Hi Community !
I installed Garuda a week ago and everything went fine until I did a full system update. I had anbox working out of the box when first installed, but after the upgrade It does not load the required kernel modules.
[ 2022-06-08 16:47:12] [session_manager.cpp:149@operator()] Failed to start as either binder or ashmem kernel drivers are not loaded
I tried looking on the Arch forums but acording to this post, zen kernels should include this modules by default and not as external modules. thanks for all the help. This is the output of my garduda-inxi command:
Kernel: 5.18.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=d76ebb87-d569-4e03-abaa-dc45790bf71d rw rootflags=subvol=@
Type: Laptop System: HP product: HP Notebook v: CNB1
Mobo: HP model: 81DF v: KBC Version 70.12 serial: <superuser required>
UEFI: Insyde v: F.15 date: 07/21/2016
ID-1: BAT0 charge: 0% condition: 41.6/41.6 Wh (100.0%) volts: 1.5 min: 14.6
model: Hewlett-Packard Primary type: Li-ion serial: <filter> status: N/A
Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1900 high: 1901 min/max: 500/1900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1901 2: 1900 3: 1900
4: 1900 bogomips: 15999
Type: l1tf
Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard driver: i915
v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:1616 class-ID: 0300
Device-2: Chicony HP Webcam type: USB driver: uvcvideo bus-ID: 1-1.5:3
chip-ID: 04f2:b52d class-ID: 0e02 serial: <filter>
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: BOE Display 0x0696 built: 2015 res: 1366x768
hz: 60 dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2)
v: 4.6 Mesa 22.1.1 direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c
chip-ID: 8086:9ca0 class-ID: 0403
Sound Server-1: ALSA v: k5.18.1-zen1-1-zen running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8136
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8723be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:b723
bus-ID: 1-1.6:4 chip-ID: 0bda:b008 class-ID: e001 serial: <filter>
Local Storage: total: 1.13 TiB used: 867.27 GiB (75.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1
type: SSD serial: <filter> rev: 052 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MQ01ABD100
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 4C scheme: GPT
ID-1: / raw-size: 206.16 GiB size: 206.16 GiB (100.00%)
used: 40.99 GiB (19.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 716 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 206.16 GiB size: 206.16 GiB (100.00%)
ID-4: /var/log raw-size: 206.16 GiB size: 206.16 GiB (100.00%)
ID-5: /var/tmp raw-size: 206.16 GiB size: 206.16 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.54 GiB used: 2.28 GiB (14.7%)
ID-2: swap-2 type: partition size: 17.11 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 60.0 C mobo: 0.0 C
Processes: 356 Uptime: 3h 12m wakeups: 6 Memory: 15.54 GiB
used: 8.91 GiB (57.3%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1970 lib: 409 Shell: fish
v: 3.4.1 running-in: konsole inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-05-24
Last full system update: 2022-06-08 ↻
