Hello Team,
this is my first post to this forum and i tried my best to avoid it but everything i found and tried failed so far. From the wiki to the forum entries and so on.
i was unable to post my full statement here with all i have tried because of forum-regulations. New users cannot post more than 5 links. The logs and system summary’s are full of links or what the system thinks is a link. So i will follow up with a second post to this one. Here are the system specs as required.
Output of: garuda-inxi:
Kernel: 6.6.3-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=4229126a-236f-4ce8-a461-0c7071445d9e rw rootflags=subvol=@
Desktop: Cinnamon v: 6.0.0 tk: GTK v: 3.24.38 info: plank wm: muffin vt: 7
dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: SAMSUNG product: 550P5C/550P7C v: P09ABI
Mobo: SAMSUNG model: NP550P5C-S0ADE v: SEC_SW_REVISION_1234567890ABCD
serial: <superuser required> UEFI: American Megatrends
v: P09ABI.026.141024.dg date: 10/24/2014
ID-1: BAT1 charge: 40.0 Wh (82.0%) condition: 48.8/48.8 Wh (100.0%)
volts: 11.8 min: 11.1 model: SAMSUNG Electronics SR Real Battery
type: Li-ion serial: <filter> status: not charging cycles: 1
Info: model: Intel Core i7-3630QM bits: 64 type: MT MCP arch: Ivy Bridge
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3337 high: 3400 min/max: 1200/3400 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3400 2: 3400 3: 3400
4: 3400 5: 3400 6: 3400 7: 3400 8: 2898 bogomips: 38334
Device-1: Intel 3rd Gen Core processor Graphics vendor: Samsung Co
driver: i915 v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
active: HDMI-A-1 off: LVDS-1 empty: DP-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0166 class-ID: 0300
Device-2: NVIDIA GK107M [GeForce GT 650M] vendor: Samsung Co driver: N/A
alternate: nouveau non-free: series: 470.xx+
status: legacy-active (EOL~2024-09-xx) arch: Kepler code: GKxxx
process: TSMC 28nm built: 2012-2018 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:0fd1 class-ID: 0300
Device-3: Silicon Motion WebCam SC-13HDL11939N driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.4:4
chip-ID: 2232:1029 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2 driver: X:
loaded: modesetting dri: crocus gpu: i915 display-ID: :0 screens: 1
s-diag: 583mm (22.95")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary model: Asus VP278
serial: <filter> built: 2017 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
Monitor-2: LVDS-1 note: disabled model: Seiko Epson 0x314b built: 2011
res: 1920x1080 dpi: 118 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1600x900
device: 1 drv: swrast surfaceless: drv: crocus x11: drv: crocus
inactive: gbm,wayland
API: OpenGL v: 4.5 compat-v: 4.2 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4000 (IVB
GT2) device-ID: 8086:0166 memory: 1.46 GiB unified: yes
vendor: Samsung Co 7 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: Focusrite-Novation Scarlett Solo (3rd Gen.)
driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 2-1.2.4:8 chip-ID: 1235:8211 class-ID: 0102 serial: <filter>
API: ALSA v: k6.6.3-arch1-1 status: kernel-api tools: N/A
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:2725
vendor: Samsung Co driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.5:3 chip-ID: 8087:0032
Local Storage: total: 715.41 GiB used: 487.57 GiB (68.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 PRO 512GB
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 830 Series
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 3B1Q scheme: MBR
used: 357.22 GiB (74.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 7.65 GiB used: 2.23 GiB (29.2%)
System Temperatures: cpu: 53.0 C mobo: N/A
Processes: 322 Uptime: 1h 51m wakeups: 0 Memory: total: 8 GiB
available: 7.65 GiB used: 3.14 GiB (41.0%) Init: systemd v: 254
Packages: pm: pacman pkgs: 2078 libs: 562 tools: pamac,paru,yay Shell: fish
v: 3.6.1 running-in: guake inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-11-27
Last full system update: 2023-12-02
Failed units: preload.service vncserver-x11-serviced.service
part 2:
