Hello!
I run the LXQt version of Garuda.
None of my microphones on my system are typically found or listed in Pulsaudio (pavucontrol-qt) unless I’ve done a system upgrade (I use octopi for this) in the same running session, after which all microphones are typically found by the system and work as intended. When I reboot, any connected microphones can no longer be found again.
Every time I do a system upgrade, my keyboard settings (under lxqt input settings, “Keyboard and Mouse Settings”) are also resetted. I want to use 2 keyboard layouts and switch between them by holding caps lock. After every system upgrade, the keyboard settings are reset to only one keyboard layout (my main one) and the secondary keyboard layout together with the setting to hold caps lock to activate it, is viped out. After which I have to manually set it again.
I want my microphones to be found by my system without having to force a system upgrad and I do not want to manually change my keyboard settings after each system upgrade.
As they both happen with system upgrades I suspect they couldb e caused by a single issue. Please excuse my ignorance if these two issues are unrelated and thus should have been issued as two separate issues.
Kernel: 6.5.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=b594f541-2664-43b4-b1ee-80ebd1a3a03b rw rootflags=subvol=@
Desktop: LXQt v: 1.3.0 tk: Qt v: 5.15.10 info: cairo-dock, lxqt-panel
wm: kwin_x11 vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Dell product: Latitude 7310 v: N/A
Mobo: Dell model: 0KD96W v: A00 serial: <superuser required> UEFI: Dell
v: 1.7.0 date: 05/27/2021
ID-1: BAT0 charge: 37.0 Wh (100.0%) condition: 37.0/51.0 Wh (72.5%)
volts: 8.4 min: 7.6 model: LGC-LGC6.843 DELL 4V5X209 type: Li-poly
serial: <filter> status: full
Info: model: Intel Core i5-10310U bits: 64 type: MT MCP
stepping: 0xC (12) microcode: 0xF8
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 600 high: 800 min/max: 400/4400 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 400 3: 400 4: 400
5: 800 6: 400 7: 800 8: 800 bogomips: 35199
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Dell Latitude 7310
ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 0000:00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 0bda:5539
Monitor-1: eDP-1 model: LG Display 0x05db built: 2018 res: 1920x1080
hz: 60 dpi: 166 gamma: 1.2 size: 294x165mm (11.57x6.5") diag: 337mm (13.3")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.8-arch1.1 renderer: Mesa Intel UHD Graphics
(CML GT2) direct-render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 0000:00:1f.3
chip-ID: 8086:02c8 class-ID: 0403
API: ALSA v: k6.5.4-zen2-1-zen status: kernel-api with: aoss
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:02f0 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5 chip-ID: 8087:0026
Hardware-1: Intel Comet Lake RAID Controller driver: intel_nvme_remap v: N/A
port: 3060 bus-ID: 0000:00:17.0 chip-ID: 8086:02d7 rev: class-ID: 0104
Local Storage: total: 238.47 GiB used: 34.09 GiB (14.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: BC511 NVMe 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B tech: SSD
serial: <filter> fw-rev: 11004101 temp: 36.9 C scheme: GPT
used: 34.08 GiB (14.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 592 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 15.3 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 51.0 C mobo: N/A
Processes: 294 Uptime: 8m wakeups: 386 Memory: total: 16 GiB note: est.
available: 15.3 GiB used: 3.98 GiB (26.0%) Init: systemd v: 254
pm: pacman pkgs: 1517 libs: 496 tools: octopi,paru Shell: Bash v: 5.1.16
running-in: qterminal inxi: 3.3.29
System install date: 2023-09-06
Last full system update: 2023-09-26
