Error when running reflector-simple using commandline. Happen on this reinstalled (full wipe) instance and old instance (wiped 10 mins before this post).
(yad:12003): Gtk-WARNING **: 21:15:16.911: Theme parsing error: gtk-dark.css:6342:10: 'height' is not a valid property name
** (yad:12003): WARNING **: 21:15:16.935: Unable to connect to dbus: Error spawning command line “dbus-launch --autolaunch=da2cc15bec544ef3bed5c58dc71105d1 --binary-syntax --close-stderr”: Child process exited with code 1
(yad:12003): GLib-GIO-CRITICAL **: 21:15:17.003: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
(yad:12003): GLib-GIO-CRITICAL **: 21:15:17.003: g_dbus_connection_get_unique_name: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
(yad:12154): Gtk-WARNING **: 21:15:27.103: Theme parsing error: gtk-dark.css:6342:10: 'height' is not a valid property name
** (yad:12154): WARNING **: 21:15:27.127: Unable to connect to dbus: Error spawning command line “dbus-launch --autolaunch=da2cc15bec544ef3bed5c58dc71105d1 --binary-syntax --close-stderr”: Child process exited with code 1
(yad:12154): GLib-GIO-CRITICAL **: 21:15:27.166: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
(yad:12154): GLib-GIO-CRITICAL **: 21:15:27.166: g_dbus_connection_get_unique_name: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
(yad:12154): Gtk-WARNING **: 21:17:45.390: Invalid markup string: Error on line 1 char 169: Odd character “t”,expected a “=” after attribute name “error” of element “urlopen”
(yad:12154): Gtk-WARNING **: 21:19:26.254: Invalid markup string: Error on line 1 char 162: Odd character “_”,expected a “=” after attribute name “error” of element “urlopen”
(yad:12154): Gtk-WARNING **: 21:24:35.300: Invalid markup string: Error on line 1 char 159: Odd character “_”,expected a “=” after attribute name “error” of element “urlopen”
(yad:12154): Gtk-WARNING **: 21:24:52.606: Invalid markup string: Error on line 1 char 156: Odd character “_”,expected a “=” after attribute name “error” of element “urlopen”
Inxi -Fza output:
System: Kernel: 5.12.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=c4959c79-ee87-4069-8621-bdad3f5a933a
rw rootflags=subvol=@ quiet
cryptdevice=UUID=2456a518-0d31-43f5-9f93-15b156366c3e:luks-2456a518-0d31-43f5-9f93-15b156366c3e
root=/dev/mapper/luks-2456a518-0d31-43f5-9f93-15b156366c3e splash rd.udev.log_priority=3
vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1
resume=/dev/mapper/luks-b0152c74-670e-4a67-a48d-2c51438efcfc loglevel=3
Desktop: KDE Plasma 5.22.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: LENOVO product: 81N7 v: Lenovo IdeaPad S340-14IWL serial: <filter>
Chassis: type: 10 v: Lenovo IdeaPad S340-14IWL serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0Q55756 WIN serial: <filter> UEFI: LENOVO
v: ALCN32WW(V2.09) date: 01/15/2021
Battery: ID-1: BAT1 charge: 47.1 Wh (97.7%) condition: 48.2/52.5 Wh (91.7%) volts: 12.7 min: 11.4
model: SMP L18M3PF7 type: Li-ion serial: <filter> status: Unknown cycles: 82
CPU: Info: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 8E (142) stepping: C (12) microcode: EA cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28800
Speed: 3209 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 3209 2: 3777 3: 3810 4: 3759
5: 3790 6: 3800 7: 3753 8: 2750
Graphics: Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX230] vendor: Lenovo driver: nvidia v: 465.31
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1d11 class-ID: 0302
Device-3: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-6:4 chip-ID: 5986:2115
class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: modesetting,nvidia
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9") diag: 355mm (14")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 21.1.2 direct render: Yes
Audio: Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:9dc8
Sound Server-1: ALSA v: k5.12.12-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Network: Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel port: 4000
bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8
bus-ID: 1-10:5 chip-ID: 8087:0aaa class-ID: e001
Drives: Local Storage: total: 1.17 TiB used: 19.52 GiB (1.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKKW256G8 size: 238.47 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
serial: <filter> rev: 005C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-24Z10 size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter>
rev: 1A04 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: USB 3.2Gen1 size: 28.65 GiB
block-size: physical: 512 B logical: 512 B serial: <filter> rev: 1.00 scheme: MBR
Partition: ID-1: / raw-size: 225.65 GiB size: 225.65 GiB (100.00%) used: 19.52 GiB (8.6%) fs: btrfs
dev: /dev/dm-0 maj-min: 254:0 mapped: luks-2456a518-0d31-43f5-9f93-15b156366c3e
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 706 KiB (0.3%) fs: vfat
ID-3: /home raw-size: 225.65 GiB size: 225.65 GiB (100.00%) used: 19.52 GiB (8.6%) fs: btrfs
ID-4: /var/log raw-size: 225.65 GiB size: 225.65 GiB (100.00%) used: 19.52 GiB (8.6%) fs: btrfs
ID-5: /var/tmp raw-size: 225.65 GiB size: 225.65 GiB (100.00%) used: 19.52 GiB (8.6%) fs: btrfs
ID-1: swap-1 type: partition size: 12.56 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-1
maj-min: 254:1 mapped: luks-b0152c74-670e-4a67-a48d-2c51438efcfc
ID-2: swap-2 type: zram size: 1.43 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 1.43 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 1.43 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 1.43 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-6: swap-6 type: zram size: 1.43 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-7: swap-7 type: zram size: 1.43 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-8: swap-8 type: zram size: 1.43 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-9: swap-9 type: zram size: 1.43 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
Sensors: System Temperatures: cpu: 56.0 C mobo: N/A
Info: Processes: 286 Uptime: 25m wakeups: 1 Memory: 11.42 GiB used: 4.6 GiB (40.3%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.0 Packages: pacman: 1662 lib: 504
Shell: fish v: 3.2.2 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.04
