1: / raw-size: 78.13 GiB size: 78.13 GiB (100.00%) used: 23.93 GiB
(30.6%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 46.4 MiB
(48.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 78.13 GiB size: 78.13 GiB (100.00%) used: 23.93 GiB
ID-4: /var/log raw-size: 78.13 GiB size: 78.13 GiB (100.00%) used: 23.93
GiB (30.6%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-5: /var/tmp raw-size: 78.13 GiB size: 78.13 GiB (100.00%) used: 23.93
ID-1: swap-1 type: zram size: 17.43 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 46.9 C mobo: N/A gpu: amdgpu temp: 41.0 C
Processes: 299 Uptime: 46m wakeups: 1 Memory: 17.43 GiB used: 3.46 GiB
(19.9%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1487 libs: 483
tools: octopi,paru,trizen Shell: fish v: 3.5.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.21
Garuda (2.6.8-1):
System install date: 2022-10-05
Last full system update: 2022-10-07
I found a way to install it in arch and I thought it would also work for garuda but it didn’t
Use the following commands:
sudo pacman -S git base-devel.
git clone https://aur.archlinux.org/trizen.git.
cd trizen
makepkg -sri
trizen -S fingerprint-gui
Sorry if there is an error in the texts, I am using translator
