Kernel: 6.1.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=d5aae51d-ba0a-4bea-96f8-ee3641351dfd rw [email protected]
loglevel=3 ibt=off
Type: Desktop Mobo: ASUSTeK model: ROG MAXIMUS X HERO (WI-FI AC) v: Rev 1.xx
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: 2503
date: 09/25/2020
Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3975 high: 4803 min/max: 800/4800 scaling:
driver: intel_pstate governor: performance cores: 1: 3700 2: 3700 3: 3700
4: 3700 5: 3700 6: 4800 7: 3700 8: 3700 9: 4803 10: 4800 11: 3700 12: 3700
bogomips: 88796
Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: ASUSTeK driver: nvidia
v: 525.85.05 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1b80 class-ID: 0300
Device-2: Microsoft LifeCam Cinema type: USB driver: snd-usb-audio
bus-ID: 1-7:4 chip-ID: 045e:075d class-ID: 0102
compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 7680x2160 s-dpi: 159 s-size: 1227x352mm (48.31x13.86")
s-diag: 1276mm (50.26")
Monitor-1: DP-2 pos: right res: 3840x2160 hz: 60 dpi: 161
size: 607x345mm (23.9x13.58") diag: 698mm (27.49") modes: N/A
Monitor-2: HDMI-0 pos: primary,left res: 3840x2160 hz: 60 dpi: 160
size: 608x345mm (23.94x13.58") diag: 699mm (27.52") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.85.05 renderer: NVIDIA GeForce GTX
1080/PCIe/SSE2 direct render: Yes
driver: snd_hda_intel v: kernel bus-ID: 1-7:4 chip-ID: 045e:075d
bus-ID: 00:1f.3 class-ID: 0102 chip-ID: 8086:a2f0 class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-3: Microsoft LifeCam Cinema type: USB driver: snd-usb-audio
Sound API: ALSA v: k6.1.7-zen1-1-zen running: yes
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: ASUSTeK
driver: rtw_8822be v: N/A modules: rtw88_8822be pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 04:00.0 chip-ID: 10ec:b822 class-ID: 0280
Device-1: ASUSTek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-13:6 chip-ID: 0b05:185c class-ID: e001 serial: <filter>
Local Storage: total: 9.1 TiB used: 2.38 TiB (26.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO with
Heatsink 1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: 5B2QGXA7
temp: 31.9 C scheme: MBR
model: WD5000AAKS-00V1A0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 1D05
model: WD4004FZWX-00GBGB0 size: 3.64 TiB block-size: physical: 4096 B
rev: 0A81 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 500GB
type: SSD serial: <filter> rev: 3B6Q scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Seagate
model: Backup+ Hub BK size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: D781 scheme: GPT
used: 96.98 GiB (10.4%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 31.28 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 41.0 C mobo: N/A gpu: nvidia temp: 56 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 24%
Processes: 329 Uptime: 1h 17m wakeups: 0 Memory: 31.28 GiB
used: 5.49 GiB (17.6%) Init: systemd v: 252 default: graphical
pkgs: 0 tools: octopi,pamac,paru,pikaur,yaourt pm: rpm pkgs: 0 Shell: fish
v: 3.6.0 running-in: yakuake inxi: 3.3.24
error: mirror 'https://geo-mirror.chaotic.cx/$repo/$arch/' contains the '$arch' variable, but no 'Architecture' is defined.
Garuda ():
System install date: 2022-11-27
Last full system update: 2023-01-21
Relevant software: snapper NetworkManager
Failed units: packagekit.service
Not sure what happened here but all of a sudden today, garuda-update or any variant of sudo pacman -Sy, -Syy, -Syu I get this error, I've never seen before:
garuda-update
chaotic-aur 2.3 MiB 2.66 MiB/s 00:01 [############################################################] 100%
--> Refreshing mirrorlists using rate-mirrors, please be patient..
Failed to update mirrorlist
chaotic-aur downloading...
--> Applying keyring updates before starting full system update..
