I've recently changed over to a Ryzen 5 2400GE system and I decided to give it a try with Garuda. Videos (inc. H/W acc.) and native games work as expected, but whenever I play a game with Wine on any desktop, even if it's a simple 2D platformer like Darkula, I can hear the fan ramp up massively. I previously had a Core i5-8500T and that didn't make anywhere near the same amount of noise. Has anyone got any ideas why it might be doing that? I thought the Vega 11 graphics were supposed to be more powerful than the Intel UHD 630! If it's any help, I've tried other distros and desktops on the same machine and they also make the same loud noise, so it clearly isn't Garuda specific.
Thanks for any help.
System: Kernel: 5.15.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=95fc1d31-d21c-49d9-a029-0bffe4a18fe0 rw [email protected] quiet splash
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: LightDM 1.30.0, SDDM
Machine: Type: Desktop System: HP product: HP EliteDesk 705 G4 DM 35W v: DBXEnabled
serial: <filter> Chassis: type: 3 serial: <filter>
Mobo: HP model: 83E9 v: KBC Version 07.D1.00 serial: <filter> UEFI: HP
v: Q26 Ver. 02.16.00 date: 04/15/2021
CPU: Info: Quad Core model: AMD Ryzen 5 PRO 2400GE w/ Radeon Vega Graphics bits: 64
type: MT MCP arch: Zen family: 17 (23) model-id: 11 (17) stepping: 0 microcode: 8101016
cache: L2: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 51101
Speed: 3791 MHz min/max: 1600/3200 MHz boost: enabled Core speeds (MHz): 1: 3791
2: 3792 3: 1516 4: 2358 5: 2538 6: 2648 7: 2398 8: 1743
Graphics: Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 0a:00.0 chip-ID: 1002:15dd
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: amdgpu,ati
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
s-diag: 777mm (30.6")
Monitor-1: DisplayPort-3 res: 2560x1440 dpi: 93 size: 698x393mm (27.5x15.5")
diag: 801mm (31.5")
OpenGL:
renderer: AMD Radeon Vega 11 Graphics (RAVEN DRM 3.42.0 5.15.2-zen1-1-zen LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Audio: Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 0a:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 0a:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: XMOS iFi (by AMR) HD USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 2-3:2 chip-ID: 20b1:3008
Sound Server-1: ALSA v: k5.15.2-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3300 bus-ID: 05:00.0
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel bus-ID: 06:00.0
Bluetooth: Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb v: 0.8
bus-ID: 2-10:4 chip-ID: 8087:0025 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter>
Drives: Local Storage: total: 267.72 GiB used: 73.1 GiB (27.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB256HAHQ-000H1
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
type: SSD serial: <filter> rev: EXD70H1Q temp: 46.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Cruzer Blade
size: 29.25 GiB block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: 1.00 scheme: MBR
Partition: ID-1: / raw-size: 117.2 GiB size: 117.2 GiB (100.00%) used: 46 GiB (39.2%) fs: btrfs
dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 61.1 MiB (63.7%) fs: vfat
ID-3: /home raw-size: 117.2 GiB size: 117.2 GiB (100.00%) used: 46 GiB (39.2%)
fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-4: /var/log raw-size: 117.2 GiB size: 117.2 GiB (100.00%) used: 46 GiB (39.2%)
ID-5: /var/tmp raw-size: 117.2 GiB size: 117.2 GiB (100.00%) used: 46 GiB (39.2%)
ID-1: swap-1 type: zram size: 14.64 GiB used: 1.8 MiB (0.0%) priority: 100
Sensors: System Temperatures: cpu: 30.0 C mobo: N/A gpu: amdgpu temp: 62.0 C
Info: Processes: 348 Uptime: 5m wakeups: 0 Memory: 14.64 GiB used: 2.76 GiB (18.9%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages:
pacman: 1621 lib: 449 flatpak: 0 Client: Unknown Client: garuda-assistant inxi: 3.3.08
