Hello everyone,
I installed the extension peek top bar on fullscreen and disabled blur my shell but this extension doesn't work for me. Does somebody has any idea? Is there an alternative extension?
https://extensions.gnome.org/extension/6048/peek-top-bar-on-fullscreen/
Quote:
"This extension is incompatible with Blur My Shell extension."
So ask the extension developer to make it work. Maybe you have to remove it? Could it be another extension's fault?
Yes, I know that, that's why I deactivated blur my shell. And still peek top bar on full screen doesn't work.
If you disable all extensions except peek top bar--and reboot--does it then work? Let's see where the incompatibility lies.
And are you using ver. 43 or 44?
system
Closed
11 July 2023 18:15
5
