External Monitors not Working at High Refresh Rate
A recent update seems to have largely broken my laptop’s ability to use an external monitor. While the monitor is detected and can be configured, the display does not function if the refresh rate is greater than 60 Hz. This doesn’t appear to be a hardware issue; the Windows install on the same laptop can drive the display at its intended 240 Hz.
While I found a few posts in the forums about monitors being broken or laggy, I couldn’t find anything that was specific to high-refresh rate displays.
Any ideas what might have caused the issue? I get the feeling I missed a change in how Hyprland and/or Wayland require external displays to be configured and this could just be a settings issue somewhere that I wouldn’t know to look.
Output of garuda-inxi
  Kernel: 6.10.6-AMD-znver3 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd-znver3
    root=UUID=9f662d8d-670c-4fc5-8ee9-dc07a83cba8a rw rootflags=subvol=@
  Desktop: Hyprland v: N/A with: waybar tools: avail: swayidle,swaylock
  Type: Laptop System: ASUSTeK product: ROG Strix G513QR_G513QR v: 1.0
  Mobo: ASUSTeK model: G513QR v: 1.0 serial: <filter>
    uuid: 3094f494-0bd5-0b4d-bfab-29f362ec6b68 UEFI: American Megatrends LLC.
    v: G513QR.331 date: 02/24/2023
  ID-1: BAT0 charge: 77.3 Wh (100.0%) condition: 77.3/90.0 Wh (85.9%)
    volts: 16.7 min: 15.9 model: AS3GWYF3KC GA50358 type: Li-ion
    serial: <filter> status: full
  Info: model: AMD Ryzen 9 5900HX with Radeon Graphics socket: FP6 bits: 64
    type: MT MCP arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
    microcode: 0xA50000B
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 4131 high: 4312 min/max: 400/4890 base/boost: 3300/4650
    scaling: driver: amd-pstate-epp governor: powersave volts: 1.2 V
    ext-clock: 100 MHz cores: 1: 4033 2: 4155 3: 4179 4: 3494 5: 4208 6: 4312
    7: 4110 8: 4297 9: 3842 10: 4242 11: 4228 12: 4263 13: 4178 14: 4160
    15: 4170 16: 4228 bogomips: 105433
  Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: ASUSTeK
    driver: nvidia v: 560.35.03 alternate: nvidia_drm non-free: 550.xx+
    status: current (as of 2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
    lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
    empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:249d class-ID: 0300
    link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1,eDP-1 empty: none
    bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 74.0 C
  Display: unspecified server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2
    compositor: Hyprland driver: X: loaded: amdgpu,nvidia
    gpu: amdgpu display-ID: :1
  Monitor-1: HDMI-A-1 model: ASUS XG17A serial: <filter> built: 2021
    res: 1920x1080 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
    diag: 438mm (17.3") ratio: 16:9 modes: max: 1920x1080 min: 720x400
  Monitor-2: eDP-1 model: BOE Display 0x0973 built: 2020 res: 2560x1440
    dpi: 189 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
  Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
    link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
    link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
  Device-5: SteelSeries ApS Arctis Nova Pro Wireless
    lanes: 1 mode: 1.1 bus-ID: 3-1.3.2:7 chip-ID: 1038:12e0 class-ID: 0300
  API: ALSA v: k6.10.6-AMD-znver3 status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.2.3 status: n/a (root, process) with:
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 13d3:3563
  Local Storage: total: 19.12 TiB used: 2.33 TiB (12.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU010TZ
    lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 32.9 C scheme: GPT
  SMART: yes health: PASSED on: 1y 91d 7h cycles: 2,101
    read-units: 66,501,334 [34.0 TB] written-units: 66,570,630 [34.0 TB]
  ID-2: /dev/sda maj-min: 8:0 vendor: Hitachi model: HUH721010ALE601
    size: 9.1 TiB block-size: physical: 4096 B logical: 512 B type: USB rev: 3.0
    spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 sata: 3.2 speed: 6.0 Gb/s tech: HDD
    rpm: 7200 serial: <filter> fw-rev: LHGL0003 temp: 42 C
  SMART: yes state: enabled health: PASSED on: 4y 247d 13h cycles: 95
    read: 1.51 PiB written: 1.51 PiB
  ID-3: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HUH721010ALE601
  SMART: yes state: enabled health: PASSED on: 4y 34d 13h cycles: 95
    read: 2.49 PiB written: 1.47 PiB
  ID-1: / raw-size: 81.06 GiB size: 81.06 GiB (100.00%)
    used: 68.43 GiB (84.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p7
    maj-min: 259:7
    used: 26.5 MiB (10.4%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1
  ID-3: /home raw-size: 81.06 GiB size: 81.06 GiB (100.00%)
    maj-min: 259:7
  ID-4: /var/log raw-size: 81.06 GiB size: 81.06 GiB (100.00%)
    maj-min: 259:7
  ID-5: /var/tmp raw-size: 81.06 GiB size: 81.06 GiB (100.00%)
    maj-min: 259:7
  ID-1: swap-1 type: zram size: 30.78 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 82.0 C mobo: 34.0 C gpu: amdgpu temp: 74.0 C
  Memory: total: 32 GiB note: est. available: 30.78 GiB
    used: 10.78 GiB (35.0%)
  Processes: 419 Power: uptime: 4h 26m states: freeze,mem,disk
    suspend, test_resume image: 12.23 GiB services: upowerd Init: systemd
    v: 256 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1827 libs: 530 tools: pacseek,paru Compilers:
    gcc: 14.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.32
    running-in: foot inxi: 3.3.35
  System install date:     2024-01-13
  Last full system update: 2024-09-05
  Windows dual boot:       Yes
Did you read Hyprland Wiki about Nvidia.
Also Hyprland Downloads | 240428 | Fixes | Nvidia
use arandr for monitor settings.
Yes, I’m aware of Hyprland’s wiki page on NVidia graphics cards and the fact that, officially, they’re not supported. I’d followed those steps when I first installed Garuda Linux around the start of the year, but I’ll go through them again in case anything has changed.
You also might want to downgrade the nvidia driver tell the next update ive heard nothing but issues with 560, and a bit with the 555. Not much else you can do though.
Personally when you get a working one i would add it to the pacman ignore list. An only update it as needed
Looks like something messed with my Hyprland configuration at some point as the required environment variables were missing from my hyprland.conf even though I’m certain I set those shortly after my initial install. I added the four environment variables, the cursor configuration, and the optional tweak to help with Firefox’s hardware acceleration.
After restarting, the display still wasn’t working at first. Changing the refresh rate to 60 brought it to life, then changing it back to its full refresh rate continued to work. I’d say resetting the refresh rate might be a useful troubleshooting step for others with this or similar problems in the future.
Thanks for pointing me in the right direction. Wouldn’t have thought to re-read and re-do the setup steps.
It’s nice this was solved easily. :slightly_smiling_face:
Nevertheless, I think nvidia may have nothing to do with it. Or you can keep it in your watch list, if something goes wrong with the refresh rate in the future.
It seems that both of your current outputs are connected to the AMD GPU, not to Nvidia.
Just pointing out what inxi report reports :stuck_out_tongue_winking_eye: .
