Failed to build NVIDIA DKMS module for kernel 6.4.0-rc1-1-git-00111-g47a2ee5d4a0b
Kernel: 6.3.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen nomodeset
root=UUID=19c1dfde-803d-40ae-9339-ace6d6ace1a6 rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: GNOME v: 44.2 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Desktop System: Dell product: Precision T1650 v: 01 serial: <filter>
Chassis: type: 6 serial: <filter>
Mobo: Dell model: 0X9M3X v: A01 serial: <filter> UEFI: Dell v: A28
date: 06/28/2018
Info: model: Intel Core i7-3770 socket: BGA1155 bits: 64 type: MT MCP
arch: Ivy Bridge gen: core 3 level: v2 built: 2012-15 process: Intel 22nm
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3624 high: 3900 min/max: 1600/3900 base/boost: 3400/3900
scaling: driver: intel_cpufreq governor: performance volts: 2.9 V
ext-clock: 100 MHz cores: 1: 3900 2: 3748 3: 3710 4: 3104 5: 3644 6: 3460
7: 3887 8: 3544 bogomips: 54275
Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: Dell
driver: nvidia v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0
chip-ID: 10de:2216 class-ID: 0300
Display: server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
compositor: gnome-shell driver: X: loaded: nvidia
display-ID: :1 screens: 1
s-diag: 583mm (22.95")
Monitor-1: DP-1 res: 1920x1080 hz: 60 dpi: 70
size: 698x392mm (27.48x15.43") diag: 801mm (31.52") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: NVIDIA GeForce RTX
3080/PCIe/SSE2 direct-render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell 7
Device-2: NVIDIA GA102 High Definition Audio vendor: Dell
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:1aef
API: ALSA v: k6.3.8-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.71 status: n/a (root, process) with:
Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e
v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
Device-2: Realtek RTL8812AU-VS 802.11a/b/g/n/ac 2T2R DB WLAN Adapter
driver: N/A type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 3-4:2 chip-ID: 0bda:881a class-ID: 0000 serial: <filter>
Local Storage: total: 931.51 GiB used: 606 GiB (65.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000VM002-1ET162
tech: HDD rpm: 5900 serial: <filter> fw-rev: SC12 scheme: GPT
used: 606 GiB (65.1%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
maj-min: 8:2
maj-min: 8:2
maj-min: 8:2
ID-1: swap-1 type: zram size: 7.71 GiB used: 266.5 MiB (3.4%)
System Temperatures: cpu: 50.0 C mobo: 27.0 C gpu: nvidia temp: 41 C
Fan Speeds (RPM): cpu: 1011 mobo: 0 gpu: nvidia fan: 30%
Processes: 299 Uptime: 32m wakeups: 0 Memory: available: 7.71 GiB
used: 4.48 GiB (58.1%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 alt: 12 clang: 15.0.7 Packages: 2438
pm: pacman pkgs: 2362 libs: 614 tools: gnome-software,octopi,pamac,paru
pm: rpm pkgs: 0 pm: flatpak pkgs: 76 Shell: garuda-inxi (sudo) default: Bash
v: 5.1.16 running-in: gnome-terminal inxi: 3.3.27
System install date: 2023-06-15
Last full system update: 2023-06-17
My update keeps failing on building NVIDIA DKMS module
here is my update screen:
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
blackarch downloading...
warning: reflector-simple: local (2.0-1.1) is newer than garuda (2.0-1)
there is nothing to do
--> A problem with the NVIDIA drivers has been detected
---> Building NVIDIA DKMS module for kernel 6.4.0-rc1-1-git-00111-g47a2ee5d4a0b
Module nvidia 535.54.03 is not installed for kernel 6.4.0-rc1-1-git-00111-g47a2ee5d4a0b (x86_64). Skipping...
Module nvidia 535.54.03 is not built for kernel 6.4.0-rc1-1-git-00111-g47a2ee5d4a0b (x86_64). Skipping...
Sign command: /usr/lib/modules/6.4.0-rc1-1-git-00111-g47a2ee5d4a0b/build/scripts/sign-file
Signing key: /var/lib/dkms/mok.key
Public certificate (MOK): /var/lib/dkms/mok.pub
Building module:
Cleaning build area...
'make' -j8 IGNORE_PREEMPT_RT_PRESENCE=1 NV_EXCLUDE_BUILD_MODULES='__EXCLUDE_MODULES' KERNEL_UNAME=6.4.0-rc1-1-git-00111-g47a2ee5d4a0b modules............................(bad exit status: 2)
Error! Bad return status for module build on kernel: 6.4.0-rc1-1-git-00111-g47a2ee5d4a0b (x86_64)
Consult /var/lib/dkms/nvidia/535.54.03/build/make.log for more information.
---> Failed to build NVIDIA DKMS module for kernel 6.4.0-rc1-1-git-00111-g47a2ee5d4a0b
---> Building NVIDIA DKMS module for kernel 6.4.0-rc6-next-20230616-1-next-git-10546-gf7efed9f38f8
Module nvidia 535.54.03 is not installed for kernel 6.4.0-rc6-next-20230616-1-next-git-10546-gf7efed9f38f8 (x86_64). Skipping...
Module nvidia 535.54.03 is not built for kernel 6.4.0-rc6-next-20230616-1-next-git-10546-gf7efed9f38f8 (x86_64). Skipping...
Sign command: /usr/lib/modules/6.4.0-rc6-next-20230616-1-next-git-10546-gf7efed9f38f8/build/scripts/sign-file
Building module:
'make' -j8 IGNORE_PREEMPT_RT_PRESENCE=1 NV_EXCLUDE_BUILD_MODULES='__EXCLUDE_MODULES' KERNEL_UNAME=6.4.0-rc6-next-20230616-1-next-git-10546-gf7efed9f38f8 modules...........(bad exit status: 2)
Error! Bad return status for module build on kernel: 6.4.0-rc6-next-20230616-1-next-git-10546-gf7efed9f38f8 (x86_64)
---> Failed to build NVIDIA DKMS module for kernel 6.4.0-rc6-next-20230616-1-next-git-10546-gf7efed9f38f8
