When booting the monitors stay on but the login screen is not appearing.
I tried to reinstall nvidia driver (reinstalled garuda-hardware-profile-nvidia, didn’t solve it).
What I found myself so far is that when I remove __GLX_VENDOR_LIBRARY_NAME=nvidia
from /etc/environment the system boots again. It fallbacks to software rendering using llvmpipe instead of my amd igpu.
Error of sddm-greeter-qt:
Nov 01 10:40:16 thomas-desktop systemd[1]: Started User Manager for UID 960.
Nov 01 10:40:16 thomas-desktop systemd[1]: Started Session c1 of User sddm.
Nov 01 10:40:16 thomas-desktop sddm-helper[4713]: Writing cookie to "/tmp/xauth_UUIKQu"
Nov 01 10:40:16 thomas-desktop sddm-helper[4713]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-mVIipw --theme /usr/share/sddm/themes/Dr460nized"
Nov 01 10:40:16 thomas-desktop sddm[1238]: Greeter session started successfully
Nov 01 10:40:16 thomas-desktop sddm-greeter-qt6[5207]: High-DPI autoscaling Enabled
Nov 01 10:40:16 thomas-desktop sddm-greeter-qt6[5207]: Reading from "/usr/share/wayland-sessions/plasma.desktop"
Nov 01 10:40:16 thomas-desktop sddm-greeter-qt6[5207]: Loading theme configuration from "/usr/share/sddm/themes/Dr460nized/theme.conf"
Nov 01 10:40:16 thomas-desktop systemd[4857]: Created slice User Core Session Slice.
Nov 01 10:40:16 thomas-desktop systemd[4857]: Starting D-Bus User Message Bus...
Nov 01 10:40:16 thomas-desktop dbus-broker-launch[5395]: Service file '/usr/share/dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Nov 01 10:40:16 thomas-desktop dbus-broker-launch[5395]: Service file '/usr/share/dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Nov 01 10:40:16 thomas-desktop dbus-broker-launch[5395]: Service file '/usr/share/dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Nov 01 10:40:16 thomas-desktop dbus-broker-launch[5395]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +31: Eavesdropping is deprecated and ignored
Nov 01 10:40:16 thomas-desktop dbus-broker-launch[5395]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +33: Eavesdropping is deprecated and ignored
Nov 01 10:40:16 thomas-desktop systemd[4857]: Started D-Bus User Message Bus.
Nov 01 10:40:16 thomas-desktop dbus-broker-launch[5395]: Ready
Nov 01 10:40:16 thomas-desktop sddm-greeter-qt6[5207]: Connected to the daemon.
Nov 01 10:40:16 thomas-desktop sddm[1238]: Message received from greeter: Connect
Nov 01 10:40:16 thomas-desktop sddm-greeter-qt6[5207]: Unrecognized OpenGL version
Nov 01 10:40:16 thomas-desktop sddm-greeter-qt6[5207]: QGLXContext: Failed to create dummy context
Nov 01 10:40:16 thomas-desktop sddm-greeter-qt6[5207]: Loading file:///usr/share/sddm/themes/Dr460nized/Main.qml...
Nov 01 10:40:16 thomas-desktop sddm-greeter-qt6[5207]: KeyStatesEngine is deprecated. Use KeyState from org.kde.plasma.private.keyboardindicator instead.
Nov 01 10:40:16 thomas-desktop sddm-greeter-qt6[5207]: file:///usr/share/sddm/themes/Dr460nized/Main.qml:351:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Nov 01 10:40:17 thomas-desktop sddm-greeter-qt6[5207]: file:///usr/share/sddm/themes/Dr460nized/Login.qml:93:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Nov 01 10:40:17 thomas-desktop sddm-greeter-qt6[5207]: file:///usr/share/sddm/themes/Dr460nized/Login.qml:21: ReferenceError: units is not defined
Nov 01 10:40:17 thomas-desktop sddm-greeter-qt6[5207]: Unrecognized OpenGL version
Nov 01 10:40:17 thomas-desktop sddm-greeter-qt6[5207]: QGfxShaderBuilder: Failed to acquire GL context to resolve capabilities, using defaults.
Nov 01 10:40:17 thomas-desktop sddm-greeter-qt6[5207]: file:///usr/share/sddm/themes/Dr460nized/Main.qml:320: ReferenceError: units is not defined
Nov 01 10:40:17 thomas-desktop sddm-greeter-qt6[5207]: Adding view for "HDMI-1" QRect(0,0 2560x1080)
Nov 01 10:40:17 thomas-desktop sddm-greeter-qt6[5207]: Loading file:///usr/share/sddm/themes/Dr460nized/Main.qml...
Nov 01 10:40:17 thomas-desktop sddm-greeter-qt6[5207]: file:///usr/share/sddm/themes/Dr460nized/Main.qml:351:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Nov 01 10:40:17 thomas-desktop sddm-greeter-qt6[5207]: Adding view for "HDMI-0" QRect(2560,0 1920x1080)
Nov 01 10:40:17 thomas-desktop sddm-greeter-qt6[5207]: QRhiGles2: Failed to make context current. Expect bad things to happen.
Nov 01 10:40:17 thomas-desktop sddm-greeter-qt6[5207]: Failed to create RHI (backend 2)
Nov 01 10:40:17 thomas-desktop sddm-greeter-qt6[5207]: Failed to initialize graphics backend for OpenGL.
Nov 01 10:40:17 thomas-desktop systemd-coredump[6592]: Process 5207 (sddm-greeter-qt) of user 960 terminated abnormally with signal 6/ABRT, processing...
Nov 01 10:40:17 thomas-desktop systemd[1]: Created slice Slice /system/systemd-coredump.
Nov 01 10:40:17 thomas-desktop systemd[1]: Started Process Core Dump (PID 6592/UID 0).
Nov 01 10:40:17 thomas-desktop systemd-coredump[6613]: Process 5207 (sddm-greeter-qt) of user 960 dumped core.
Stack trace of thread 5207:
#0 0x00007f50a209894c n/a (libc.so.6 + 0x9894c)
#1 0x00007f50a203e410 raise (libc.so.6 + 0x3e410)
#2 0x00007f50a202557a abort (libc.so.6 + 0x2557a)
#3 0x00007f50a289348c n/a (libQt6Core.so.6 + 0x9348c)
#4 0x00007f50a2894250 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x94250)
#5 0x00007f50a450f58b n/a (libQt6Quick.so.6 + 0x10f58b)
#6 0x00007f50a46fe2ea n/a (libQt6Quick.so.6 + 0x2fe2ea)
#7 0x00007f50a46fff37 n/a (libQt6Quick.so.6 + 0x2fff37)
#8 0x00007f50a4700b37 n/a (libQt6Quick.so.6 + 0x300b37)
#9 0x00007f50a3415ccc _ZN7QWindow5eventEP6QEvent (libQt6Gui.so.6 + 0x215ccc)
#10 0x00007f50a296a6c8 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt6Core.so.6 + 0x16a6c8)
#11 0x00007f50a33ab36a _ZN22QGuiApplicationPrivate18processExposeEventEPN29QWindowSystemInterfacePrivate11ExposeEventE (libQt6Gui.so.6 + 0x1ab36a)
#12 0x00007f50a342cf2c _ZN22QWindowSystemInterface22sendWindowSystemEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Gui.so.6 + 0x22cf2c)
#13 0x00007f509e43e3f7 n/a (libQt6XcbQpa.so.6 + 0x563f7)
#14 0x00007f50a1f06f8d n/a (libglib-2.0.so.0 + 0x5ef8d)
#15 0x00007f50a1f08657 n/a (libglib-2.0.so.0 + 0x60657)
#16 0x00007f50a1f08865 g_main_context_iteration (libglib-2.0.so.0 + 0x60865)
#17 0x00007f50a2c4a9d2 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x44a9d2)
#18 0x00007f50a2975a86 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x175a86)
#19 0x00007f50a296f171 _ZN16QCoreApplication4execEv (libQt6Core.so.6 + 0x16f171)
#20 0x00005624be399fe3 n/a (/usr/bin/sddm-greeter-qt6 + 0x13fe3)
#21 0x00007f50a2027675 n/a (libc.so.6 + 0x27675)
#22 0x00007f50a2027729 __libc_start_main (libc.so.6 + 0x27729)
#23 0x00005624be39c9e5 n/a (/usr/bin/sddm-greeter-qt6 + 0x169e5)
Stack trace of thread 5365:
#0 0x00007f50a209f042 n/a (libc.so.6 + 0x9f042)
#1 0x00007f50a20931ac n/a (libc.so.6 + 0x931ac)
#2 0x00007f50a20931f4 n/a (libc.so.6 + 0x931f4)
#3 0x00007f50a210d4ee __poll (libc.so.6 + 0x10d4ee)
#4 0x00007f50a43e220b n/a (libxcb.so.1 + 0xd20b)
#5 0x00007f50a43e3f3d xcb_wait_for_event (libxcb.so.1 + 0xef3d)
#6 0x00007f509e43be29 n/a (libQt6XcbQpa.so.6 + 0x53e29)
#7 0x00007f50a2b30ca9 n/a (libQt6Core.so.6 + 0x330ca9)
#8 0x00007f50a20969cb n/a (libc.so.6 + 0x969cb)
#9 0x00007f50a211aa0c n/a (libc.so.6 + 0x11aa0c)
Stack trace of thread 5390:
#3 0x00007f50a210da36 ppoll (libc.so.6 + 0x10da36)
#4 0x00007f50a1f08784 n/a (libglib-2.0.so.0 + 0x60784)
#5 0x00007f50a1f08865 g_main_context_iteration (libglib-2.0.so.0 + 0x60865)
#6 0x00007f50a2c4a9d2 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x44a9d2)
#7 0x00007f50a2975a86 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x175a86)
#8 0x00007f50a2a8af7e _ZN7QThread4execEv (libQt6Core.so.6 + 0x28af7e)
#9 0x00007f50a2e8b63e n/a (libQt6DBus.so.6 + 0x3763e)
#10 0x00007f50a2b30ca9 n/a (libQt6Core.so.6 + 0x330ca9)
#11 0x00007f50a20969cb n/a (libc.so.6 + 0x969cb)
#12 0x00007f50a211aa0c n/a (libc.so.6 + 0x11aa0c)
Stack trace of thread 6493:
#9 0x00007f50a2b30ca9 n/a (libQt6Core.so.6 + 0x330ca9)
#10 0x00007f50a20969cb n/a (libc.so.6 + 0x969cb)
#11 0x00007f50a211aa0c n/a (libc.so.6 + 0x11aa0c)
Stack trace of thread 6351:
#9 0x00007f50a47a0ba2 n/a (libQt6Quick.so.6 + 0x3a0ba2)
Stack trace of thread 6173:
#0 0x00007f50a211876d syscall (libc.so.6 + 0x11876d)
#1 0x00007f50a2a91e97 n/a (libQt6Core.so.6 + 0x291e97)
#2 0x00007f5083fd4dc5 n/a (libQt6HunspellInputMethod.so.6 + 0xedc5)
#3 0x00007f50a2b30ca9 n/a (libQt6Core.so.6 + 0x330ca9)
#4 0x00007f50a20969cb n/a (libc.so.6 + 0x969cb)
#5 0x00007f50a211aa0c n/a (libc.so.6 + 0x11aa0c)
Stack trace of thread 5585:
Stack trace of thread 6320:
#2 0x00007f50a209381c n/a (libc.so.6 + 0x9381c)
#3 0x00007f50a2095ede pthread_cond_wait (libc.so.6 + 0x95ede)
#4 0x00007f50a2b35269 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt6Core.so.6 + 0x335269)
#5 0x00007f50833c9ee8 n/a (libQt6LabsFolderListModel.so.6 + 0xcee8)
#6 0x00007f50a2b30ca9 n/a (libQt6Core.so.6 + 0x330ca9)
#7 0x00007f50a20969cb n/a (libc.so.6 + 0x969cb)
#8 0x00007f50a211aa0c n/a (libc.so.6 + 0x11aa0c)
Stack trace of thread 6563:
Stack trace of thread 6569:
ELF object binary architecture: AMD x86-64
Nov 01 10:40:17 thomas-desktop systemd[1]: systemd-coredump@0-1-6592_6593-0.service: Deactivated successfully.
Nov 01 10:40:17 thomas-desktop systemd[1]: systemd-coredump@0-1-6592_6593-0.service: Consumed 366ms CPU time, 196.7M memory peak.
Nov 01 10:40:17 thomas-desktop sddm-helper[4713]: [PAM] Closing session
Nov 01 10:40:17 thomas-desktop sddm-helper[4713]: pam_unix(sddm-greeter:session): session closed for user sddm
Nov 01 10:40:17 thomas-desktop sddm-helper[4713]: [PAM] Ended.
Nov 01 10:40:17 thomas-desktop systemd[1]: session-c1.scope: Deactivated successfully.
Nov 01 10:40:17 thomas-desktop sddm[1238]: Auth: sddm-helper exited with 6
Nov 01 10:40:17 thomas-desktop sddm[1238]: Greeter stopped. SDDM::Auth::HelperExitStatus(6)
Garuda-inxi:
Kernel: 6.17.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=4f5c30b4-5bbf-407a-bba3-ffde8bfbebc5 rw rootflags=subvol=@
resume=UUID=894bfe7c-2c9b-4180-af69-5fe9a7b22a6a loglevel=3
nvidia-drm.modeset=1
Desktop: KDE Plasma v: 6.5.1 tk: Qt v: N/A info: frameworks v: 6.19.0
Type: Desktop System: Gigabyte product: X670 AORUS ELITE AX v: -CF
Mobo: Gigabyte model: X670 AORUS ELITE AX v: x.x
Megatrends LLC. v: F6a date: 10/06/2022
Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 4
model-id: 0x61 (97) stepping: 2 microcode: 0xA60120A
desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2989 min/max: 403/5576 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 2989 2: 2989 3: 2989
4: 2989 5: 2989 6: 2989 7: 2989 8: 2989 9: 2989 10: 2989 11: 2989 12: 2989
13: 2989 14: 2989 15: 2989 16: 2989 bogomips: 143733
Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: Gigabyte
driver: nvidia v: 580.95.05 alternate: nouveau,nvidia_drm
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: HDMI-A-1 empty: DP-1, DP-2, DP-3, HDMI-A-2 bus-ID: 01:00.0
chip-ID: 10de:2216 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Gigabyte
active: HDMI-A-3 empty: DP-4, DP-5, DP-6, Writeback-1 bus-ID: 15:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 34.0 C
gpu: amdgpu,nv_platform,nvidia,nvidia-nvswitch d-rect: 4480x1080
display-ID: 0
Monitor-1: HDMI-A-1 pos: primary,left model: Samsung S23B550
serial: <filter> built: 2012 res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 96 gamma: 1.2 size: 510x287mm (20.08x11.3") diag: 585mm (23")
Monitor-2: HDMI-A-3 pos: right model: LG (GoldStar) HDR WFHD
serial: <filter> built: 2019 res: mode: 2560x1080 hz: 75 scale: 100% (1)
dpi: 81 gamma: 1.2 size: 798x334mm (31.42x13.15") diag: 869mm (34.2")
modes: max: 2560x1080 min: 640x480
drv: kms_swrast surfaceless: drv: nvidia wayland: drv: nvidia x11:
drv: nvidia inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.95.05
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
memory: 9.77 GiB display-ID: :1.0
API: Vulkan v: 1.4.328 layers: 16 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3080 driver: nvidia v: 580.95.05
device-ID: 10de:2216 surfaces: N/A device: 1 type: integrated-gpu name: AMD
v: 25.2.6-arch1.1 device-ID: 1002:164e surfaces: N/A device: 2 type: cpu
name: llvmpipe (LLVM 21.1.4 256 bits) driver: mesa llvmpipe
v: 25.2.6-arch1.1 (LLVM 21.1.4) device-ID: 10005:0000 surfaces: N/A
Device-1: NVIDIA GA102 High Definition Audio vendor: Gigabyte
[Rembrandt/Strix] driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 15:00.1 chip-ID: 1002:1640 class-ID: 0403
lanes: 16 bus-ID: 15:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Kingston HyperX 7.1 Audio
lanes: 1 mode: 1.1 bus-ID: 9-1.2:4 chip-ID: 0951:16a4 class-ID: 0300
API: ALSA v: k6.17.6-zen1-1-zen status: kernel-api with: aoss
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0e:00.0
IF: enp14s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 0f:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp15s0 state: down mac: <filter>
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:3 chip-ID: 0e8d:0616
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.3 lmp-v: 12
Local Storage: total: 931.51 GiB used: 789.28 GiB (84.7%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 32.9 C
ID-1: / raw-size: 897.66 GiB size: 897.66 GiB (100.00%)
used: 789.28 GiB (87.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 664 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 897.66 GiB size: 897.66 GiB (100.00%)
ID-4: /var/log raw-size: 897.66 GiB size: 897.66 GiB (100.00%)
ID-5: /var/tmp raw-size: 897.66 GiB size: 897.66 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.49 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 33.56 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 44.0 C mobo: 32.0 C gpu: amdgpu temp: 34.0 C
Memory: total: 32 GiB note: est. available: 30.49 GiB used: 4.49 GiB (14.7%)
Processes: 395 Power: uptime: 19m states: freeze,mem,disk suspend: s2idle
image: 12.08 GiB services: org_kde_powerdevil,upowerd Init: systemd v: 258
Packages: pm: pacman pkgs: 2023 libs: 524 tools: octopi,paru Compilers:
clang: 21.1.4 gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish v: 4.1.2
Garuda (2.11.1-1):
System install date: 2022-10-18
Last full system update: 2025-11-01
Relevant software: snapper NetworkManager dracut nvidia-utils nvidia-open-dkms garuda-hardware-profile-nvidia garuda-hardware-profile-standard garuda-hardware-profile-standard-x11
24/25 checks run in 0.71 seconds ⌛
Powered by garuda-health 🦅
--- LOW ---
