Hello.
I freshly installed Garuda-qtile edition, but after the update I am new facing this "expat" issue as its not letting me install some additional packages at all.
sudo rm /var/lib/pacman/db.lck
[sudo] password for raj:
rm: cannot remove '/var/lib/pacman/db.lck': No such file or directory
[email protected] in ~ as 🧙 took 4s
[🔴] × garuda-update
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur 1565.7 KiB 564 KiB/s 00:03 [---------------------------------------------------] 100%
--> Refreshing mirrorlists using rate-mirrors, please be patient..
core 133.1 KiB 314 KiB/s 00:00 [---------------------------------------------------] 100%
extra 1543.0 KiB 2.26 MiB/s 00:01 [---------------------------------------------------] 100%
community 6.1 MiB 4.18 MiB/s 00:01 [---------------------------------------------------] 100%
multilib 149.0 KiB 369 KiB/s 00:00 [---------------------------------------------------] 100%
chaotic-aur 1565.7 KiB 795 KiB/s 00:02 [---------------------------------------------------] 100%
--> Applying keyring updates before starting full system update..
error: duplicated database entry 'expat'
warning: archlinux-keyring-20220224-1 is up to date -- skipping
warning: chaotic-keyring-20220220-1 is up to date -- skipping
warning: garuda-hotfixes-1.1.1-1 is up to date -- skipping
there is nothing to do
spawn pacman -Su
resolving dependencies...
Packages (1) expat-2.4.6-1
Total Installed Size: 0.40 MiB
Net Upgrade Size: 0.01 MiB
(1/1) checking keys in keyring [---------------------------------------------------] 100%
(1/1) checking package integrity [---------------------------------------------------] 100%
(1/1) loading package files [---------------------------------------------------] 100%
(1/1) checking for file conflicts [---------------------------------------------------] 100%
expat: /usr/lib/cmake/expat-2.4.6/expat-config-version.cmake exists in filesystem
expat: /usr/lib/cmake/expat-2.4.6/expat-config.cmake exists in filesystem
expat: /usr/lib/cmake/expat-2.4.6/expat-none.cmake exists in filesystem
expat: /usr/lib/cmake/expat-2.4.6/expat.cmake exists in filesystem
expat: /usr/lib/libexpat.so.1.8.6 exists in filesystem
[email protected] in ~ as 🧙 took 2m3s
[🔴] × ls /var/lib/pacman/local/ | grep expat
drwxr-xr-x - root 31 Jan 21:24 expat-2.4.4-1
drwxr-xr-x - root 28 Feb 19:35 expat-2.4.6-1
drwxr-xr-x - root 28 Feb 19:36 lib32-expat-2.4.6-1
I have tried the method that is available in this link Errors ! shoud i worry about this erorrs
But nothing seems to be working.
I tried the below commands to remove the three entries of expat but it shows something like this.
sudo -Rcns expat lib32-expat
sudo: you are not permitted to use the -R option with expat
sudo purge expat lib32-expat
sudo: purge: command not found
Please tell me what to do now!!
