When booting into Garuda, I usually have to restart my computer 1 or 2 times for me to get to the login successfully. When the first or second boot fails, It freezes and shows
Booting 'Garuda Linux'
Loading Linux-zen ...
Loading initial ramdisk ...
error: start_image() returned 0x8000000000000005.
Failed to boot both default and fallback entries
Press any key to continue...
It does eventually boot successfully after the first or second boot. I should also mention that on my previous install of Garuda, the problem started around 3 months ago and gradually got worse, making it feel almost impossible to boot into Garuda. I am duel booting Windows 11 and have tried disconnecting my Windows drive and doing a reinstall of Garuda today and the problem still persists.
Here is my inxi, i appreciate any assistance I can get
Kernel: 6.5.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=5acfeb78-973a-45a3-8771-2998e219729a rw rootflags=subvol=@
Type: Desktop Mobo: MSI model: Z97 GAMING 5 (MS-7917) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.13
date: 02/16/2016
Info: model: Intel Core i7-4790K bits: 64 type: MT MCP arch: Haswell
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 4700 high: 4704 min/max: 800/4700 scaling:
driver: intel_cpufreq governor: performance cores: 1: 4704 2: 4701 3: 4700
4: 4700 5: 4701 6: 4700 7: 4700 8: 4700 bogomips: 64002
Device-1: NVIDIA GA106 [Geforce RTX 3050] vendor: Micro-Star MSI
driver: nvidia v: 535.104.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:2507 class-ID: 0300
Device-2: WaveRider USB Live camera driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:4
chip-ID: 0c46:64ab class-ID: 0102 serial: <filter>
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: DP-0 pos: primary res: 2560x1440 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
Monitor-2: None-1-1 size-res: N/A modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.104.05 renderer: NVIDIA GeForce RTX
3050/PCIe/SSE2 direct-render: Yes
Device-1: Intel 9 Series Family HD Audio vendor: Micro-Star MSI 9
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
Device-2: NVIDIA GA106 High Definition Audio vendor: Micro-Star MSI
Device-3: Corsair VOID ELITE Wireless Gaming Dongle
lanes: 1 mode: 1.1 bus-ID: 3-14:8 chip-ID: 1b1c:0a51 class-ID: 0300
Device-4: WaveRider USB Live camera driver: snd-usb-audio,uvcvideo
Device-5: Texas Instruments PCM2902 Audio Codec
lanes: 1 mode: 1.1 bus-ID: 3-6:5 chip-ID: 08bb:2902 class-ID: 0300
API: ALSA v: k6.5.2-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.79 status: active with: 1: pipewire-pulse
Device-1: Qualcomm Atheros Killer E220x Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 1969:e091 class-ID: 0200
Local Storage: total: 2.22 TiB used: 13.12 GiB (0.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
tech: SSD serial: <filter> fw-rev: ST17 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37960G
size: 894.25 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: Z1.3 scheme: GPT
model: WD10JMVW-11AJGS4 size: 931.48 GiB block-size: physical: 512 B
logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1015 scheme: MBR
ID-1: / raw-size: 893.96 GiB size: 893.96 GiB (100.00%)
used: 13.12 GiB (1.5%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 576 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 893.96 GiB size: 893.96 GiB (100.00%)
ID-4: /var/log raw-size: 893.96 GiB size: 893.96 GiB (100.00%)
ID-5: /var/tmp raw-size: 893.96 GiB size: 893.96 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.57 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 35.0 C mobo: N/A gpu: nvidia temp: 37 C
Processes: 253 Uptime: 13m wakeups: 0 Memory: total: 16 GiB
available: 15.57 GiB used: 3.3 GiB (21.2%) Init: systemd v: 254
pm: pacman pkgs: 1424 libs: 445 tools: octopi,pamac,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
System install date: 2023-09-10
Last full system update: 2023-09-10 ↻
