sudo garuda-inxi
doas ([email protected]) password:
Kernel: 5.18.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=7325060a-014c-4c0f-a8ba-b8d209f1be3b rw [email protected]
intel_iommu=on i915.enable_gvt=1 i915.enable_fbc=0 quiet
cryptdevice=UUID=c1153f24-b444-4f58-abc3-4419803dcde0:luks-c1153f24-b444-4f58-abc3-4419803dcde0
root=/dev/mapper/luks-c1153f24-b444-4f58-abc3-4419803dcde0 quiet splash
intel_iommu=on ibt=off
Type: Desktop Mobo: PCWARE model: IPMH310G v: x.x serial: N/A
UEFI: American Megatrends v: F11 DB date: 03/29/2019
Info: model: Intel Core i5-8400 socket: LGA1151 (U3E1) note: check bits: 64
type: MCP arch: Coffee Lake gen: core 8 built: 2018 process: Intel 14nm
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
desc: 1x9 MiB
Speed (MHz): avg: 3592 high: 3739 min/max: 800/4000 base/boost: 3800/8300
scaling: driver: intel_pstate governor: performance volts: 1.0 V
ext-clock: 100 MHz cores: 1: 3550 2: 3672 3: 3463 4: 3612 5: 3516 6: 3739
bogomips: 33599
Type: l1tf
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT disabled
STIBP: disabled, RSB filling
Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: Gigabyte
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:21c4 class-ID: 0300
Display: x11 server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_x11 driver: X: loaded: nvidia
display-ID: :0
Message: GL data unavailable for root.
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
Device-2: NVIDIA TU116 High Definition Audio vendor: Gigabyte
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:1aeb
Sound Server-1: ALSA v: k5.18.12-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.55 running: yes
lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
driver: btusb v: 0.8 bus-ID: 1-10:4 chip-ID: 0a12:0001 class-ID: e001
Supported mdraid levels: raid0
Device-1: md0 maj-min: 9:0 type: mdraid level: raid-0 status: active
state: clean size: 3.64 TiB
Info: report: N/A blocks: 3906642944 chunk-size: 512k super-blocks: 1.2
Components: Online:
0: sda maj-min: 8:0 size: 1.82 TiB state: active sync
1: sdb maj-min: 8:16 size: 931.51 GiB state: active sync
2: sdd maj-min: 8:48 size: 931.51 GiB state: active sync
Local Storage: total: raw: 3.86 TiB usable: 3.86 TiB used: 2.51 TiB (65.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
family: BarraCuda 3.5 (SMR) size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 7200
serial: <filter> rev: 0001 temp: 37 C
SMART: yes state: enabled health: PASSED on: 1768h+43m+21.815s
cycles: 336 read: 26.73 TiB written: 12.25 TiB Pre-Fail:
attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM003-1SB102
family: Barracuda 7200.14 (AF) size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: CC43 temp: 32 C
SMART: yes state: enabled health: PASSED on: 2y 239d 2h cycles: 3072
read: 81.99 TiB written: 53.22 TiB Old-Age: UDMA CRC errors: 775116
alert: Bad cable/connection? Pre-Fail: attribute: Spin_Retry_Count
ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: SV300S37A240G
family: Driven SSDs size: 223.57 GiB block-size: physical: 512 B
logical: 512 B sata: 3.0 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: BBF0 temp: 27 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 293d 16h cycles: 3491
read: 52324 GiB written: 46490 GiB
ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST1000DM003-1CH162
physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: CC49 temp: 33 C
SMART: yes state: enabled health: PASSED on: 3y 160d 15h cycles: 4159
read: 94.61 TiB written: 54.1 TiB Old-Age: UDMA CRC errors: 372286
used: 97.98 GiB (43.9%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-c1153f24-b444-4f58-abc3-4419803dcde0
used: 724 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sdc1
maj-min: 8:33
ID-1: swap-1 type: zram size: 15.57 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: 33.0 C mobo: N/A
Processes: 290 Uptime: 14m wakeups: 0 Memory: 15.57 GiB
used: 5.26 GiB (33.8%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: 2300
pacman: 2294 lib: 576 flatpak: 6 Shell: garuda-inxi (doas) default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.19
Garuda (2.6.5-1):
System install date: 2022-06-17
Last full system update: 2022-07-21
Is partially upgraded: Yes
I have a system with an intel i5-8400 and a discrete nvidia Gtx 1660 Super with proprietary drivers. Currently my system only uses the discrete gpu for video but i would like to pass throught my integrated gpu to an already working windows qemu VM for better performance, but the igpu does not appear in the vmm menus.
I already know i need to enable intel GVT-g for that and you can see on my grub configuration that i have done some of the steps. The problem now is that i cant find my igpu on linux, i tried:
lspci | grep VGA
01:00.0 VGA compatible controller: NVIDIA Corporation TU116 [GeForce GTX 1660 SUPER] (rev a1)
But as you can see the only gpu is my nvidia card. I'm absolutely sure this igpu works because i have booted garuda with it before. I tried searching for this problem but found almost nothing related to it as it seem to not be a common problem.
