When trying to build Python 2 binaries from source I got this error (I know Python 2 is revoked from official repositories but I need it for some tools that still require Python 2 dependencies)
garuda-inxi:
Kernel: 6.0.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=868d6417-5926-48d3-8b1a-565967682ed4 rw rootflags=subvol=@
Desktop: Cinnamon v: 5.4.12 tk: GTK v: 3.24.34 info: plank wm: Mutter
vt: 7 dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: X540YA v: 1.0
Mobo: ASUSTeK model: X540YA v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X540YA.320 date: 05/15/2018
ID-1: BAT0 charge: 26.1 Wh (99.2%) condition: 26.3/33.3 Wh (78.9%)
volts: 11.1 min: 11.1 model: ASUSTek X540-30 type: Li-ion serial: N/A
status: not charging cycles: 333
Info: model: AMD E2-6110 APU with AMD Radeon R2 Graphics bits: 64 type: MCP
arch: Puma level: v2 built: 2014-15 process: GF 28nm family: 0x16 (22)
model-id: 0x30 (48) stepping: 1 microcode: 0x7030106
desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 1x2 MiB
Speed (MHz): avg: 998 high: 1000 min/max: 1000/1500 boost: disabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 998 2: 1000
3: 998 4: 998 bogomips: 11977
Type: retbleed mitigation: untrained return thunk; SMT disabled
Device-1: AMD Mullins [Radeon R2 Graphics] vendor: ASUSTeK driver: radeon
v: kernel alternate: amdgpu arch: GCN-2 code: Sea Islands
process: GF/TSMC 16-28nm built: 2013-17 ports: active: eDP-1
empty: HDMI-A-1,VGA-1 bus-ID: 00:01.0 chip-ID: 1002:9852 class-ID: 0300
Device-2: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 2-1.2:4 chip-ID: 13d3:5a01 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: radeon
unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: radeon
s-diag: 414mm (16.31")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x15ca built: 2014
res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1366x768 min: 640x480
Device-1: AMD Kabini HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840 class-ID: 0403
Device-2: AMD FCH Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Sound API: ALSA v: k6.0.7-zen1-1-zen running: yes
Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Lite-On
driver: rtl8723be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 01:00.0 chip-ID: 10ec:b723 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
bus-ID: 2-1.1:3 chip-ID: 0bda:b721 class-ID: e001 serial: <filter>
Local Storage: total: 238.47 GiB used: 67.24 GiB (28.2%)
ID-1: /dev/sda maj-min: 8:0 model: SSD 256GB size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 0521 scheme: MBR
ID-1: / raw-size: 86.57 GiB size: 86.57 GiB (100.00%) used: 16.48 GiB
(19.0%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-2: /boot/efi raw-size: 50 MiB size: 50 MiB (99.99%) used: 29 MiB
(58.0%) fs: ntfs dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 86.57 GiB size: 86.57 GiB (100.00%) used: 16.48 GiB
ID-4: /var/log raw-size: 86.57 GiB size: 86.57 GiB (100.00%) used: 16.48
GiB (19.0%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-5: /var/tmp raw-size: 86.57 GiB size: 86.57 GiB (100.00%) used: 16.48
ID-1: swap-1 type: zram size: 3.26 GiB used: 2.47 GiB (75.9%)
System Temperatures: cpu: 60.4 C mobo: N/A gpu: radeon temp: 61.0 C
Fan Speeds (RPM): cpu: 2200
Processes: 299 Uptime: 1d 9h 2m wakeups: 2 Memory: 3.26 GiB used: 2.59 GiB
(79.6%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1339 libs: 326
tools: octopi,paru,yay Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: terminator inxi: 3.3.22
Garuda (2.6.9-1):
System install date: 2022-11-06
Last full system update: 2022-11-07
Is partially upgraded: Yes
The error I receive when I try to build Python 2 binaries from source:
Ran 54 tests in 3.793s
OK
== Tests result: FAILURE ==
371 tests OK.
1 test failed:
test_time
23 tests skipped:
test_aepack test_al test_applesingle test_bsddb185 test_cd test_cl
test_dl test_gl test_imageop test_imgfile test_kqueue
test_linuxaudiodev test_macos test_macostools test_msilib
test_ossaudiodev test_py3kwarn test_scriptpackages test_startfile
test_sunaudiodev test_winreg test_winsound test_zipfile64
Those skips are all expected on linux2.
Total duration: 29 min 50 sec
==> ERROR: A failure occurred in check().
Aborting...
-> error making: python2
