So I can’t seem to find an answer to my problem, most search results come up for wifi frustratingly. I had recently done a system update to get all my apps up to date, and upon doing a restart later on I noticed my ethernet connection was connected but had no traffic. I could use my wifi just fine still, just noting on the ethernet. So figuring I must had screwed something up somehow, and wanting to do a fresh install anyways, so I wiped and reload the os. The problem was fixed, ethernet was running just fine again. Did the normal fresh install updates, all looked fine. Shut down for a bit, came back and ethernet is dead again. So now I have no idea what the problem is. I can again still use wifi just fine, but I prefer a wired connect over it. Any insight would be helpful.
Hi!!
Please post your garuda-inxi like this :
Without it we won’t be able to help
And my first suggestion would be to try LTS kernel
Kernel: 6.5.7-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=8187ed13-adc7-40e0-93e6-28325d2e0438 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop System: Micro-Star product: MS-7B79 v: 3.0
Mobo: Micro-Star model: X470 GAMING PLUS MAX (MS-7B79) v: 3.0
serial: <superuser required> UEFI: American Megatrends LLC. v: H.G0
date: 07/27/2022
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3689 high: 4337 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4337 2: 3600
3: 3600 4: 3600 5: 3600 6: 3599 7: 3600 8: 3600 9: 3600 10: 4299 11: 3600
12: 3600 13: 3600 14: 3600 15: 3600 16: 3600 bogomips: 115191
vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: HDMI-A-1,HDMI-A-2 empty: DP-1,DP-2
bus-ID: 29:00.0 chip-ID: 1002:73df class-ID: 0300
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (19.96x11.22")
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: NEC LCD2490WUXi
serial: <filter> built: 2008 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2
size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes:
max: 1920x1200 min: 720x400
Monitor-2: HDMI-A-2 mapped: HDMI-A-1 pos: primary
model: LG (GoldStar) TV RVU serial: <filter> built: 2016 res: 1920x1080
hz: 60 dpi: 30 gamma: 1.2 size: 1600x900mm (62.99x35.43")
diag: 1836mm (72.3") ratio: 16:9 modes: max: 3840x2160 min: 720x400
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (navi22 LLVM
16.0.6 DRM 3.54 6.5.7-zen2-1-zen) device-ID: 1002:73df memory: 11.72 GiB
unified: no
API: Vulkan v: 1.3.264 layers: 7 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:73df surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 29:00.1 chip-ID: 1002:ab28
bus-ID: 2b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: DJ Audio USB driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2.1.3:8
chip-ID: 292b:f117 class-ID: 0300 serial: <filter>
API: ALSA v: k6.5.7-zen2-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.82 status: active with: 1: pipewire-pulse
vendor: Micro-Star MSI driver: r8168 v: 8.052.01-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 22:00.0
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 24:00.0 chip-ID: 8086:08b1 class-ID: 0280
IF: wlp36s0 state: up mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:3 chip-ID: 8087:07dc
rfk-block: hardware: no software: yes address: <filter> bt-v: 4.0 lmp-v: 6
Device-2: Broadcom BCM20702A0 Bluetooth 4.0 driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2.1.1:6
chip-ID: 0a5c:21e8 class-ID: fe01 serial: <filter>
Report: ID: hci1 rfk-id: 1 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter> bt-v: 4.1 lmp-v: 7
Local Storage: total: 2.77 TiB used: 615.18 GiB (21.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KLEVV model: CRAS C710 M.2 NVMe
SSD 1TB size: 953.87 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: U0204A0L
temp: 37.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: TeamGroup model: TM8FP6512G
lanes: 4 tech: SSD serial: <filter> fw-rev: 2.H.5.0 temp: 41.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS545050B9A300
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: C64G scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: HD103SI
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: N/A serial: <filter> fw-rev: 1118 scheme: MBR
ID-5: /dev/sdc maj-min: 8:32 vendor: Lexar model: USB Flash Drive
size: 7.47 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter> fw-rev: 1100
scheme: MBR
ID-1: / raw-size: 237.96 GiB size: 237.96 GiB (100.00%)
used: 47.67 GiB (20.0%) fs: btrfs dev: /dev/nvme1n1p5 maj-min: 259:8
used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p4 maj-min: 259:7
ID-3: /home raw-size: 237.96 GiB size: 237.96 GiB (100.00%)
ID-4: /var/log raw-size: 237.96 GiB size: 237.96 GiB (100.00%)
ID-5: /var/tmp raw-size: 237.96 GiB size: 237.96 GiB (100.00%)
System Temperatures: cpu: 44.0 C mobo: N/A gpu: amdgpu temp: 41.0 C
mem: 38.0 C
Processes: 380 Uptime: 1h 38m wakeups: 2 Memory: total: 16 GiB
available: 15.54 GiB used: 5.78 GiB (37.2%) Init: systemd v: 254
pm: pacman pkgs: 1510 libs: 469 tools: gnome-software,octopi,paru,yay
inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-10-16
Last full system update: 2023-10-17 ↻
Install the r8168-dkms or r8168 driver and then reboot.
Disable MAC Address Randomization and then reboot both your router & computer.
Try installing the linux-lts kernel and reboot into the lts kernel.
Try installing the r8168-lts driver with the lts kernel and reboot into the linux-lts kernel.
Disable IPv6 in Network Manager:
In the connection properties IPv6 tab ensure “IPv6 is required for this connection” is not selected (ignore). In the IPv4 tab select “IPv4 is required for this connection”. Conversely, if IPv6 is already disabled, then try re-enabling it.
So I tried both drivers, neither worked. As far as kernel hopping goes, I think I’d rather just go back with simpler distro. Garuda has a lot of features that I really like, but I’ve had nothing but problems with it from day one. Probably just going to go back to mint, only used it for email, chat, and youtube anyways. Thanks for trying, but I’m done banging my head against problems I don’t understand at all.
Can you check if this workaround works?
If it doesn’t then take a look at this. Just one minor detail they blacklist the r8169 module since that’s what they had been using before but since you are using the r8168 module please blacklist that instead. Apart from that everything remains same including the packages you download. (You both have exact same network card).
