I’m running the kernel module asus-nb-wmi. I go to /sys/devices/platform/asus-nb-wmi/hwmon/hwmon? like it talks about here Fan speed control - ArchWiki
lrwxrwxrwx - root 22 Feb 13:24 device -> ../../../asus-nb-wmi
drwxr-xr-x - root 22 Feb 13:24 power
lrwxrwxrwx - root 22 Feb 13:14 subsystem -> ../../../../../class/hwmon
.r--r--r-- 4.1k root 22 Feb 13:24 fan1_input
.r--r--r-- 4.1k root 22 Feb 13:24 fan1_label
.r--r--r-- 4.1k root 22 Feb 13:24 fan2_input
.r--r--r-- 4.1k root 22 Feb 13:24 fan2_label
.r--r--r-- 4.1k root 22 Feb 13:24 name
.rw-r--r-- 4.1k root 22 Feb 13:24 pwm1_enable
.rw-r--r-- 4.1k root 22 Feb 13:24 pwm2_enable
.rw-r--r-- 4.1k root 22 Feb 13:14 uevent
echo 0 > pwm1/2_enable doesn’t do anything. I tried installing asus_fan. I.e.
pacman -Q dkms - to verify, which of course it’s installed becaused it’s used with the dkms nvidia module
sudo modprobe asus_fan - which responds ‘no devices found’
I’ve tried installing the AUR package asusctl, however the GUI doesn’t show fans
Am I SOL on controlling that second fan? (I mean, I can’t seem to control the first fan. But at least it runs)
Info: model: AMD Ryzen 7 6800H with Radeon Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 821 high: 1370 min/max: 400/4785 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1370 2: 400 3: 1367
4: 400 5: 1367 6: 1361 7: 1357 8: 1359 9: 1368 10: 400 11: 400 12: 400
13: 400 14: 400 15: 400 16: 400 bogomips: 102208
Device-1: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] vendor: ASUSTeK
status: current (as of 2024-02; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 8 link-max: lanes: 16 ports: active: none empty: HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:25a0 class-ID: 0300
Device-2: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,
DP-2, DP-3, DP-4, DP-5 bus-ID: 34:00.0 chip-ID: 1002:1681 class-ID: 0300
temp: 54.0 C
Device-3: Quanta USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:4 chip-ID: 0408:30e1
gpu: nvidia,amdgpu display-ID: 0
Monitor-1: eDP-1 res: 1707x1067 size: N/A modes: N/A
surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.0.1-arch1.1
rembrandt LLVM 16.0.6 DRM 3.57 6.7.5-zen1-1-zen) device-ID: 1002:1681
API: Vulkan v: 1.3.276 layers: 8 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV REMBRANDT) driver: mesa radv v: 24.0.1-arch1.1
device-ID: 1002:1681 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce RTX 3050 Ti Laptop GPU
driver: nvidia v: 545.29.06 device-ID: 10de:25a0
16.0.6 256 bits) driver: mesa llvmpipe v: 24.0.1-arch1.1 (LLVM 16.0.6)
gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:2291 class-ID: 0403
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 34:00.1
snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 34:00.5
bus-ID: 34:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-5: Sony DualSense wireless controller (PS5)
driver: playstation,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 054c:0ce6 class-ID: 0300
API: ALSA v: k6.7.5-zen1-1-zen status: kernel-api with: aoss
lanes: 1 bus-ID: 02:00.0 chip-ID: 14c3:0616 class-ID: 0280
Device-2: Sony DualSense wireless controller (PS5)
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:3 chip-ID: 0489:e0e2
Local Storage: total: 953.87 GiB used: 159.16 GiB (16.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 3400 MTFDKBA1T0TFH
lanes: 4 tech: SSD serial: <filter> fw-rev: P7MA002 temp: 38.9 C
ID-1: / raw-size: 280.9 GiB size: 280.9 GiB (100.00%)
used: 159.16 GiB (56.7%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: /boot/efi raw-size: 1000.7 MiB size: 998.7 MiB (99.80%)
used: 3.9 MiB (0.4%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6
ID-3: /home raw-size: 280.9 GiB size: 280.9 GiB (100.00%)
ID-4: /var/log raw-size: 280.9 GiB size: 280.9 GiB (100.00%)
ID-5: /var/tmp raw-size: 280.9 GiB size: 280.9 GiB (100.00%)
ID-1: swap-1 type: zram size: 14.89 GiB used: 4.84 GiB (32.5%)
System Temperatures: cpu: 56.8 C mobo: 42.0 C gpu: amdgpu temp: 55.0 C
Fan Speeds (rpm): cpu: 0
Memory: total: 16 GiB note: est. available: 14.89 GiB used: 6.59 GiB (44.2%)
Processes: 388 Power: uptime: 1h 6m states: freeze,mem,disk
suspend, test_resume image: 5.91 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1559 libs: 492 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0 running-in: konsole
inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-12-27
Last full system update: 2024-02-21 ↻
