Here it is:
Kernel: 6.17.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=26cbd1e8-a023-4a5a-9408-f76947a4c04f rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.5.1 tk: Qt v: N/A info: frameworks v: 6.19.0
Type: Desktop System: HP product: HP Z8 G4 Workstation v: SBKPF,DWKSBLF
Mobo: HP model: 81C7 v: 1.00 serial: <superuser required>
part-nu: 6B4K3UP#ABA uuid: <superuser required> UEFI: HP v: P60 v02.96
date: 06/05/2025
Info: model: Intel Xeon Gold 6234 bits: 64 type: MT MCP SMP
arch: Cascade Lake level: v4 note: check built: 2019 process: Intel 14nm
family: 6 model-id: 0x55 (85) stepping: 7 microcode: 0x5003901
Topology: cpus: 2x dies: 1 clusters: 8 cores: 8 threads: 16 tpc: 2
smt: enabled cache: L1: 2x 512 KiB (1024 KiB) desc: d-8x32 KiB; i-8x32 KiB
L2: 2x 8 MiB (16 MiB) desc: 8x1024 KiB L3: 2x 24.8 MiB (49.5 MiB)
desc: 1x24.8 MiB
Speed (MHz): avg: 1200 min/max: 1200/4000 scaling: driver: intel_pstate
governor: powersave cores: 1: 1200 2: 1200 3: 1200 4: 1200 5: 1200 6: 1200
7: 1200 8: 1200 9: 1200 10: 1200 11: 1200 12: 1200 13: 1200 14: 1200
15: 1200 16: 1200 17: 1200 18: 1200 19: 1200 20: 1200 21: 1200 22: 1200
23: 1200 24: 1200 25: 1200 26: 1200 27: 1200 28: 1200 29: 1200 30: 1200
31: 1200 32: 1200 bogomips: 211200
Device-1: NVIDIA GA104GL [RTX A4000] vendor: Hewlett-Packard driver: nvidia
v: 580.95.05 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-08; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: DP-5,DP-6
empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 2d:00.0 chip-ID: 10de:24b0
Device-2: Logitech BRIO Ultra HD Webcam
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.1
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-2:2 chip-ID: 046d:085e
compositor: kwin_wayland driver: gpu: nv_platform,nvidia,nvidia-nvswitch
d-rect: 5120x1440 display-ID: 0
Monitor-1: DP-5 pos: primary,left model: HP Z27q G3 serial: <filter>
built: 2022 res: mode: 2560x1440 hz: 60 scale: 100% (1) dpi: 109 gamma: 1.2
max: 2560x1440 min: 640x480
Monitor-2: DP-6 pos: right model: HP Z27q G3 serial: <filter> built: 2022
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.95.05
glx-v: 1.4 direct-render: yes renderer: NVIDIA RTX A4000/PCIe/SSE2
memory: 15.62 GiB display-ID: :0.0
API: Vulkan v: 1.4.328 layers: 7 device: 0 type: discrete-gpu
name: NVIDIA RTX A4000 driver: nvidia v: 580.95.05 device-ID: 10de:24b0
surfaces: N/A device: 1 type: cpu name: llvmpipe (LLVM 21.1.4 256 bits)
driver: mesa llvmpipe v: 25.2.6-arch1.1 (LLVM 21.1.4)
de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
Device-1: Intel C62x HD Audio vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a1f0 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 2d:00.1 chip-ID: 10de:228b
Device-3: Logitech BRIO Ultra HD Webcam
API: ALSA v: k6.17.6-zen1-1-zen status: kernel-api tools: N/A
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b9 class-ID: 0200
Device-2: Intel Ethernet X722 vendor: Hewlett-Packard driver: N/A pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0 chip-ID: 8086:37cc
Device-3: Intel Ethernet X722 for 1GbE vendor: Hewlett-Packard
driver: i40e v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A
bus-ID: 04:00.2 chip-ID: 8086:37d1 class-ID: 0200
IF: enp4s0f2np2 state: down mac: <filter>
Local Storage: total: 3.45 TiB used: 6.26 GiB (0.2%)
model: MZVL2512HCJQ-00BH1 size: 476.94 GiB block-size: physical: 512 B
fw-rev: HPS2NGXH temp: 38.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Samsung
model: MZVLB1T0HBLR-000H1 size: 953.87 GiB block-size: physical: 512 B
fw-rev: HPS0NEXF temp: 40.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
tech: HDD rpm: 7200 serial: <filter> fw-rev: VP02 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Kingston model: DataTraveler Max
size: 238.47 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
scheme: MBR
ID-1: / raw-size: 100.53 GiB size: 100.53 GiB (100.00%)
used: 6.23 GiB (6.2%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 200 MiB size: 196 MiB (98.00%)
used: 36.9 MiB (18.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 100.53 GiB size: 100.53 GiB (100.00%)
ID-4: /var/log raw-size: 100.53 GiB size: 100.53 GiB (100.00%)
ID-5: /var/tmp raw-size: 100.53 GiB size: 100.53 GiB (100.00%)
ID-1: swap-1 type: zram size: 62.59 GiB used: 0 KiB (0.0%) priority: 100
Src: lm-sensors+/sys Message: No sensor data found using /sys/class/hwmon
or lm-sensors.
Memory: total: 64 GiB available: 62.59 GiB used: 4.76 GiB (7.6%)
Processes: 555 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.97 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1177 libs: 308 tools: octopi,paru Compilers:
gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish v: 4.1.2 running-in: konsole
inxi: 3.3.39
Garuda (2.11.1-1):
System install date: 2026-01-15
Garuda release: 251103
Last full system update: 2026-01-15
Relevant software: snapper NetworkManager dracut nvidia-utils nvidia-open-dkms garuda-hardware-profile-nvidia garuda-hardware-profile-standard
24/25 checks run in 1.30 seconds ⌛
Powered by garuda-health 🦅
