Made a fresh install with latest dr460nized kde and and my system is having more fan noise and a little more heating which was not same before the updates.
System is updated.
System is updated.
Try htop maybe some app working in background like indexing app.
and clean? no dust inside ![]()
No dust
i keep my laptop more clean than myself.
Can't find much from htop but facing mostly this when playing a video from vlc or mpv.
inxi -Fxxza
indent preformatted text by 4 spaces
sometimes is ~~~ better
System: Kernel: 5.9.13-98-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=7e02b47b-5fff-4b42-827a-250f5371450d rw rootflags=subvol=@ quiet splash
rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: ASUSTeK product: VivoBook 15_ASUS Laptop X507UF v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X507UF v: 1.0 serial: <filter> UEFI: American Megatrends v: X507UF.305
date: 07/17/2019
Battery: ID-1: BAT0 charge: 19.9 Wh condition: 20.5/33.3 Wh (62%) volts: 11.1/11.1 model: ASUSTeK ASUS Battery
type: Li-ion serial: N/A status: Charging cycles: 752
CPU: Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Kaby Lake family: 6
model-id: 8E (142) stepping: A (10) microcode: E0 L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28824
Speed: 1577 MHz min/max: 400/1600 MHz Core speeds (MHz): 1: 1586 2: 1600 3: 1596 4: 1600 5: 1600
6: 1600 7: 1600 8: 1579
Graphics: Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:5917
Device-2: NVIDIA GM108M [GeForce MX130] vendor: ASUSTeK driver: nouveau v: kernel bus ID: 01:00.0
chip ID: 10de:174d
Device-3: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo bus ID: 1-6:2
chip ID: 13d3:5a11
Display: x11 server: X.org 1.20.10 compositor: kwin_x11 driver: intel,nouveau unloaded: modesetting
alternate: fbdev,nv,vesa resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.0 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus ID: 00:1f.3 chip ID: 8086:9d71
Sound Server: ALSA v: k5.9.13-98-tkg-bmq
Network: Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: e000 bus ID: 02:00.0
chip ID: 8086:24fd
Drives: Local Storage: total: 931.51 GiB used: 245.96 GiB (26.4%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: SDM4 scheme: GPT
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: f060
bus ID: 00:17.0 chip ID: 8086.282a rev: 21
Partition: ID-1: / raw size: 230.00 GiB size: 230.00 GiB (100.00%) used: 9.52 GiB (4.1%) fs: btrfs dev: /dev/sda7
ID-2: /home raw size: 230.00 GiB size: 230.00 GiB (100.00%) used: 9.52 GiB (4.1%) fs: btrfs
dev: /dev/sda7
ID-3: /var/log raw size: 230.00 GiB size: 230.00 GiB (100.00%) used: 9.52 GiB (4.1%) fs: btrfs
dev: /dev/sda7
ID-4: /var/tmp raw size: 230.00 GiB size: 230.00 GiB (100.00%) used: 9.52 GiB (4.1%) fs: btrfs
dev: /dev/sda7
ID-1: swap-1 type: partition size: 8.00 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda4
ID-2: swap-2 type: zram size: 979.4 MiB used: 264 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 979.4 MiB used: 512 KiB (0.1%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 979.4 MiB used: 264 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 979.4 MiB used: 256 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-6: swap-6 type: zram size: 979.4 MiB used: 276 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-7: swap-7 type: zram size: 979.4 MiB used: 512 KiB (0.1%) priority: 32767 dev: /dev/zram5
ID-8: swap-8 type: zram size: 979.4 MiB used: 512 KiB (0.1%) priority: 32767 dev: /dev/zram6
ID-9: swap-9 type: zram size: 979.4 MiB used: 392 KiB (0.0%) priority: 32767 dev: /dev/zram7
Sensors: System Temperatures: cpu: 87.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3600
Info: Processes: 276 Uptime: 5h 50m wakeups: 25 Memory: 7.65 GiB used: 4.77 GiB (62.4%) Init: systemd v: 247
Compilers: gcc: 10.2.0 clang: 11.0.0 Packages: pacman: 1124 lib: 291 Shell: fish v: 3.1.2
running in: konsole inxi: 3.1.09
More RAM could help?
Use less app as possible.
auto-cpufreq --log
Linux distro: Garuda Linux Rolling n/a
Linux kernel: 5.9.12-97-tkg-bmq
Processor: Intel(R) Core(TM) i5-4300M CPU @ 2.60GHz
Cores: 4
Architecture: x86_64
Driver: intel_cpufreq
------------------------------ Current CPU states ------------------------------
CPU max frequency: 3300 MHz
CPU min frequency: 800 MHz
Usage Temperature Frequency
CPU0: 100.0% 74 °C 3193 MHz
CPU1: 100.0% 74 °C 3193 MHz
CPU2: 100.0% 75 °C 3193 MHz
CPU3: 100.0% 75 °C 3193 MHz
---------------------------- CPU frequency scaling ----------------------------
Battery is: charging
Setting to use: "performance" governor
Total CPU usage: 100.0 %
Total system load: 7.13
Average temp. of all cores: 74.5 °C
High CPU load
setting turbo boost: on
"auto-cpufreq" refresh in: 2
Should show what governor / freqs are used.
it says autocpufreq: command not found
/usr/bin/cpufreqctl: line 267: echo: write error: Invalid argument
Linux distro: Garuda Linux Soaring n/a
Linux kernel: 5.9.13-98-tkg-bmq
Processor: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
Cores: 8
CPU max frequency: 1600 MHz
CPU min frequency: 400 MHz
CPU0: 44.4% 68 °C 1569 MHz
CPU1: 37.4% 68 °C 1523 MHz
CPU2: 39.0% 70 °C 1598 MHz
CPU3: 21.2% 69 °C 1574 MHz
CPU4: 11.0% 68 °C 1262 MHz
CPU5: 14.3% 68 °C 1414 MHz
CPU6: 13.9% 70 °C 1600 MHz
CPU7: 15.0% 69 °C 1600 MHz
Setting to use: "balance_performance" EPP
Total CPU usage: 11.8 %
Total system load: 2.14
Average temp. of all cores: 68.75 °C
Load optimal
Optimal total CPU usage: 11.8 %, high average core temp: 68.75 °C
setting turbo boost: off
pacman -Qi auto-cpufreq-git
Version : 1.5.1.r187.070103d-1
Beschreibung : Automatic CPU speed & power optimizer
Architektur : any
URL : https://github.com/AdnanHodzic/auto-cpufreq
Lizenzen : LGPL-3.0
Gruppen : Nichts
Stellt bereit : auto-cpufreq
Hängt ab von : python-distro python-psutil python-click
Optionale Abhängigkeiten : cpufreqctl: CPU Power Manager
gnome-shell-extension-cpufreq: CPU Power Manager for GNOME Shell
Benötigt von : performance-tweaks
Optional für : Nichts
In Konflikt mit : auto-cpufreq
Ersetzt : Nichts
Installationsgröße : 99,21 KiB
Packer : Pedro Henrique Lara Campos <root@pedrohlc.com>
Erstellt am : Mo 07 Dez 2020 21:07:48 CET
Installiert am : Mo 07 Dez 2020 23:30:17 CET
Installationsgrund : Installiert als Abhängigkeit für ein anderes Paket
Installations-Skript : Ja
Verifiziert durch : Signatur
Well can you give me output of
mhwd -l
And
mhwd -li
mostly open 4 to 5 apps like vscode firefox telegram vlc so i think it should be sufficient for 8 gb ram to run.
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-dkms-prime-render-offloading 2020.12.07 false PCI
video-nvidia-dkms 2020.12.07 false PCI
video-hybrid-intel-nvidia-390xx-dkms-bumblebee 2020.12.07 false PCI
video-nvidia-390xx-dkms 2020.12.07 false PCI
video-linux 2020.12.03 true PCI
> 0000:00:02.0 (0300:8086:5917) Display controller Intel Corporation:
video-modesetting 2020.07.13 true PCI
video-vesa 2017.03.12 true PCI
Installed PCI configs:
Ohh it seems i made a big mistake
It seems optimus-manager isnt installed for your hardware so its possible both gpu are powered on.
I will do an update and you can give me the output again
I think i should mention
I choose free during installation. I don't have much idea but once installed with nonfree drivers and there was a more battery drainage so afterwards I choose free drivers.
Well but still can you do this
sudo pacman -Sy mhwd-db-garuda-git
Then give me output of
mhwd -l
video-optimus-manager 2020.12.08 false PCI
Okay now do this
sudo mhwd -a pci nonfree 0300
done.[quote="librewish, post:19, topic:1890"]
do
[/quote]
done
