Hello,
I don’t use my ethernet connection much, so I’ve noticed this problem just a few moments ago. I dual boot Windows, and on Windows everything is working as it should. On Garuda, the lights are on, but nothing is happening and in networkmanager Wired connection is grey. However, in inxi, I can see the device.
During updates, following warning shows:
> ==> WARNING: Possibly missing firmware for module: 'aic94xx'
> ==> WARNING: Possibly missing firmware for module: 'bfa'
> ==> WARNING: Possibly missing firmware for module: 'qed'
> ==> WARNING: Possibly missing firmware for module: 'qla1280'
> ==> WARNING: Possibly missing firmware for module: 'qla2xxx
> ==> WARNING: Possibly missing firmware for module: 'wd719x'
> ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
my ip a:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: wlo1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether xx:xx:xx:xx:xx:xx brd ff:ff:ff:ff:ff:ff
altname wlp61s0
inet 172.20.10.5/28 brd 172.20.10.15 scope global dynamic noprefixroute wlo1
valid_lft 86278sec preferred_lft 86278sec
inet6 fe80::45dd:d27d:ebd2:6a97/64 scope link noprefixroute
3: ztksey564h: <BROADCAST,MULTICAST> mtu 2800 qdisc fq_codel state DOWN group default qlen 1000
inet 10.11.12.121/24 brd 10.11.12.255 scope global ztksey564h
inxi:
Kernel: 6.6.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=21c7fde8-1bef-4f82-abc8-364dad2d6848 rw rootflags=subvol=@
resume=UUID=59131e58-a432-49f0-bae1-aebf3325230e loglevel=3 r8168.aspm=0
r8168.eee_enable=0 pcie_aspm=off ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 dm: SDDM
Type: Laptop System: HP product: OMEN by HP Laptop 15-dc1xxx v: N/A
Mobo: HP model: 8574 v: 21.17 serial: <filter> UEFI: AMI v: F.22
date: 05/03/2021
ID-1: BAT0 charge: 65.0 Wh (90.9%) condition: 71.5/71.5 Wh (100.0%)
volts: 17.6 min: 15.4 model: HP Primary type: Li-ion serial: N/A
status: charging
Info: model: Intel Core i7-9750H socket: BGA1440 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake gen: core 9 level: v3 note: check built: 2018
process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xD (13)
microcode: 0xFA
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 900 min/max: 800/4500 base/boost: 3960/8300 scaling:
driver: intel_pstate governor: powersave volts: 1.1 V ext-clock: 100 MHz
cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900 8: 900 9: 900
10: 900 11: 900 12: 900 bogomips: 62399
Device-1: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Hewlett-Packard
status: current (as of 2023-10; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f11 class-ID: 0300
Device-2: Lite-On HP Wide Vision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 04ca:707f
Display: server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3 compositors:
1: kwin_x11 2: Tabby driver: X: loaded: nvidia gpu: nvidia display-ID: :0
Screen-1: 0 s-res: 1920x1080 s-dpi: 143 s-size: 341x191mm (13.43x7.52")
s-diag: 391mm (15.39")
Monitor-1: Unknown-1 mapped: DP-2 res: 1920x1080 hz: 60 dpi: 142
size: 344x194mm (13.54x7.64") modes: 1920x1080
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
memory: 5.86 GiB
API: Vulkan v: 1.3.273 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 2060 driver: nvidia v: 545.29.06
device-ID: 10de:1f11 surfaces: xcb,xlib
Device-2: NVIDIA TU106 High Definition Audio vendor: Hewlett-Packard
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
API: ALSA v: k6.6.7-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: n/a (root, process) with:
vendor: Hewlett-Packard driver: N/A modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 3c:00.0 chip-ID: 10ec:8168
speed: 5 GT/s lanes: 1 bus-ID: 3d:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: ztksey564h state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:5 chip-ID: 8087:0029
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
v: 3.0 port: 5020 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.84 TiB used: 137.38 GiB (7.3%)
model: MZVLB1T0HBLR-000H1 size: 953.87 GiB block-size: physical: 512 B
fw-rev: HPS0NEXF temp: 43.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 13d 3h cycles: 1,791
read-units: 85,217,405 [43.6 TB] written-units: 85,016,741 [43.5 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
family: based SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 1B6Q temp: 33 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 128d 3h cycles: 1457
written: 6.56 TiB Pre-Fail: reallocated sector: 98 threshold: 10
ID-1: / raw-size: 896.9 GiB size: 896.9 GiB (100.00%)
used: 137.36 GiB (15.3%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
used: 26.9 MiB (10.5%) fs: vfat block-size: 512 B dev: /dev/sda1
maj-min: 8:1
ID-3: /home raw-size: 896.9 GiB size: 896.9 GiB (100.00%)
maj-min: 8:2
ID-4: /var/log raw-size: 896.9 GiB size: 896.9 GiB (100.00%)
maj-min: 8:2
ID-5: /var/tmp raw-size: 896.9 GiB size: 896.9 GiB (100.00%)
maj-min: 8:2
ID-1: swap-1 type: partition size: 34.36 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 31.22 GiB used: 7.2 MiB (0.0%) priority: 100
System Temperatures: cpu: 65.0 C pch: 56.0 C mobo: N/A gpu: nvidia
temp: 56 C
Fan Speeds (rpm): cpu: 2401 fan-2: 2180
Processes: 357 Uptime: 15m wakeups: 0 Memory: total: 32 GiB
available: 31.22 GiB used: 6.29 GiB (20.2%) Init: systemd v: 255
pm: pacman pkgs: 1941 libs: 544 tools: pamac,paru,yay
Shell: garuda-inxi (sudo) default: Bash v: 5.2.21 running-in: tabby
inxi: 3.3.31
Garuda (2.6.21-1):
System install date: 2021-07-24
Last full system update: 2023-12-18
Relevant software: timeshift tlp NetworkManager mkinitcpio nvidia-dkms
Windows dual boot: Yes
Any help would be greatly appreciated! Thanks in advance.
