External display not working on gnome de
external monitor getting detected but cant enable it
system info
  Kernel: 6.2.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=ab6520de-9098-4aca-aee7-e69deb536217 rw rootflags=subvol=@
    resume=UUID=9c97a42f-947d-4c19-95b9-eb34691343db loglevel=3 ibt=off
  Desktop: GNOME v: 43.4 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 43.0
  Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05
    serial: <superuser required> Chassis: type: 10 v: Lenovo Legion 5 15ARH05
  Mobo: LENOVO model: LNVNB161216 v: SDK0Q55722 WIN
    serial: <superuser required> UEFI: LENOVO v: EUCN37WW date: 04/14/2022
  ID-1: BAT0 charge: 29.7 Wh (56.9%) condition: 52.2/60.0 Wh (86.9%)
    volts: 15.3 min: 15.4 model: SMP L19M4PC0 type: Li-poly serial: <filter>
    status: discharging cycles: 292
  Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
    microcode: 0x8600106
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 1405 high: 1521 min/max: 1400/2900 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1521
    3: 1397 4: 1400 5: 1400 6: 1400 7: 1397 8: 1397 9: 1396 10: 1400 11: 1397
    12: 1397 13: 1397 14: 1397 15: 1397 16: 1397 bogomips: 92628
  Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo
    status: current (as of 2023-03) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
    link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:1f95 class-ID: 0300
  Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: eDP-1 empty: none bus-ID: 06:00.0
    chip-ID: 1002:1636 class-ID: 0300 temp: 48.0 C
  Device-3: Bison Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:3
    chip-ID: 5986:212b class-ID: 0e02
    compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa
    dri: radeonsi gpu: amdgpu display-ID: :1 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
    s-diag: 1055mm (41.55")
  Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x08e8 built: 2019
    res: 1920x1080 hz: 120 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
  API: OpenGL v: 4.6 Mesa 23.0.2 renderer: AMD Radeon Graphics (renoir LLVM
    15.0.7 DRM 3.49 6.2.11-zen1-1-zen) direct-render: Yes
  Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16
    snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s lanes: 16
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 06:00.6
  API: ALSA v: k6.2.11-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 0.3.69 status: active with: 1: pipewire-pulse
    port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
    speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:5
    chip-ID: 8087:0029 class-ID: e001
  Report: bt-adapter ID: hci0 rfk-id: 4 state: down
    address: <filter>
  Local Storage: total: 476.95 GiB used: 14.71 GiB (3.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: SK Hynix
    model: HFS256GD9TNI-L2A0B size: 238.47 GiB block-size: physical: 512 B
    rev: 11010C10 temp: 38.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Silicon Power
    model: SPCC M.2 PCIe SSD size: 238.47 GiB block-size: physical: 512 B
    rev: SVN2789 temp: 29.9 C scheme: GPT
  ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
    used: 14.71 GiB (6.4%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
    used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
  ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
  ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
  ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
  ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme1n1p3 maj-min: 259:3
  ID-2: swap-2 type: zram size: 7.13 GiB used: 2.7 MiB (0.0%) priority: 100
  System Temperatures: cpu: 48.8 C mobo: N/A gpu: amdgpu temp: 47.0 C
  Processes: 391 Uptime: 1h 15m wakeups: 10 Memory: 7.14 GiB
  used: 4.03 GiB (56.4%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1233
  libs: 372 tools: gnome-software,octopi,pamac,paru Shell: fish v: 3.6.1
  default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.26
  System install date:     2023-04-17
  Last full system update: 2023-04-17 ↻
  Is partially upgraded:   Yes
Please run:
garuda-update
Paste the full input/output into the thread.
Reboot, then test again. If it isn't working, explain what your method is for trying to enable it.
I woke up this morning and remembered that there was kernel parameter I changed on my last image but not this one. I got this from ArchWiki:
Blockquote
If you are an NVIDIA user with the proprietary nvidia driver, also enable DRM kernel mode setting.
I added nvidia-drm.modeset=1 to grub and now second screen works with wayland
Thanks for all the help
