Kernel: 5.18.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=be21ce40-5fa9-4063-8c05-b4ea34bf9d40 rw rootflags=subvol=@
Desktop: GNOME v: 42.3.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM
v: 42.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: LENOVO product: 80F6 v: Lenovo B40-80
serial: <superuser required> Chassis: type: 10 v: Lenovo B40-80
Mobo: LENOVO model: Lenovo B40-80 v: SDK0J40679 WIN
serial: <superuser required> UEFI: LENOVO v: A8CN51WW(V3.04)
date: 02/26/2016
ID-1: BAT1 charge: 19.4 Wh (100.0%) condition: 19.4/28.5 Wh (68.2%)
volts: 16.3 min: 14.4
model: 0x53 0x41 0x4E 0x59 0x4F 0x00 0x 003041345333314C type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell
gen: core 5 built: 2015-18 process: Intel 14nm family: 6
model-id: 0x3D (61) stepping: 4 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1656 high: 1896 min/max: 500/1900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1424 2: 1896 3: 1411
4: 1896 bogomips: 15963
Type: l1tf
Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel
arch: Gen8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: X: loaded: modesetting
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1490 built: 2013 res: 1366x768
hz: 60 dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: 1366x768
Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo
Sound Server-1: ALSA v: k5.18.10-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.55 running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wireless 3160 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 8086:08b4 class-ID: 0280
IF: wlp9s0 state: up mac: <filter>
bus-ID: 2-7:2 chip-ID: 8087:07dc class-ID: e001
Local Storage: total: 465.76 GiB used: 22.73 GiB (4.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LT012-1DG142
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: LVM1
used: 22.73 GiB (4.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 3.75 GiB used: 503 MiB (13.1%)
System Temperatures: cpu: 46.0 C mobo: N/A
Processes: 238 Uptime: 1h 46m wakeups: 1 Memory: 3.75 GiB
used: 1.94 GiB (51.8%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 Packages: 1205 pacman: 1200 lib: 352
flatpak: 5 Shell: fish v: 3.4.1 default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.19
Garuda (2.6.5-1):
System install date: 2022-06-29
Last full system update: 2022-07-15 ↻
I need help in using kitty and chafa from fast fetch, I am a newbie so, I dont know where to look at, can someone help me?
Hi there, welcome to the forum!
I don't know what kind of help would be necessary.
Fastfetch is normally launched from the configuration file of the shell you use, I think it has no direct relation with the terminal emulator in use.
Just wanted to say hello and provide a couple of links.
The Arch wiki is always a good starting point, and it has a page for Kitty, small, but with some configuration hints.
https://wiki.archlinux.org/title/Kitty
Nothing available for Chafa, but I see the Arch package site refers to this page as "upstream site":
And, of course, for fastfetch information:
I hope this helps...
I wanted to change the logo to fire dragon, there is nothing to edit in fastfetch config file, but running through fastfetch -h provided me with the option to change logo, so I edited the fish config file to get my desired logo, but now that I've seen more options, I want to experiment with them and I can't find anything related to kitty, chafa, sixel options.
Install fastfetch-git
sudo pacman -S garuda-fastfetch-git
and use in fish config
fastfetch -l garudadragon
yes, I changed the logo already, now I want to explore the other options. These options:
--logo-type : set the type of the logo given. Must be auto, builtin, file, raw, sixel, kitty or chafa.
--logo-width : set the width of the logo (in characters), if it is an image
--logo-height : set the height of the logo (in characters), if it is an image
--logo-color-[1-9] : overwrite a color in the logo
--logo-padding : set the padding on the left and the right of the logo
--logo-padding-left : set the padding on the left of the logo
--logo-padding-right : set the padding on the right of the logo
--logo-print-remaining <?value>: weather to print the remaining logo, if it has more lines than modules to display
--sixel : short for --logo-type sixel --logo
--kitty : short for --logo-type kitty --logo
--chafa : short for --logo-type chafa --logo
--file : short for --logo-type file --logo
--raw : short for --logo-type raw --logo
For this and the other options I think you should anyway refer to the upstream github.
For sure, if anyone here has good hints they will arrive.
But it seems to me too application-specific…
These emulators have basic graphics rendering capabilities, i.e. you can print a crude photo or similar in the terminal. Using these flags allows you to make the Fastfetch logo an image (rendered with the respective emulator’s protocol) instead of the normal ASCII art. Is that what you want?
If you are trying to use this feature and can’t get it to work, you are going to have to provide more details about the specific configuration you are trying so we can see what is going on.
Obviously executing the command in the referenced emulator is a prerequisite for using its image rendering protocol (you cannot use Gnome terminal, for example).
Yes, i want to know how to use these commands, can you provide with some examples please
Just follow the documentation you noted above, put your setup into your ~/.config/fastfetch/config.conf, and see how it goes. If you have trouble getting it to work, like I said you will need to add specific details describing your efforts into the thread so we can try to identify any mistakes in your configuration.
