Hi all,
I'm really having trouble figuring this out. I'm using Garuda KDE on a laptop connected to two monitors via Thunderbolt. Sometimes when the monitors turn off and go into power-saving mode, I'm unable to get any screen (including the laptop's screen after disconnecting from Thunderbolt) to turn back on. I'm not using sleep mode at all (I turned that off).
The odd thing is, I can hear the "hardware disconnected" and "hardware connected" sound when I disconnect and reconnect Thunderbolt, even though all the screens are black. I can't even get the laptop screen to turn on after I disconnect it from Thunderbolt. The only way I can use my system is if I hold the power button on the laptop to force a shutdown.
I'm wondering if it's an issue with KDE (maybe Cinnamon would work better?). Or perhaps Thunderbolt just doesn't work very well with Garuda or Linux generally.
I really like Garuda a lot, so I'm praying this is a solvable issue.
I'm a dumb noob if you couldn't tell, but here is the output from "garuda-inxi":
Kernel: 6.2.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=9cf6ce54-9154-4a11-a235-61b09fc57d7e rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.2 tk: Qt v: 5.15.8 info: latte-dock
Type: Laptop System: LENOVO product: 20TD003KUS v: ThinkPad E15 Gen 2
serial: Chassis: type: 10 serial:
Mobo: LENOVO model: 20TD003KUS v: SDK0J40697 WIN
serial: UEFI: LENOVO v: R1EET45W(1.45 )
date: 10/27/2021
ID-1: BAT0 charge: 42.3 Wh (94.0%) condition: 45.0/45.0 Wh (100.1%)
volts: 12.1 min: 11.1 model: Sunwoda 5B10X025 type: Li-poly serial:
status: discharging cycles: 30
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
microcode: 0xA6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 2083 high: 2400 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 1103 2: 2400 3: 2400
4: 2400 5: 2400 6: 2400 7: 1166 8: 2400 bogomips: 38707
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Luxvisions Innotech Integrated Camera type: USB driver: uvcvideo
bus-ID: 2-8:2 chip-ID: 30c9:003a class-ID: fe01 serial:
Monitor-1: eDP-1 model: BOE Display 0x085e built: 2018 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct-render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
chip-ID: 8086:a0c8 class-ID: 0401
Sound API: ALSA v: k6.2.2-zen1-1-zen running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
IF: wlp0s20f3 state: up mac:
port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac:
bus-ID: 2-10:3 chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address:
Local Storage: total: 476.95 GiB used: 80.23 GiB (16.8%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung
model: MZVLQ256HAJD-00000 size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial:
rev: FXV7101Q temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
model: MZALQ256HAJD-000L1 size: 238.47 GiB block-size: physical: 512 B
rev: EL1QFXV7 temp: 29.9 C scheme: GPT
used: 80.23 GiB (33.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-1: swap-1 type: zram size: 15.33 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 48.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 0 fan-2: 0
Processes: 280 Uptime: 3m wakeups: 878 Memory: 15.33 GiB
used: 3.34 GiB (21.8%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1363
libs: 366 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-02-12
Last full system update: 2023-03-04
Hi,
I have the same issue on a similar Lenovo laptop. When the screen goes dark for power-saving, i can’t wake it up and am forced to do a hard-reset.
Any ideas ?
Kernel: 6.7.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=93c200b2-f7d6-44e0-b4da-8a779d0679f4 rw rootflags=subvol=@
resume=UUID=60c3e298-c385-4adf-8796-820ae4ebfa38 loglevel=3 ibt=off
v: 5.115.0 wm: kwin_wayland vt: 2 dm: SDDM Distro: Garuda base: Arch Linux
Type: Laptop System: LENOVO product: 21D4002TFR v: ThinkPad Z16 Gen 1
Mobo: LENOVO model: 21D4002TFR serial: <superuser required>
part-nu: LENOVO_MT_21D4_BU_Think_FM_ThinkPad Z16 Gen 1
uuid: <superuser required> UEFI: LENOVO v: N3GET64W (1.64 )
date: 11/01/2023
ID-1: BAT0 charge: 56.0 Wh (83.0%) condition: 67.5/72.2 Wh (93.6%)
power: 10.4 W volts: 16.9 min: 15.5 model: Celxpert 5B10W51888 type: Li-poly
serial: <filter> status: discharging cycles: 20
Info: model: AMD Ryzen 7 PRO 6850H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3+ gen: 4 level: v3 note: check built: 2022
process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x44 (68) stepping: 1
microcode: 0xA404102
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 960 high: 1398 min/max: 400/4785 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 1398 3: 1397
4: 400 5: 1397 6: 1397 7: 1397 8: 400 9: 1396 10: 1397 11: 1397 12: 400
13: 1397 14: 400 15: 400 16: 400 bogomips: 102217
Device-1: AMD Rembrandt [Radeon 680M] vendor: Lenovo driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,
DP-2, DP-3, DP-4, DP-5, DP-6, DP-7 bus-ID: e4:00.0 chip-ID: 1002:1681
class-ID: 0300 temp: 35.0 C
Device-2: Luxvisions Innotech Integrated RGB Camera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2
chip-ID: 30c9:0052 class-ID: fe01 serial: <filter>
Monitor-1: eDP-1 res: 1920x1200 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.1-arch1.1
rembrandt LLVM 16.0.6 DRM 3.57 6.7.5-zen1-1-zen) device-ID: 1002:1681
memory: 500 MiB unified: no display-ID: :0.0
API: Vulkan v: 1.3.276 layers: 7 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV REMBRANDT) driver: mesa radv v: 24.0.1-arch1.1
device-ID: 1002:1681 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.1-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
bus-ID: e4:00.1 chip-ID: 1002:1640 class-ID: 0403
snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: e4:00.5
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: e4:00.6
API: ALSA v: k6.7.5-zen1-1-zen status: kernel-api tools: N/A
Device-1: Qualcomm QCNFA765 Wireless Network Adapter vendor: Lenovo
driver: ath11k_pci v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 link-max:
gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 17cb:1103 class-ID: 0280
Device-1: USI driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 10ab:9309 class-ID: e001
rfk-block: hardware: no software: no address: <filter> bt-v: 5.3 lmp-v: 12
Local Storage: total: 476.94 GiB used: 61.45 GiB (12.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN810 SDCQNRY-512G-1001 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 61560101 temp: 31.9 C scheme: GPT
ID-1: / raw-size: 460.25 GiB size: 460.25 GiB (100.00%)
used: 61.42 GiB (13.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 34.7 MiB (11.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 460.25 GiB size: 460.25 GiB (100.00%)
ID-4: /var/log raw-size: 460.25 GiB size: 460.25 GiB (100.00%)
ID-5: /var/tmp raw-size: 460.25 GiB size: 460.25 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.39 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 14.89 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 37.0 C mobo: N/A gpu: amdgpu temp: 36.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 0
Memory: total: 16 GiB note: est. available: 14.89 GiB used: 4.55 GiB (30.5%)
Processes: 390 Power: uptime: 3m states: freeze,mem,disk suspend: s2idle
image: 5.94 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1364 libs: 387 tools: octopi,pamac,paru
Compilers: gcc: 13.2.1 Shell: garuda-inxi default: Zsh v: 5.9
Garuda (2.6.23-1):
System install date: 2023-07-15
Last full system update: 2024-02-21
Bro
21 February 2024 13:50
3
Switch from Wayland to X11 at boot.
Maybe try this . I had similar problem on Garuda KDE.
