While installing KDE dragonized from live USB calamares is not starting. In terminal it gives me this error.
calamares
calamares: error while loading shared libraries: libboost_python310.so.1.76.0: cannot open shared object file:
No such file or directory
ISO Name and version : garuda-dr460nized-linux-zen-211221.iso
This is a bug with calamares currently. Boost-libs just recently got an update.
My current solution is to either downgrade the package using downgrade or manually download the old package and place the .so file in the right place.
Calamares should not call the .so file directly and instead should use the symlinked .so file that automatically redirects to the latest .so file
A rebuild is in progress
Edit: done
system
Closed
4
