File system crashes after opening rcloned onedrive directory
  Kernel: 6.9.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=50d4c2af-2fd2-443e-819b-f21c29243442 rw rootflags=subvol=@
  Desktop: Hyprland v: 0.40.0 with: waybar tools: avail: swayidle,swaylock
    vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
  Type: Desktop Mobo: Micro-Star model: X570-A PRO (MS-7C37) v: 3.0
    UEFI: American Megatrends v: H.60 date: 11/06/2019
  Info: model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2 gen: 3
    L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 4249 high: 4253 min/max: N/A cores: 1: 4250 2: 4250
    3: 4250 4: 4248 5: 4250 6: 4250 7: 4250 8: 4250 9: 4244 10: 4250 11: 4250
    12: 4250 13: 4250 14: 4249 15: 4253 16: 4250 bogomips: 136002
    active: DP-1,HDMI-A-1 empty: DP-2,DP-3,Writeback-1 bus-ID: 2f:00.0
    chip-ID: 1002:73df class-ID: 0300
    compositor: Hyprland v: 0.40.0 driver: X: loaded: amdgpu
    gpu: amdgpu d-rect: 3840x1080 display-ID: 1
  Monitor-1: DP-1 pos: primary,left model: Dell U2419H serial: <filter>
    built: 2020 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2 scale: 1
  Monitor-2: HDMI-A-1 pos: right model: Dell U2419H serial: <filter>
    drv: radeonsi inactive: gbm
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.0-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6750 XT (radeonsi
    navi22 LLVM 17.0.6 DRM 3.57 6.9.3-zen1-1-zen) device-ID: 1002:73df
    memory: 11.72 GiB unified: no
  API: Vulkan v: 1.3.279 layers: 4 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6750 XT (RADV NAVI22) driver: mesa radv v: 24.1.0-arch1.1
    device-ID: 1002:73df surfaces: xcb,xlib,wayland device: 1 type: cpu
    v: 24.1.0-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2f:00.1 chip-ID: 1002:ab28
  Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI X570-A PRO
    bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Logitech PRO X Wireless Gaming Headset
    lanes: 1 mode: 1.1 bus-ID: 5-1:4 chip-ID: 046d:0aba class-ID: 0300
  API: ALSA v: k6.9.3-zen1-1-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
    vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8168
  IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 2.05 TiB used: 119.86 GiB (5.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M81000G
    lanes: 4 tech: SSD serial: <filter> fw-rev: S5Z42105 temp: 39.9 C
    scheme: MBR
  ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung model: SSD 980 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 35.9 C
    model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
    fw-rev: 1A02 scheme: GPT
    used: 103.05 GiB (44.3%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:4
    used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
  ID-1: swap-1 type: zram size: 31.29 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 55.2 C mobo: N/A gpu: amdgpu temp: 42.0 C
    mem: 40.0 C
  Memory: total: 32 GiB available: 31.29 GiB used: 4.98 GiB (15.9%)
  Processes: 362 Power: uptime: 4h 31m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.51 GiB services: upowerd Init: systemd
    v: 255 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1347 libs: 395 tools: pacseek,paru Compilers:
    gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: foot
    inxi: 3.3.34
  System install date:     2024-05-01
  Last full system update: 2024-06-02
There is a small problem with the file manager. When I am opening a mounted cloud drive it crashes. I admit that the drive has pictures and a lot of files, but I’ve done it in Garuda Draginized with no issues. Somehow in Hyprland it breaks. If I navigate with the terminal, no issues. I thinks it’s a bug… I don’t know.
Small note: Can anyone direct me to where I can leave feedback and comments for Garuda Hyprland? I LOVE this flavor and I would love to help with some ideas and bring up issues/bugs like this in hope that it can get fixed.
Ok
Microsoft OneDrive - Rclone
Thunar?
I use Dolphin in Hyprland.
Can you check with Dolphin?
I move it to Hyprland | Community but Thunar is unsopported :slight_smile:
The general thing with WMs is that it is just a WM, and we just choose and add the things of third party softwares to make it usable, if you find thunar not working for you then you should try Dolphin or nautilus , even these don’t work then maybe cutefish and deepin filemanager (I would recommend to always back up your important docs before doing such things)
That’s all I can say :confused:
I just installed dolphin and it works like a charm. No crashes no nothing. Thanks!
I would recommend shipping with dolphin since it is much more stable(giving it is the default for Dragonized as well for the sake of consistency).
For removing thunar just sudo pacman -R thunar?
Then mark @SGS as Solution please .
YES :wink:
Personally, I would never uninstall Thunar.
Just recently there were problems with Dolphin because of empty “open with” in Dolphin in Hyprland.
Nowadays we have enough storage to be prepared for all eventualities, I also use Kate and Geany together, depending on what I need at the time.
I see your point of view. I am a dev too. But one thing that I learned is that users first want ONE good thing that works. Then if others come along, even better.
For my case, installing Dolphin was good enough. So thanks for help! Maybe a fix for Thunar will come in the near future and my recommendation will be pointless :smiley:
To clarify, I am not and will never be a developer, my knowledge is not sufficient for that.
I maintain i3wm and hyprland, nothing more and nothing less. :slight_smile:
