Hello.
$ garuda-inxi
root=UUID=63b28f5b-c1b1-46b5-abd9-132176ab64c0 rw rootflags=subvol=@
Type: Server System: HP product: ProLiant DL380 G7 v: N/A
serial: <superuser required> Chassis: type: 23 serial: <superuser required>
Mobo: N/A model: N/A serial: N/A BIOS: HP v: P67 date: 08/16/2015
Info: model: Intel Xeon E5640 bits: 64 type: MT MCP SMP arch: Nehalem
family: 6 model-id: 0x2C (44) stepping: 2 microcode: 0x1F
Topology: cpus: 2x cores: 4 tpc: 2 threads: 8 smt: enabled cache:
L1: 2x 256 KiB (512 KiB) desc: d-4x32 KiB; i-4x32 KiB
L2: 2x 1024 KiB (2 MiB) desc: 4x256 KiB L3: 2x 12 MiB (24 MiB)
desc: 1x12 MiB
Speed (MHz): avg: 1581 high: 2602 min/max: 1600/2666 scaling:
driver: pcc-cpufreq governor: performance cores: 1: 0 2: 1870 3: 2384
4: 2019 5: 1644 6: 1600 7: 1615 8: 1880 9: 1615 10: 2602 11: 1668
12: 1600 13: 0 14: 1600 15: 1608 16: 1600 bogomips: 85311
Type: l1tf
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
Device-1: NVIDIA GK208B [GeForce GT 730] vendor: PNY driver: nvidia
v: 470.103.01 alternate: nouveau,nvidia_drm pcie: gen: 2 speed: 5 GT/s
lanes: 8 bus-ID: 11:00.0 chip-ID: 10de:1287 class-ID: 0300
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.02x10.71")
s-diag: 554mm (21.82")
Monitor-1: DVI-D-0 pos: primary res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.78x10.55") diag: 547mm (21.54") modes: N/A
Monitor-2: HDMI-0 pos: primary res: 1920x1080 size: N/A modes: N/A
OpenGL: renderer: NVIDIA GeForce GT 730/PCIe/SSE2
v: 4.6.0 NVIDIA 470.103.01 direct render: Yes
Device-1: NVIDIA GK208 HDMI/DP Audio vendor: PNY driver: snd_hda_intel
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8 bus-ID: 11:00.1
chip-ID: 10de:0e0f class-ID: 0403
Device-2: C-Media USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 4-1:2 chip-ID: 0d8c:0008
Device-1: Broadcom NetXtreme II BCM5709 Gigabit Ethernet
vendor: Hewlett-Packard NC382i Multi-port Server driver: bnx2 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 2 link-max: lanes: 4 port: N/A
bus-ID: 03:00.0 chip-ID: 14e4:1639 class-ID: 0200
IF: enp3s0f0 state: down mac: <filter>
Device-2: Broadcom NetXtreme II BCM5709 Gigabit Ethernet
bus-ID: 03:00.1 chip-ID: 14e4:1639 class-ID: 0200
IF: enp3s0f1 state: down mac: <filter>
Device-3: Broadcom NetXtreme II BCM5709 Gigabit Ethernet
bus-ID: 04:00.0 chip-ID: 14e4:1639 class-ID: 0200
IF: enp4s0f0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-4: Broadcom NetXtreme II BCM5709 Gigabit Ethernet
bus-ID: 04:00.1 chip-ID: 14e4:1639 class-ID: 0200
IF: enp4s0f1 state: down mac: <filter>
IF-ID-1: br-5780daa07fe3 state: down mac: <filter>
IF-ID-3: virbr0 state: down mac: <filter>
Hardware-1: Hewlett-Packard Smart Array G6 controllers driver: hpsa
v: 3.4.20-200 port: 4000 bus-ID: 05:00.0 chip-ID: 103c:323a rev: N/A
class-ID: 0104
Local Storage: total: 484.34 GiB used: 209.14 GiB (43.2%)
ID-1: /dev/sda maj-min: 8:0 model: LOGICAL VOLUME size: 37.24 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: N/A rev: 3.66
scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 model: LOGICAL VOLUME size: 447.1 GiB
scheme: MBR
ID-1: / raw-size: 447.1 GiB size: 447.1 GiB (100.00%)
used: 209.14 GiB (46.8%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-2: /home raw-size: 447.1 GiB size: 447.1 GiB (100.00%)
ID-3: /var/log raw-size: 447.1 GiB size: 447.1 GiB (100.00%)
ID-4: /var/tmp raw-size: 447.1 GiB size: 447.1 GiB (100.00%)
ID-1: swap-1 type: zram size: 23.51 GiB used: 5.5 MiB (0.0%)
System Temperatures: cpu: 8.3 C mobo: N/A gpu: nvidia temp: 48 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Processes: 359 Uptime: 2h 20m wakeups: 0 Memory: 23.51 GiB
used: 4.99 GiB (21.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1577 lib: 393 Shell: nu
running-in: yakuake inxi: 3.3.14
Garuda (2.5.6-2):
System install date: 2021-11-09
Last full system update: 2022-03-31
Windows dual boot: no
Snapshots: Timeshift (maybe)
Failed units: bluetooth-autoconnect.service grafana.service nebula.service zfs-auto-mount.service
Trying to build a virtual machine. Following the arch wiki, I:
$ sudo pacman -Syu libvirt qemu bridge-utils virt-viewer virt-manager --needed
$ sudo usermod -aG libvirt (id -u)
$ sudo systemctl enable libvirtd
$ sudo reboot
rebootedâŠ
$ sudo systemctl enable --now virtstoraged
$ sudo pacman -Syu iptables-nft dnsmasq dmidecode --needed
$ virsh net-list --all
$ virsh net-start default
$ sudo systemctl enable --now virtnetworkd
$ sudo virsh net-start default
$ sudo virsh net-autostart default
This is condensing running into a few errors and resolving them. Why did I need to manually enable virstoraged and virtnetworkd, when thatâs not mentioned in the Arch wiki? Shouldnât that get enabled with libvirtd? Is this something specific to Garuda?
Regardless, after running these commands, then starting virt-manager, walking through a typical install (resulting in this configuration), I click finish, and receive this error:
Unable to complete install: âUnable to read from â/sys/fs/cgroup/machine.slice/machine-qemu\x2d2\x2dnixos\x2dunstable.scope/libvirt/cgroup.controllersâ: No such file or directoryâ
details
