Installed Garuda on a Sony Vaio and occasionally the fan will get out of control and system locks up.
Looking into how to control the fans I looked to:
https://wiki.archlinux.org/title/fan_speed_control
But when I get to pwmconfig it says: There are no pwm-capable sensor modules installed
So it seems that's not a solution.
My thought then is to look into what is actually the cause of the system thinking it's overheating. Hoping someone might have some suggestions. Normally I'll keep tabs on what top is showing. But I never really see it go over 1.x load average. Looking through journalctl has also not been very helpful.
Thanks for any suggestions.
Curtis
Kernel: 6.1.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=43f18a73-c753-4e08-9fba-b8afedfcb3ac rw [email protected]
resume=UUID=9431c5cc-6a40-4ec6-91b8-d397f24a4c4e loglevel=3 ibt=off
Desktop: GNOME v: 43.3 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: Sony product: VPCZ21TGX v: J004MUHH
Mobo: Sony model: VAIO serial: <superuser required> BIOS: INSYDE
v: R0170H5 date: 06/16/2011
ID-1: BAT1 charge: 0 Wh condition: N/A volts: N/A model: Sony Corporation
type: Li-ion serial: N/A status: not charging
Info: model: Intel Core i7-2620M bits: 64 type: MT MCP arch: Sandy Bridge
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 818 high: 878 min/max: 800/3400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 798 3: 878 4: 798
bogomips: 21551
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
vendor: Sony driver: i915 v: kernel arch: Gen-6 code: Sandybridge
process: Intel 32nm built: 2011 ports: active: eDP-1
empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0126
Device-2: Cheng Uei Precision Industry (Foxlink) Webcam type: USB
driver: uvcvideo bus-ID: 1-1.3:5 chip-ID: 05c8:0318 class-ID: 0e02
compositor: gnome-shell driver: X: loaded: modesetting
alternate: fbdev,intel,vesa dri: crocus gpu: i915 display-ID: :1
Monitor-1: eDP-1 model: Sony LCD serial: <filter> built: 2011
res: 1920x1080 hz: 60 dpi: 168 gamma: 1.2 size: 291x164mm (11.46x6.46")
diag: 334mm (13.2") ratio: 16:9 modes: 1920x1080
missing.
vendor: Sony driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Sound API: ALSA v: k6.1.12-zen1-1-zen running: yes
Device-1: Intel Centrino Advanced-N 6230 [Rainbow Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 8086:0091 class-ID: 0280
vendor: Sony driver: r8168 v: 8.051.02-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 6000 bus-ID: 05:00.0 chip-ID: 10ec:8168
Device-1: Intel Centrino Advanced-N 6230 Bluetooth adapter type: USB
driver: btusb v: 0.8 bus-ID: 1-1.2:4 chip-ID: 8086:0189 class-ID: e001
v: 3.0 port: a060 bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 238.49 GiB used: 46.71 GiB (19.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZRPC256HADR-000SO
type: SSD serial: <filter> rev: 3S1Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: MZRPC256HADR-000SO
ID-1: / raw-size: 110.44 GiB size: 110.44 GiB (100.00%)
used: 46.71 GiB (42.3%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 110.44 GiB size: 110.44 GiB (100.00%)
ID-3: /var/log raw-size: 110.44 GiB size: 110.44 GiB (100.00%)
ID-4: /var/tmp raw-size: 110.44 GiB size: 110.44 GiB (100.00%)
ID-1: swap-1 type: zram size: 5.71 GiB used: 1.24 GiB (21.7%)
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 53.0 C mobo: N/A
Processes: 262 Uptime: 56m wakeups: 1 Memory: 5.71 GiB
used: 3.24 GiB (56.7%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1554
libs: 491 tools: gnome-software,pamac,paru pm: flatpak pkgs: 0 Shell: fish
v: 3.6.0 default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2022-05-03
Last full system update: 2023-02-25 ↻
Relevant software: snapper(custom) NetworkManager mkinitcpio
