Fan always off
I just installed Garuda Linux with i3 for the first time. Everything seems to be working fine, apart from the CPU fan, it is always off, my CPU is running really hot now, currently at 83C, and the fan just does not turn on, no matter how high the temperature. On other distros it usually jumps on at around 60C.
On one hand I like the silence, on the other hand I am a bit worried about the longevity of my mini PC (Larkbox Pro).
Please let me know if this is intentional and/or if it can be adjusted. Thanks!
Please post
inxi -Fxxxza
read
and
:slight_smile:
Thanks for the quick reply.
inxi -Fxxxza (PrivateBin)
To confirm: this issue was present from the start, I have not modified the system in any way, apart from installing a couple programs (vivaldi, sublime-text) that do not control fan speed, cpu freq etc.
Currently CPU usage is at 7%, yet the CPU temp does not drop from 76C without the fan, due to the PC being so tiny and having almost no heat sink the fan is really the only way to carry the heat away.
I have tested Win10 (came with it) , Manjaro KDE, Pop_OS! and the fan is working in all those OSs.
System:    Kernel: 5.9.12-97-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
           root=UUID=c0c1c348-f8ce-46ec-922d-c0ec104af2d6 rw rootflags=subvol=@ quiet splash
           rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3
           Desktop: i3 4.19 info: i3bar dm: LightDM 1.30.0 Distro: Garuda Linux
Machine:   Type: Desktop System: CHUWI Innovation And (ShenZhen) product: LarkBox Pro v: N/A serial: <filter>
           Mobo: N/A model: N/A serial: <filter> UEFI: American Megatrends v: GB01_ZW_1_05 date: 09/17/2020
Battery:   Device-1: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball serial: <filter>
           charge: 55% (should be ignored) rechargeable: yes status: Discharging
           Device-2: hidpp_battery_1 model: Logitech Wireless Touch Keyboard K400 Plus serial: <filter>
CPU:       Info: Quad Core model: Intel Celeron J4125 bits: 64 type: MCP arch: Goldmont Plus family: 6
           model-id: 7A (122) stepping: 8 microcode: 18 L2 cache: 4096 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 15989
           Speed: 128 MHz min/max: 800/1080 MHz Core speeds (MHz): 1: 127 2: 998 3: 998 4: 998
Graphics:  Device-1: Intel UHD Graphics 605 driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3185
           Display: x11 server: X.Org 1.20.10 compositor: picom v: git-dac85 driver: intel unloaded: modesetting
           alternate: fbdev,vesa display ID: :0 screens: 1
           Monitor-1: HDMI1 res: 1920x1080 hz: 60 dpi: 94 size: 520x290mm (20.5x11.4") diag: 595mm (23.4")
           OpenGL: renderer: Mesa Intel UHD Graphics 600 (GLK 2) v: 4.6 Mesa 20.3.0 direct render: Yes
Audio:     Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio vendor: Realtek
           driver: snd_hda_intel v: kernel bus ID: 00:0e.0 chip ID: 8086:3198
           Device-2: Audio-Technica ATR USB microphone type: USB driver: hid-generic,snd-usb-audio,usbhid
           bus ID: 1-8.1:4 chip ID: 0909:001b
           Sound Server: ALSA v: k5.9.12-97-tkg-bmq
Network:   Device-1: Intel driver: iwlwifi v: kernel port: f000 bus ID: 00:0c.0 chip ID: 8086:31dc
           IF: wlo2 state: up mac: <filter>
Drives:    Local Storage: total: 564.13 GiB used: 10.21 GiB (1.8%)
           ID-1: /dev/mmcblk0 model: UY7CS0 size: 117.00 GiB block size: physical: 512 B logical: 512 B
           serial: <filter> rev: 0x8 scheme: GPT
           ID-2: /dev/sda model: KSN480 size: 447.13 GiB block size: physical: 512 B logical: 512 B
           speed: 6.0 Gb/s serial: <filter> rev: 170 scheme: GPT
Partition: ID-1: / raw size: 78.12 GiB size: 78.12 GiB (100.00%) used: 9.91 GiB (12.7%) fs: btrfs dev: /dev/sda5
           ID-2: /home raw size: 78.12 GiB size: 78.12 GiB (100.00%) used: 9.91 GiB (12.7%) fs: btrfs
           dev: /dev/sda5
           ID-3: /var/log raw size: 78.12 GiB size: 78.12 GiB (100.00%) used: 9.91 GiB (12.7%) fs: btrfs
           dev: /dev/sda5
           ID-4: /var/tmp raw size: 78.12 GiB size: 78.12 GiB (100.00%) used: 9.91 GiB (12.7%) fs: btrfs
           dev: /dev/sda5
Swap:      Kernel: swappiness: 10 (default 60) cache pressure: 75 (default 100)
           ID-1: swap-1 type: partition size: 4.00 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda4
           ID-2: swap-2 type: zram size: 1.41 GiB used: 812 KiB (0.1%) priority: 32767 dev: /dev/zram0
           ID-3: swap-3 type: zram size: 1.41 GiB used: 956 KiB (0.1%) priority: 32767 dev: /dev/zram1
           ID-4: swap-4 type: zram size: 1.41 GiB used: 808 KiB (0.1%) priority: 32767 dev: /dev/zram2
           ID-5: swap-5 type: zram size: 1.41 GiB used: 752 KiB (0.1%) priority: 32767 dev: /dev/zram3
Sensors:   System Temperatures: cpu: 80.0 C mobo: N/A
Info:      Processes: 264 Uptime: 50m wakeups: 7 Memory: 5.63 GiB used: 2.61 GiB (46.4%) Init: systemd v: 247
           Compilers: gcc: 10.2.0 clang: 11.0.0 Packages: pacman: 1205 lib: 288 flatpak: 0 Shell: Zsh v: 5.8
           running in: xfce4-terminal inxi: 3.1.09
Befor or after install i3wm?
Can you run the live ISO to see if it is the same there, if so also another OS, so we can rule out a hardware failure/dust?
I just booted into Win10 again, fan is working fine. Actually the very moment I start rebooting Garuda the fan turns on, so it must be some program blocking it. The fan turns on when the reboot process is initiated, way before actually halting the system.
I will test the live ISO later again.
Like always in Win dual boot, time, bluetooth ... fan? are blocked.
Really not sure what you mean. As mentioned, the fan immediately kicks on while I am shutting down Garuda, so I don't see what Windows has to do with anything.
Windoze often interferes on a hardware level with Linux. Windoze has developed the nasty habit of disabling hardware at the bios or onboard firmware level.
Windows often turns off devices at shutdown or suspend to conserve power. These changes persist after a reboot into Linux. Sometimes the changes persist even after Windows is uninstalled. In these cases Windows actually needs to be reinstalled to allow the device to be turned on again.
You would best to go through as many of Windows advanced power saving feature settings as you can find and disable them.
True, but generalizing leads to conspiracy theories. We have enough of them with the pandemic :wink:.
You may not have lm-sensors installed. Install it if it isn’t already.
Read more and try to configure, if your HW is compatible.
https://wiki.archlinux.org/index.php/Fan_speed_control#Overview
I beg to differ, we always have room for a few more conspiracy theories.
Which inevitably brings me back to:
While not everything can be proved to be Windoze fault, why do so many that dual boot with Windows have so many problems?
If it’s not Windows causing all these bizzare quirks, are all the people who dual boot Windows simply as a group the most unlucky people on the planet.
Just saying, statistically if you search the forum for “Windows Dual Boot” you’ll basically find almost without exception every topic is cursed with some strange issue.
Coincidence, conspiracy, or just terrible luck. I’ll leave it for you to decide.
:wink:
It’s just coincidence, WinOS is a comparison reference. It’s an unavoidable step to Linux switching.
It’s mostly boot issues (related to Win ties to UEFI) and a couple of HW switches, due to vendors MS interconnection (for easy profit).
We have solutions for most of them and continue to scrap out more. :man_shrugging:
I left WinOS on my new laptop for my only vulnerability, my kids, until they switch too (which is difficult with University ties to all MS products). We are still on discussions :laughing:
