Extremely Slow Mirrors
Hi,
I live in India and I found out that the mirrors are extremely slow. I get around 100 to 200 kbps and it takes forever to update. Does anyone know any countries with the fastest mirrors?
Use German mirrors, they are much faster in India.
sudo reflector --country Germany --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pacman.d/mirrorlist && cat /etc/pacman.d/mirrorlist && sudo pacman -Syu
Ok thanks! I will try !
You can also open the Garuda Welcome app, and change your mirror locations ... just in case you prefer not to use the terminal.
