Kernel: 5.17.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=d84d1289-1918-4cb8-b260-dc86d66875da rw [email protected]
Type: Desktop System: Micro-Star product: MS-7A38 v: 2.0
Mobo: Micro-Star model: B350M PRO-VDH (MS-7A38) v: 2.0
serial: <superuser required> UEFI: American Megatrends v: A.E0
date: 09/21/2018
Info: model: AMD Ryzen 5 1400 bits: 64 type: MT MCP arch: Zen
family: 0x17 (23) model-id: 1 stepping: 1 microcode: 0x8001137
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 3324 high: 3400 min/max: N/A cores: 1: 3400 2: 3400
3: 2795 4: 3400 5: 3400 6: 3400 7: 3400 8: 3400 bogomips: 54398
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: eVga.com.
driver: nvidia v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 1f:00.0 chip-ID: 10de:1c02 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia
s-diag: 610mm (24")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 92
OpenGL: renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
v: 4.6.0 NVIDIA 510.60.02 direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: eVga.com.
bus-ID: 1f:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 21:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Razer USA Kraken Kitty Edition type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-3.2.3:16
chip-ID: 1532:0521 class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.17.3-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.50 running: yes
lanes: 1 port: f000 bus-ID: 1b:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp27s0 state: down mac: <filter>
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 1d:00.0 chip-ID: 8086:24f3 class-ID: 0280
IF: wlp29s0 state: up mac: <filter>
Local Storage: total: 1.02 TiB used: 161.09 GiB (15.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Silicon Power
model: SPCC Solid State Disk size: 111.79 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 21.1
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-1: / raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
used: 38.17 GiB (34.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
ID-4: /var/log raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
ID-5: /var/tmp raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.64 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: 36.0 C mobo: 38.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1901 fan-3: 1220 fan-4: 854 fan-5: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.39 vbat: 3.25
Processes: 301 Uptime: 11h 31m wakeups: 9 Memory: 15.64 GiB
used: 3.36 GiB (21.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1782 lib: 537 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.1-3):
System install date: 2022-03-21
Last full system update: 2022-04-18 ↻
I'm trying to map a usb device to a com port for a wine program. To do that however, I need to find the name and path of the device, which I am having trouble with. I have no devices named ttyUSB, ttyACM or anything like that and I'm unfamiliar with what it would be in Garuda. Also, the system does recognize the device.
