Facebook Messenger connectivity problem in Firedragon
Today I’m having big connectivity issues on Facebook website when looking at my inbox. I tried disabling blocking and that doesn’t help. It’s kind of half-working, initial messages load but AJAX requests to load more fail.
Meanwhile, in Vivaldi, it works perfectly fine.
Is there still some user-agent issue like before?
inxi
Kernel: 6.10.8-zen1-1.1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=51ef4a7a-fb89-43c3-a466-7318e0363e7e rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Laptop System: Acer product: Predator PH315-53 v: V2.04
Mobo: CML model: QX50_CMS v: V2.04 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 2.04
date: 08/20/2021
ID-1: BAT1 charge: 40.6 Wh (100.0%) condition: 40.6/58.8 Wh (69.1%)
volts: 16.4 min: 15.4 model: SMP AP18E7M type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xFC
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2447 high: 3500 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 2813 2: 800 3: 3257
4: 1573 5: 2695 6: 800 7: 3120 8: 3500 9: 2050 10: 3401 11: 2164 12: 3201
bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Acer Incorporated ALI
ports: active: none off: eDP-1 empty: HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 560.35.03
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: none off: HDMI-A-1 empty: DP-1
bus-ID: 01:00.0 chip-ID: 10de:1f15 class-ID: 0300
Device-3: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0408:a061
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
alternate: fbdev,intel,nv,vesa dri: iris gpu: i915,nvidia,nvidia-nvswitch
Monitor-1: HDMI-A-1 mapped: HDMI-1-0 note: disabled pos: primary
model: Samsung serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 40
gamma: 1.2 size: 1210x680mm (47.64x26.77") diag: 1168mm (46") ratio: 16:9
Monitor-2: eDP-1 note: disabled model: AU Optronics 0x82ed built: 2018
res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.1-arch1.1.1
device-ID: 8086:9bc4 memory: 7.54 GiB unified: yes
API: Vulkan v: 1.3.285 layers: 10 device: 0 type: integrated-gpu
name: Intel UHD Graphics (CML GT2) driver: mesa intel v: 24.2.1-arch1.1.1
device-ID: 8086:9bc4 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 2060 driver: nvidia v: 560.35.03
device-ID: 10de:1f15 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.1-arch1.1.1 (LLVM
Device-1: Intel Comet Lake PCH cAVS vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs,
snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Acer Incorporated ALI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Texas Instruments PCM2900B Audio CODEC
lanes: 1 mode: 1.1 bus-ID: 1-1.3:6 chip-ID: 08bb:29b0 class-ID: 0300
API: ALSA v: k6.10.8-zen1-1.1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks Dual Band
Wi-Fi 6 Killer AX1650i 160MHz 2x2 driver: iwlwifi v: kernel
Device-2: Realtek Killer E2600 GbE vendor: Acer Incorporated ALI
bus-ID: 08:00.0 chip-ID: 10ec:2600 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
Local Storage: total: 3.19 TiB used: 1.62 TiB (50.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBQNTY-512G-1014 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 11101100 temp: 77.8 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Western Digital
model: WD Blue SN570 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 234200WD temp: 41.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
tech: HDD rpm: 7200 serial: <filter> fw-rev: A3J0 scheme: GPT
ID-1: / raw-size: 1.73 TiB size: 1.73 TiB (100.00%) used: 553.65 GiB (31.2%)
fs: btrfs dev: /dev/nvme1n1p3 maj-min: 259:5
ID-2: /boot/efi raw-size: 625 MiB size: 623.7 MiB (99.80%)
used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-3: /home raw-size: 1.73 TiB size: 1.73 TiB (100.00%)
used: 553.65 GiB (31.2%) fs: btrfs dev: /dev/nvme1n1p3 maj-min: 259:5
ID-4: /var/log raw-size: 1.73 TiB size: 1.73 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.73 TiB size: 1.73 TiB (100.00%)
ID-1: swap-1 type: partition size: 11.72 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p2 maj-min: 259:4
ID-2: swap-2 type: zram size: 15.45 GiB used: 307 MiB (1.9%) priority: 100
System Temperatures: cpu: 59.0 C pch: 83.0 C mobo: N/A
Memory: total: 16 GiB available: 15.45 GiB used: 8.21 GiB (53.1%)
Processes: 397 Power: uptime: 2h 44m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.13 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1741 libs: 463 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 alt: 13 Shell: garuda-inxi default: fish v: 3.7.1
System install date:     2024-07-17
Last full system update: 2024-09-05
The issue persists, Facebook Message doesn’t work in FireDragon anymore.
Empty posts without new information are considered impolite in forums.
They give the impression that you want to push your request in front of others.
Just wait until it is your turn.
If you do not receive an answer, it may there is no one in the forum who has a solution to your problem.
I think it might be because people who use a secure browser to protect their personal information are not active on FB.
