Not sure how to fix the following error, Package just won’t build:
Resolving dependencies…
Checking inter-conflicts…
Edit boost174 build files
Checking boost174-libs dependencies…
Warning: garuda-settings-manager: local (1.0.2-5) is newer than garuda (1.0.2-3)
Warning: garuda-settings-manager-kcm: local (1.0.2-5) is newer than garuda (1.0.2-3)
Building boost174…
==> ERROR: PKGBUILD does not exist.
Also providing inxi:
reggie@garudaK in ~
╰─λ garuda-inxi
Kernel: 6.6.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=d5f354c6-7622-48a6-bcef-bc670f2bd476 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
Type: Vmware System: VMware product: VMware Virtual Platform v: N/A
serial:  Chassis: No Enclosure type: 1
serial:
Mobo: Intel model: 440BX Desktop Reference Platform
serial:  BIOS: Phoenix v: 6.00 date: 11/12/2020
Info: model: 11th Gen Intel Core i9-11900H bits: 64 type: MCP SMP
microcode: 0x4E
Topology: cpus: 2x cores: 4 smt:  cache:
L1: 2x 320 KiB (640 KiB) desc: d-4x48 KiB; i-4x32 KiB L2: 2x 5 MiB (10 MiB)
desc: 4x1.2 MiB L3: 2x 24 MiB (48 MiB) desc: 1x24 MiB
Speed (MHz): avg: 2496 min/max: N/A cores: 1: 2496 2: 2496 3: 2496 4: 2496
5: 2496 6: 2496 7: 2496 8: 2496 bogomips: 39936
Device-1: VMware SVGA II Adapter driver: vmwgfx v: 2.20.0.0 ports:
active: Virtual-1 empty: Virtual-2, Virtual-3, Virtual-4, Virtual-5,
Virtual-6, Virtual-7, Virtual-8 bus-ID: 00:0f.0 chip-ID: 15ad:0405
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
compositor: kwin_x11 driver: X: loaded: vmware unloaded: modesetting
alternate: fbdev,vesa dri: vmwgfx gpu: vmwgfx display-ID: :0 screens: 1
Screen-1: 0 s-res: 1918x998 s-dpi: 96 s-size: 505x263mm (19.88x10.35")
s-diag: 569mm (22.42")
Monitor-1: Virtual-1 mapped: Virtual1 res: 1918x998 hz: 60 size: N/A
modes: max: 1918x998 min: 640x480
API: EGL v: 1.5 platforms: device: 0 egl: 1.4 drv: vmwgfx device: 1
drv: swrast gbm: egl: 1.4 drv: vmwgfx surfaceless: egl: 1.4 drv: vmwgfx x11:
egl: 1.4 drv: vmwgfx inactive: wayland
API: OpenGL v: 4.5 compat-v: 4.3 vendor: vmware mesa v: 23.3.2-arch1.2
glx-v: 1.4 direct-render: yes renderer: SVGA3D; build: RELEASE; LLVM;
device-ID: 15ad:0405 memory: 1000 KiB unified: no
Device-1: Ensoniq ES1371/ES1373 / Creative Labs CT2518 driver: snd_ens1371
v: kernel bus-ID: 02:02.0 chip-ID: 1274:1371 class-ID: 0401
API: ALSA v: k6.6.10-zen1-1-zen status: kernel-api tools: N/A
Device-1: Intel 82371AB/EB/MB PIIX4 ACPI vendor: VMware Virtual Machine
type: network bridge driver: N/A modules: i2c_piix4 port: N/A
bus-ID: 00:07.3 chip-ID: 8086:7113 class-ID: 0680
Device-2: Intel 82545EM Gigabit Ethernet vendor: VMware PRO/1000 MT
Single Port driver: e1000 v: kernel port: 2000 bus-ID: 02:01.0
chip-ID: 8086:100f class-ID: 0200
IF: ens33 state: up speed: 1000 Mbps duplex: full mac:
Device-1: VMware Virtual Bluetooth Adapter driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2.1:4
chip-ID: 0e0f:0008 class-ID: e001 serial:
Local Storage: total: 40 GiB used: 31.97 GiB (79.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: VMware model: Virtual S size: 40 GiB
block-size: physical: 512 B logical: 512 B tech: N/A serial: N/A fw-rev: 1.0
scheme: MBR
ID-1: / raw-size: 39.99 GiB size: 39.99 GiB (100.00%)
used: 31.97 GiB (79.9%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 39.99 GiB size: 39.99 GiB (100.00%)
ID-3: /var/log raw-size: 39.99 GiB size: 39.99 GiB (100.00%)
ID-4: /var/tmp raw-size: 39.99 GiB size: 39.99 GiB (100.00%)
ID-1: swap-1 type: zram size: 9.53 GiB used: 1.05 GiB (11.0%)
Src: lm-sensors+/sys Message: No sensor data found using /sys/class/hwmon
or lm-sensors.
Processes: 378 Uptime: 46m wakeups: 0 Memory: total: 9.88 GiB
available: 9.53 GiB used: 5.18 GiB (54.4%) Init: systemd v: 255
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1435
pm: pacman pkgs: 1417 libs: 371 tools: gnome-software,octopi,pamac,paru
pm: flatpak pkgs: 18 Shell: fish v: 3.7.0 running-in: konsole inxi: 3.3.31
Garuda (2.6.22-1):
System install date:     2023-11-10
Last full system update: 2024-01-11
Windows dual boot:
╭─reggie@garudaK in ~ took 8s
THis is an issue on multiple computers which run Garuda.
Also adding output from bauh:
git clone https://aur.archlinux.org/boost174.git --depth=1 /tmp/bauh@reggie/arch/build_1705004263/boost174
Cloning into ‘/tmp/bauh@reggie/arch/build_1705004263/boost174’…
Using custom makepkg.conf → /home/reggie/.config/bauh/arch/makepkg.conf
makepkg -ALcfm --check --noarchive --nobuild --noprepare --nodeps -p /tmp/bauh@reggie/arch/build_1705004263/boost174/PKGBUILD_CUSTOM --config=/home/reggie/.config/bauh/arch/makepkg.conf
/tmp/bauh@reggie/arch/build_1705004263/boost174/PKGBUILD_CUSTOM: line 5: boost174: command not found
/tmp/bauh@reggie/arch/build_1705004263/boost174/PKGBUILD_CUSTOM: line 6: boost174-libs: command not found
/tmp/bauh@reggie/arch/build_1705004263/boost174/PKGBUILD_CUSTOM: line 7: syntax error near unexpected token `)’
/tmp/bauh@reggie/arch/build_1705004263/boost174/PKGBUILD_CUSTOM: line 7: `)’
==> ERROR: Failed to source /tmp/bauh@reggie/arch/build_1705004263/boost174/PKGBUILD_CUSTOM
makepkg -ALcsmf --skipchecksums --nodeps -p /tmp/bauh@reggie/arch/build_1705004263/boost174/PKGBUILD_CUSTOM
rm -rf /tmp/bauh@reggie/arch/build_1705004263
Package “boost174-libs” upgrade failed
The operation logs can be found at “/tmp/bauh@reggie/logs/upgrade/upgrade_2024111_1705004263.log”
The upgrade summary can be found at “/tmp/bauh@reggie/logs/upgrade/upgrade_2024111_1705004263_summary.txt”
