Hello! Garuda forums, I am new to garuda and am having trouble updating the system after a fresh install
Specs:
Kernel: 6.2.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Dell product: OptiPlex 3020 v: 00
v: A20 date: 05/27/2019
Info: model: Intel Core i5-4570 bits: 64 type: MCP arch: Haswell gen: core 4
level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
model-id: 0x3C (60) stepping: 3 microcode: 0x28
desc: 1x6 MiB
Speed (MHz): avg: 3396 high: 3600 min/max: 800/3600 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3600 2: 3600 3: 3193
4: 3193 bogomips: 25543
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
driver: nouveau v: kernel non-free: 525.xx+ status: current (as of 2023-02)
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-21 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: DVI-D-1,HDMI-A-1 empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:1c82
class-ID: 0300 temp: 28.0 C
compositor: kwin_x11 driver: X: loaded: nouveau unloaded: modesetting
alternate: fbdev,nv,vesa dri: nouveau gpu: nouveau display-ID: :0
s-diag: 1055mm (41.54")
Monitor-1: DVI-D-1 pos: left model: Asus VC239 serial: <filter>
built: 2018 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9 modes:
Monitor-2: HDMI-A-1 mapped: HDMI-1 pos: primary,right model: Acer KG242Y
serial: <filter> built: 2021 res: 1920x1080 hz: 75 dpi: 93 gamma: 1.2
API: OpenGL v: 4.3 Mesa 22.3.6 renderer: NV137 direct-render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: Dell
driver: snd_hda_intel bus-ID: 3-9:8 v: kernel bus-ID: 00:1b.0
chip-ID: 145f:0254 chip-ID: 8086:8c20 class-ID: 0300 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9
Device-3: Trust GXT 232 Microphone type: USB
Sound API: ALSA v: k6.2.7-zen1-1-zen running: yes
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: TP-Link TL-WN823N v2/v3 [Realtek RTL8192EU] type: USB
driver: rtl8xxxu bus-ID: 3-10:10 chip-ID: 2357:0109 class-ID: 0000
IF: wlp0s20u10 state: down mac: <filter>
Local Storage: total: 447.13 GiB used: 8.6 GiB (1.9%)
ID-1: /dev/sda maj-min: 8:0 model: SATA3 480GB SSD size: 447.13 GiB
serial: <filter> rev: 7B0 scheme: MBR
ID-1: / raw-size: 447.13 GiB size: 447.13 GiB (100.00%) used: 8.6 GiB (1.9%)
fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 447.13 GiB size: 447.13 GiB (100.00%)
used: 8.6 GiB (1.9%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-3: /var/log raw-size: 447.13 GiB size: 447.13 GiB (100.00%)
ID-4: /var/tmp raw-size: 447.13 GiB size: 447.13 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.58 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 32.0 C mobo: N/A gpu: nouveau temp: 28.0 C
Processes: 210 Uptime: 1h 0m wakeups: 0 Memory: 15.58 GiB
used: 2.52 GiB (16.2%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1780
libs: 512 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-04-17
Last full system update: 2023-04-17
Here is the konsole output log from running garuda-update
â•─officiallydragon@Garuda in ~ as đź§™ took 18ms
[đź”´] Ă— garuda-update
:: Synchronising package databases...
garuda is up to date
core is up to date
extra is up to date
community 7.2 MiB 3.16 MiB/s 00:02 [------------------------------------] 100%
multilib 161.3 KiB 849 KiB/s 00:00 [------------------------------------] 100%
chaotic-aur 2.4 MiB 1054 KiB/s 00:02 [------------------------------------] 100%
garuda downloading...
core downloading...
extra downloading...
community downloading...
multilib downloading...
chaotic-aur downloading...
warning: lock file missing /var/lib/pacman/db.lck
:: Replace ananicy-rules-git with chaotic-aur/ananicy-rules? [Y/n] y
resolving dependencies...
:: python-pyxdg and python-xdg are in conflict. Remove python-xdg? [y/N] y
warning: dependency cycle detected:
warning: libcamera-ipa will be installed before its libcamera dependency
Packages (457) accountsservice-23.13.9-1 adobe-source-code-pro-fonts-2.042u+1.062i+1.026vf-1
alacritty-0.12.0-1 alsa-card-profiles-1:0.3.69-2 ananicy-rules-1.r129.8ac5d97-1
ananicy-rules-git-2.2.1.r320.g62771a8-1 [removal] appstream-glib-0.8.2-2
at-spi2-core-2.48.0-2 attica-5.105.0-1 attr-2.5.1-3 baloo-5.105.0-1 bat-0.23.0-3
beautyline-1:20230402-1 bind-9.18.13-1 bison-3.8.2-5 bluedevil-1:5.27.4-1
bluez-qt-5.105.0-1 bottles-2:51.5-3 breeze-5.27.4-1 breeze-icons-5.105.0-1
btrfs-progs-6.2.2-1 candy-icons-git-r982.a017160-1 chaotic-mirrorlist-20230412-1
corectrl-1.3.5-1 coreutils-9.2-3 cryptsetup-2.6.1-3 curl-8.0.1-1 cython-0.29.34-1
device-mapper-2.03.20-1 discord-0.0.26-1 dmidecode-3.5-1 downgrade-11.3.0-1
dxvk-mingw-git-2.1.r62.g990a7205-1 efibootmgr-18-2 efivar-38-3 exa-0.10.1-7
f2fs-tools-1.16.0-1 fastfetch-1.11.0-1 faudio-23.04-1 ffmpeg-2:6.0-4 firedragon-112.0-1
fish-3.6.1-1 flex-2.6.4-5 fluidsynth-2.3.2-1 frameworkintegration-5.105.0-1
fuse-common-3.14.1-1 fuse3-3.14.1-1 fwupd-1.8.14-1 fzf-0.39.0-1 game-devices-udev-0.21-1
garuda-common-settings-2.6.16-1 garuda-hooks-2.10.1-1 garuda-migrations-2.3.1-1 gdbm-1.23-2
geoip-database-20230414-1 gettext-0.21.1-5 ghostscript-10.01.1-1 glib2-2.76.1-1
glslang-12.1.0-1 gobject-introspection-runtime-1.76.1-1 gpgme-1.19.0-3 grep-3.10-1
grub-2:2.06.r499.ge67a551a4-1 gsettings-desktop-schemas-44.0-1
gst-plugin-pipewire-1:0.3.69-2 gtk-update-icon-cache-1:4.10.1-2 gtk2-2.24.33-3
gtk4-1:4.10.1-2 gupnp-igd-1.6.0-1 gvim-9.0.1420-1 heroic-games-launcher-bin-2.7.0-1
hwdata-0.369-1 iana-etc-20230405-1 imagemagick-7.1.1.7-1 inotify-tools-3.22.6.0-2
inxi-3.3.26.1-1 kactivities-5.105.0-1 kactivities-stats-5.105.0-1
kactivitymanagerd-5.27.4-1 karchive-5.105.0-1 kauth-5.105.0-1 kbookmarks-5.105.0-1
kcalendarcore-5.105.0-1 kcmutils-5.105.0-1 kcodecs-5.105.0-1 kcompletion-5.105.0-1
kconfig-5.105.0-1 kconfigwidgets-5.105.0-1 kcontacts-1:5.105.0-1 kcoreaddons-5.105.0-1
kcrash-5.105.0-1 kdbusaddons-5.105.0-1 kde-cli-tools-5.27.4-1 kde-gtk-config-5.27.4-1
kdeclarative-5.105.0-1 kdecoration-5.27.4-1 kded-5.105.0-1 kdelibs4support-5.105.0-1
kdeplasma-addons-5.27.4-1 kdesu-5.105.0-1 kdnssd-5.105.0-1 kemoticons-5.105.0-1
kfilemetadata-5.105.0-1 kglobalaccel-5.105.0-1 kguiaddons-5.105.0-1 kholidays-1:5.105.0-1
khotkeys-5.27.4-1 ki18n-5.105.0-1 kiconthemes-5.105.0-1 kidletime-5.105.0-1
kimageformats-5.105.0-1 kinfocenter-5.27.4-1 kinit-5.105.0-1 kio-5.105.0-1
kirigami2-5.105.0-1 kitemmodels-5.105.0-1 kitemviews-5.105.0-1 kjobwidgets-5.105.0-1
kjs-5.105.0-1 kmenuedit-5.27.4-1 knewstuff-5.105.0-1 knotifications-5.105.0-1
knotifyconfig-5.105.0-1 kpackage-5.105.0-1 kparts-5.105.0-1 kpeople-5.105.0-1
kpipewire-5.27.4-1 kplotting-5.105.0-1 kpty-5.105.0-1 kquickcharts-5.105.0-1
krunner-5.105.0-1 kscreen-5.27.4-1 kscreenlocker-5.27.4-1 kservice-5.105.0-1
ksshaskpass-5.27.4-1 ksystemstats-5.27.4-1 ktexteditor-5.105.0-1 ktextwidgets-5.105.0-1
kunitconversion-5.105.0-1 kvantum-1.0.10-1 kwallet-5.105.0-1 kwallet-pam-5.27.4-1
kwayland-5.105.0-1 kwayland-integration-5.27.4-1 kwidgetsaddons-5.105.0-1 kwin-5.27.4.1-1
kwindowsystem-5.105.0-1 kxmlgui-5.105.0-1 layer-shell-qt-5.27.4-1 ldb-2:2.7.2-1
lib32-alsa-oss-1.1.8-4 lib32-alsa-plugins-1.2.7.1-2 lib32-at-spi2-core-2.48.0-2
lib32-curl-8.0.1-1 lib32-fluidsynth-2.3.2-1 lib32-glib-networking-2.76.0-1
lib32-glib2-2.76.1-1 lib32-gnutls-3.8.0-2 lib32-libcap-2.68-1 lib32-libcurl-compat-8.0.1-1
lib32-libcurl-gnutls-8.0.1-1 lib32-libelf-0.189-1 lib32-libgcrypt-1.10.2-1
lib32-libinstpatch-1.1.6-2 lib32-libpipewire-1:0.3.69-2 lib32-libusb-1.0.26-2
lib32-libva-mesa-driver-23.0.2-2 lib32-mangohud-0.6.9-1 lib32-mesa-23.0.2-2
lib32-mesa-vdpau-23.0.2-2 lib32-mpg123-1.31.3-1 lib32-openal-1.23.1-1
lib32-pipewire-1:0.3.69-2 lib32-pipewire-jack-1:0.3.69-2 lib32-portaudio-1:19.7.0-2
lib32-sdl2-2.26.5-1 lib32-systemd-253.3-1 lib32-vulkan-icd-loader-1.3.245-1
lib32-vulkan-intel-23.0.2-2 lib32-vulkan-mesa-layers-23.0.2-2 lib32-vulkan-radeon-23.0.2-2
lib32-wayland-1.22.0-1 lib32-xz-5.4.2-1 libadwaita-1:1.3.1-1 libaio-0.3.113-2
libassuan-2.5.5-2 libcamera-0.0.4-4 libcamera-ipa-0.0.4-4 libcap-2.68-1
libcurl-compat-8.0.1-1 libcurl-gnutls-8.0.1-1 libdecor-0.1.1-2 libelf-0.189-1
libgcrypt-1.10.2-1 libgirepository-1.76.1-1 libgit2-1:1.6.4-1 libgpg-error-1.47-1
libheif-1.15.2-1 libibus-1.5.28-3 libimagequant-4.1.1-1 libinput-1.23.0-1
libinstpatch-1.1.6-2 libisl-0.26-1 libjcat-0.1.13-2 libkate-0.4.1-9 libkscreen-5.27.4-1
libksysguard-5.27.4-1 libldap-2.6.4-2 libmfx-23.1.6-1 libnftnl-1.2.5-1 libnghttp2-1.52.0-2
libnice-0.1.21-2 libnsl-2.0.0-3 libopenmpt-0.6.10-1 libpaper-2.0.12-1
libpipewire-1:0.3.69-2 libplacebo-5.229.2-2 libraqm-0.10.1-1 libretro-beetle-pce-1175-1
libretro-beetle-pce-fast-1215-1 libretro-beetle-psx-2666-1 libretro-beetle-psx-hw-2666-1
libretro-beetle-supergrafx-978-1 libretro-bsnes-1:3083-1 libretro-core-info-1.15.0-1
libretro-flycast-5542-1 libretro-gambatte-994-1 libretro-genesis-plus-gx-2022-1
libretro-nestopia-1:107-1 libretro-overlays-242-1 libretro-picodrive-2293-1
libretro-play-7657-1 libretro-scummvm-140967-1 libretro-shaders-slang-1194-1
libretro-snes9x-2390-1 libsamplerate-0.2.2-2 libsynctex-2023.66539-1
libtraceevent-1:1.7.2-1 libtracefs-1.6.4-2 libupnp-1.14.16-1 libusb-1.0.26-2
libva-2.18.0-1 libva-mesa-driver-23.0.2-2 libva-utils-2.18.0-1 libvirt-1:9.2.0-1
libvirt-python-1:9.2.0-1 libwbclient-4.18.1-1 libxfixes-6.0.1-1 libxt-1.3.0-1
licenses-20220125-2 linux-zen-6.2.11.zen1-1 linux-zen-headers-6.2.11.zen1-1 lvm2-2.03.20-1
m4-1.4.19-3 man-pages-6.04-1 mangohud-0.6.9-1 mangohud-common-0.6.9-1
mariadb-libs-10.11.2-2 mercurial-6.4.1-1 mesa-23.0.2-2 mesa-demos-9.0.0-2
mesa-utils-9.0.0-2 mesa-vdpau-23.0.2-2 milou-5.27.4-1 modemmanager-qt-5.105.0-1
mpg123-1.31.3-1 mpv-1:0.35.1-4 mtools-1:4.0.43-1 mujs-1.3.3-1 multipath-tools-0.9.5-1
ndctl-76.1-1 network-manager-sstp-1.3.1-2 networkmanager-qt-5.105.0-1
networkmanager-vpnc-1.2.8-3 nextcloud-client-2:3.8.0-1 nftables-1:1.0.7-1
noto-fonts-20230401-1 npth-1.6-4 openal-1.23.1-1 openexr-3.1.7-1 openldap-2.6.4-2
openvpn-2.6.3-1 oxygen-sounds-5.27.4-1 pacman-contrib-1.9.0-1 pacman-mirrorlist-20230410-1
parted-3.6-1 pipewire-1:0.3.69-2 pipewire-alsa-1:0.3.69-2 pipewire-audio-1:0.3.69-2
pipewire-jack-1:0.3.69-2 pipewire-pulse-1:0.3.69-2 pipewire-v4l2-1:0.3.69-2
pipewire-x11-bell-1:0.3.69-2 pipewire-zeroconf-1:0.3.69-2 pkgconf-1.8.1-1
plasma-browser-integration-5.27.4-1 plasma-desktop-5.27.4-1 plasma-firewall-5.27.4-1
plasma-framework-5.105.0-1 plasma-integration-5.27.4-1 plasma-nm-5.27.4-1
plasma-pa-5.27.4-1 plasma-systemmonitor-5.27.4-1 plasma-thunderbolt-5.27.4-1
plasma-workspace-5.27.4.1-1 plymouth-git-22.02.122.r170.ge8e19371-2
polkit-kde-agent-5.27.4.1-1 portaudio-1:19.7.0-2 powerdevil-5.27.4.1-1 prison-5.105.0-1
proton-ge-custom-2:GE.Proton7.55-2 purpose-5.105.0-1 pyside2-5.15.9-1
python-fonttools-4.39.3-1 python-gobject-3.44.1-1 python-humanfriendly-10.0-4
python-markdown-3.4.3-1 python-matplotlib-3.7.1-3 python-more-itertools-9.1.1-1
python-orjson-3.8.10-1 python-platformdirs-3.2.0-1 python-pydantic-1.10.7-2
python-pyqt5-sip-12.12.0-1 python-setuptools-1:67.6.1-1 python-shiboken2-5.15.9-1
python-validate-pyproject-0.12.2-1 python-xdg-6.0.0-2 [removal] python-zope-interface-6.0-1
qemu-audio-alsa-7.2.1-1 qemu-audio-dbus-7.2.1-1 qemu-audio-jack-7.2.1-1
qemu-audio-oss-7.2.1-1 qemu-audio-pa-7.2.1-1 qemu-audio-sdl-7.2.1-1
qemu-audio-spice-7.2.1-1 qemu-block-curl-7.2.1-1 qemu-block-dmg-7.2.1-1
qemu-block-nfs-7.2.1-1 qemu-block-ssh-7.2.1-1 qemu-chardev-spice-7.2.1-1
qemu-common-7.2.1-1 qemu-desktop-7.2.1-1 qemu-hw-display-qxl-7.2.1-1
qemu-hw-display-virtio-gpu-7.2.1-1 qemu-hw-display-virtio-gpu-gl-7.2.1-1
qemu-hw-display-virtio-gpu-pci-7.2.1-1 qemu-hw-display-virtio-gpu-pci-gl-7.2.1-1
qemu-hw-display-virtio-vga-7.2.1-1 qemu-hw-display-virtio-vga-gl-7.2.1-1
qemu-hw-s390x-virtio-gpu-ccw-7.2.1-1 qemu-hw-usb-host-7.2.1-1 qemu-hw-usb-redirect-7.2.1-1
qemu-hw-usb-smartcard-7.2.1-1 qemu-img-7.2.1-1 qemu-pr-helper-7.2.1-1
qemu-system-x86-7.2.1-1 qemu-system-x86-firmware-7.2.1-1 qemu-tools-7.2.1-1
qemu-ui-curses-7.2.1-1 qemu-ui-dbus-7.2.1-1 qemu-ui-egl-headless-7.2.1-1
qemu-ui-gtk-7.2.1-1 qemu-ui-opengl-7.2.1-1 qemu-ui-sdl-7.2.1-1 qemu-ui-spice-app-7.2.1-1
qemu-ui-spice-core-7.2.1-1 qemu-vhost-user-gpu-7.2.1-1 qemu-virtiofsd-7.2.1-1
qgpgme-1.19.0-3 qqc2-desktop-style-5.105.0-1 qt5-base-5.15.9+kde+r151-1 qt5-charts-5.15.9-1
qt5-declarative-5.15.9+kde+r22-1 qt5-graphicaleffects-5.15.9-1
qt5-imageformats-5.15.9+kde+r9-1 qt5-location-5.15.9+kde+r4-1 qt5-multimedia-5.15.9+kde+r3-1
qt5-quickcontrols-5.15.9-1 qt5-quickcontrols2-5.15.9+kde+r5-1 qt5-sensors-5.15.9-1
qt5-speech-5.15.9+kde+r1-1 qt5-svg-5.15.9+kde+r7-1 qt5-tools-5.15.9+kde+r1-1
qt5-translations-5.15.9-1 qt5-wayland-5.15.9+kde+r55-1 qt5-webchannel-5.15.9+kde+r3-1
qt5-webengine-5.15.13-2 qt5-websockets-5.15.9+kde+r2-1 qt5-x11extras-5.15.9-1
qt5-xmlpatterns-5.15.9-1 qt6-5compat-6.5.0-1 qt6-base-6.5.0-3 qt6-declarative-6.5.0-2
qt6-imageformats-6.5.0-1 qt6-svg-6.5.0-1 qt6-translations-6.5.0-1 qt6-wayland-6.5.0-2
qtermwidget-1.3.0-1 reshade-shaders-git-r21.7c48ddc-1 retroarch-1.15.0-1
retroarch-assets-glui-1:446-1 retroarch-assets-ozone-1:446-1 retroarch-assets-xmb-1:446-1
retroarch-autoconfig-udev-git-r2128.f2123bb-1 rsync-3.2.7-4 rubberband-3.2.1-1 scrcpy-2.0-1
sddm-kcm-5.27.4.1-1 sdl2-2.26.5-1 shaderc-2023.3-1 smbclient-4.18.1-1 solid-5.105.0-1
sonnet-5.105.0-1 sqlite-3.41.2-1 starship-1.14.2-1 sweet-theme-full-git-r312.e19223f-1
syndication-5.105.0-1 syntax-highlighting-5.105.0-1 systemd-253.3-3 systemd-libs-253.3-3
systemd-sysvcompat-253.3-3 systemsettings-5.27.4.1-1 telegram-desktop-4.7.1-2
texinfo-7.0.3-1 texlive-bin-2023.66539-1 threadweaver-5.105.0-1 thunderbird-102.10.0-1
timidity++-2.15.0-10 tracker3-3.5.0-1 tzdata-2023c-1 vim-runtime-9.0.1420-1 vlc-3.0.18-8
vte-common-0.72.1-1 vte3-0.72.1-1 vulkan-headers-1:1.3.246-1 vulkan-icd-loader-1.3.245-1
vulkan-intel-23.0.2-2 vulkan-mesa-layers-23.0.2-2 vulkan-radeon-23.0.2-2
vulkan-swrast-23.0.2-2 vulkan-tools-1.3.245-1 wayland-1.22.0-1 webkit2gtk-2.40.0-2
wine-staging-8.5-1 wolfssl-5.6.0-1 wpebackend-fdo-1.14.2-1
xdg-desktop-portal-kde-5.27.4.1-1 xf86-input-libinput-1.3.0-1 xf86-input-wacom-1.2.0-1
xfsprogs-6.2.0-1 xorg-server-21.1.8-1 xorg-server-common-21.1.8-1 xorg-xwayland-23.1.1-1
xorg-xwininfo-1.1.6-1 xz-5.4.2-1 zziplib-0.13.72-2 python-pyxdg-0.28-1
Total Download Size: 6.52 MiB
Total Installed Size: 6223.04 MiB
Net Upgrade Size: 143.05 MiB
:: Retrieving packages...
grep-3.10-1-x86_64 232.3 KiB 780 KiB/s 00:00 [------------------------------------] 100%
nftables-1:1.0.7-1-x86_64 395.4 KiB 984 KiB/s 00:00 [------------------------------------] 100%
qtermwidget-1.3.0-1-x86_64 216.9 KiB 935 KiB/s 00:00 [------------------------------------] 100%
btrfs-progs-6.2.2-1-x86_64 978.4 KiB 1623 KiB/s 00:01 [------------------------------------] 100%
python-orjson-3.8.10-1-x86_64 243.6 KiB 401 KiB/s 00:01 [------------------------------------] 100%
wayland-1.22.0-1-x86_64 137.7 KiB 976 KiB/s 00:00 [------------------------------------] 100%
libnftnl-1.2.5-1-x86_64 69.5 KiB 914 KiB/s 00:00 [------------------------------------] 100%
ananicy-rules-1.r129.8ac5d97-1-any 57.7 KiB 286 KiB/s 00:00 [------------------------------------] 100%
beautyline-1:20230402-1-any 4.2 MiB 1411 KiB/s 00:03 [------------------------------------] 100%
Total (9/9) 6.5 MiB 2040 KiB/s 00:03 [------------------------------------] 100%
(455/455) checking keys in keyring [------------------------------------] 100%
downloading required keys...
:: Import PGP key 493DE21C824E9541, "Chih-Hsuan Yen <yan12125@archlinux.org>"? [Y/n] y
(455/455) checking package integrity [------------------------------------] 100%
error: libnftnl: signature from "Sébastien Luttringer <seblu@seblu.net>" is marginal trust
:: File /var/cache/pacman/pkg/libnftnl-1.2.5-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] y
error: nftables: signature from "Sébastien Luttringer <seblu@seblu.net>" is marginal trust
:: File /var/cache/pacman/pkg/nftables-1:1.0.7-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package(PGP signature)).
error: ananicy-rules: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/ananicy-rules-1.r129.8ac5d97-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: wayland: signature from "Sébastien Luttringer <seblu@seblu.net>" is marginal trust
:: File /var/cache/pacman/pkg/wayland-1.22.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: grep: signature from "Sébastien Luttringer <seblu@seblu.net>" is marginal trust
:: File /var/cache/pacman/pkg/grep-3.10-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: btrfs-progs: signature from "Sébastien Luttringer <seblu@seblu.net>" is marginal trust
:: File /var/cache/pacman/pkg/btrfs-progs-6.2.2-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: beautyline: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/beautyline-1:20230402-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: bind: signature from "Sébastien Luttringer <seblu@seblu.net>" is marginal trust
:: File /var/cache/pacman/pkg/bind-9.18.13-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: bottles: signature from "Pedro Henrique Lara Campos <root@pedrohlc.com>" is unknown trust
:: File /var/cache/pacman/pkg/bottles-2:51.5-3-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: candy-icons-git: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/candy-icons-git-r982.a017160-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: chaotic-mirrorlist: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/chaotic-mirrorlist-20230412-1-any.pkg.tar.zst is corrupted (invalid or corruptedpackage (PGP signature)).
error: downgrade: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/downgrade-11.3.0-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: dxvk-mingw-git: signature from "Pedro Henrique Lara Campos <root@pedrohlc.com>" is unknown trust
:: File /var/cache/pacman/pkg/dxvk-mingw-git-2.1.r62.g990a7205-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: fastfetch: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/fastfetch-1.11.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package(PGP signature)).
error: firedragon: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/firedragon-112.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package(PGP signature)).
error: game-devices-udev: signature from "Pedro Henrique Lara Campos <root@pedrohlc.com>" is unknown trust
:: File /var/cache/pacman/pkg/game-devices-udev-0.21-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: garuda-hooks: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/garuda-hooks-2.10.1-1-any.pkg.tar.zst is corrupted (invalid or corrupted package(PGP signature)).
error: garuda-migrations: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/garuda-migrations-2.3.1-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: garuda-common-settings: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/garuda-common-settings-2.6.16-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: heroic-games-launcher-bin: signature from "Pedro Henrique Lara Campos <root@pedrohlc.com>" is unknown trust
:: File /var/cache/pacman/pkg/heroic-games-launcher-bin-2.7.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: mangohud-common: signature from "Pedro Henrique Lara Campos <root@pedrohlc.com>" is unknown trust
:: File /var/cache/pacman/pkg/mangohud-common-0.6.9-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lib32-mangohud: signature from "Pedro Henrique Lara Campos <root@pedrohlc.com>" is unknown trust
:: File /var/cache/pacman/pkg/lib32-mangohud-0.6.9-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: mangohud: signature from "Pedro Henrique Lara Campos <root@pedrohlc.com>" is unknown trust
:: File /var/cache/pacman/pkg/mangohud-0.6.9-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: plymouth-git: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/plymouth-git-22.02.122.r170.ge8e19371-2-x86_64.pkg.tar.zst is corrupted (invalidor corrupted package (PGP signature)).
error: proton-ge-custom: signature from "Pedro Henrique Lara Campos <root@pedrohlc.com>" is unknown trust
:: File /var/cache/pacman/pkg/proton-ge-custom-2:GE.Proton7.55-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: reshade-shaders-git: signature from "Pedro Henrique Lara Campos <root@pedrohlc.com>" is unknown trust
:: File /var/cache/pacman/pkg/reshade-shaders-git-r21.7c48ddc-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
y
error: retroarch-autoconfig-udev-git: signature from "Pedro Henrique Lara Campos <root@pedrohlc.com>" is unknown trust
:: File /var/cache/pacman/pkg/retroarch-autoconfig-udev-git-r2128.f2123bb-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: sweet-theme-full-git: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/sweet-theme-full-git-r312.e19223f-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package)
--> Some corrupt downloads were detected. Retrying...
Total Download Size: 627.57 MiB
sweet-theme-full-git-r312.e19223... 7.7 MiB 928 KiB/s 00:09 [------------------------------------] 100%
dxvk-mingw-git-2.1.r62.g990a7205... 7.5 MiB 906 KiB/s 00:09 [------------------------------------] 100%
beautyline-1:20230402-1-any 4.2 MiB 498 KiB/s 00:09 [------------------------------------] 100%
bind-9.18.13-1-x86_64 1972.8 KiB 629 KiB/s 00:03 [------------------------------------] 100%
candy-icons-git-r982.a017160-1-any 1635.7 KiB 449 KiB/s 00:04 [------------------------------------] 100%
plymouth-git-22.02.122.r170.ge8e... 1093.5 KiB 467 KiB/s 00:02 [------------------------------------] 100%
btrfs-progs-6.2.2-1-x86_64 978.4 KiB 812 KiB/s 00:01 [------------------------------------] 100%
lib32-mangohud-0.6.9-1-x86_64 774.3 KiB 376 KiB/s 00:02 [------------------------------------] 100%
mangohud-0.6.9-1-x86_64 719.2 KiB 376 KiB/s 00:02 [------------------------------------] 100%
bottles-2:51.5-3-x86_64 690.1 KiB 359 KiB/s 00:02 [------------------------------------] 100%
nftables-1:1.0.7-1-x86_64 395.4 KiB 644 KiB/s 00:01 [------------------------------------] 100%
grep-3.10-1-x86_64 232.3 KiB 543 KiB/s 00:00 [------------------------------------] 100%
fastfetch-1.11.0-1-x86_64 228.0 KiB 401 KiB/s 00:01 [------------------------------------] 100%
wayland-1.22.0-1-x86_64 137.7 KiB 478 KiB/s 00:00 [------------------------------------] 100%
retroarch-autoconfig-udev-git-r2... 87.3 KiB 254 KiB/s 00:00 [------------------------------------] 100%
libnftnl-1.2.5-1-x86_64 69.5 KiB 319 KiB/s 00:00 [------------------------------------] 100%
ananicy-rules-1.r129.8ac5d97-1-any 57.7 KiB 104 KiB/s 00:01 [------------------------------------] 100%
garuda-common-settings-2.6.16-1-any 54.5 KiB 155 KiB/s 00:00 [------------------------------------] 100%
downgrade-11.3.0-1-any 27.3 KiB 92.2 KiB/s 00:00 [------------------------------------] 100%
mangohud-common-0.6.9-1-x86_64 16.7 KiB 70.8 KiB/s 00:00 [------------------------------------] 100%
game-devices-udev-0.21-1-any 8.6 KiB 12.1 KiB/s 00:01 [------------------------------------] 100%
garuda-hooks-2.10.1-1-any 7.8 KiB 15.7 KiB/s 00:01 [------------------------------------] 100%
garuda-migrations-2.3.1-1-any 5.1 KiB 16.7 KiB/s 00:00 [------------------------------------] 100%
chaotic-mirrorlist-20230412-1-any 3.6 KiB 14.0 KiB/s 00:00 [------------------------------------] 100%
reshade-shaders-git-r21.7c48ddc-... 52.1 MiB 1050 KiB/s 00:51 [------------------------------------] 100%
firedragon-112.0-1-x86_64 76.9 MiB 859 KiB/s 01:32 [------------------------------------] 100%
heroic-games-launcher-bin-2.7.0-... 122.7 MiB 1207 KiB/s 01:44 [------------------------------------] 100%
proton-ge-custom-2:GE.Proton7.55... 347.4 MiB 2.25 MiB/s 02:35 [------------------------------------] 100%
Total (28/28) 627.6 MiB 4.06 MiB/s 02:35 [------------------------------------] 100%
