Error: target not found: plasma-workspace>=6.0.0
  Kernel: 6.7.6-arch1-2.1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
    avail: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux
    root=UUID=b6b92ddd-1165-4684-927f-b9ae66d45eff rw rootflags=subvol=@ quiet
    rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3 mitigations=off
    sysrq_always_enabled=1 elevator=noop ibt=off
  Desktop: GNOME v: 45.4 tk: GTK v: 3.24.41 wm: gnome-shell tools: gsd-screensaver-proxy dm: GDM
    v: 45.0.1 Distro: Garuda base: Arch Linux
  Type: Laptop System: ASUSTeK product: X540LA v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: X540LA v: 1.0 serial: <superuser required> part-nu: ASUS-NotebookSKU
    uuid: <superuser required> UEFI: American Megatrends v: X540LA.303 date: 08/31/2018
  ID-1: BAT0 charge: 22.6 Wh (95.8%) condition: 23.6/33.2 Wh (71.2%) volts: 10.8 min: 10.8
    model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: not charging cycles: 789
  Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell gen: core 5 level: v3
    note: check built: 2015-18 process: Intel 14nm family: 6 model-id: 0x3D (61) stepping: 4
    microcode: 0x2F
  Topology: cpus: 1x cores: 2 tpc: 2 threads: 4 smt: enabled cache: L1: 128 KiB
    desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1991 high: 1996 min/max: 500/1900 scaling: driver: intel_cpufreq
    governor: performance cores: 1: 1996 2: 1996 3: 1995 4: 1980 bogomips: 15968
  Device-1: Intel HD Graphics 5500 vendor: ASUSTeK driver: i915 v: kernel arch: Gen-8
    process: Intel 14nm built: 2014-15 ports: active: DP-1 off: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:1616 class-ID: 0300
  Device-2: IMC Networks USB2.0 VGA UVC WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4 chip-ID: 13d3:5a11 class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.4 compositor: gnome-shell
    driver: X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: 0
  Monitor-1: DP-1 model: Samsung SyncMaster serial: <filter> built: 2009 res: 1600x900 dpi: 92
    gamma: 1.2 size: 443x249mm (17.44x9.8") diag: 508mm (20") ratio: 16:9 modes: max: 1600x900
    min: 720x400
  Monitor-2: eDP-1 model: ChiMei InnoLux 0x15dc built: 2015 res: 1366x768 dpi: 101 gamma: 1.2
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9 modes: 1366x768
  API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris device: 1 drv: swrast
    surfaceless: drv: iris wayland: drv: iris x11: drv: iris inactive: gbm
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.2-arch1.1 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel HD Graphics 5500 (BDW GT2) device-ID: 8086:1616
    memory: 7.44 GiB unified: yes display-ID: :0.0
  Device-1: Intel Broadwell-U Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:03.0
    chip-ID: 8086:160c class-ID: 0403
  Device-2: Intel Wildcat Point-LP High Definition Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0 class-ID: 0403
  API: ALSA v: k6.7.6-arch1-2.1 status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse status: active
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK driver: r8169 v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 02:00.2 chip-ID: 10ec:8136
  IF: enp2s0f2 state: down mac: <filter>
  Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Lite-On driver: rtl8723be
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:b723
  Info: services: NetworkManager,
 systemd-timesyncd, wpa_supplicant
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 2.1 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 1-4:3 chip-ID: 0bda:b721 class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.0 lmp-v: 6 status:
    discoverable: no pairing: no class-ID: c010c
  Local Storage: total: 704.24 GiB used: 653.07 GiB (92.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T253256GB size: 238.47 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 227N
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD5000LPCX-80VHAT1 size: 465.76 GiB
    fw-rev: 1A02 scheme: GPT
  ID-1: / raw-size: 24.91 GiB size: 24.91 GiB (100.00%) used: 11.81 GiB (47.4%) fs: btrfs
    dev: /dev/sda1 maj-min: 8:1
  ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 584 KiB (0.1%) fs: vfat
    dev: /dev/sda4 maj-min: 8:4
  ID-3: /home raw-size: 9.8 GiB size: 9.8 GiB (100.00%) used: 4.68 GiB (47.8%) fs: btrfs
    dev: /dev/sda2 maj-min: 8:2
  ID-4: /var/log raw-size: 24.91 GiB size: 24.91 GiB (100.00%) used: 11.81 GiB (47.4%) fs: btrfs
  ID-5: /var/tmp raw-size: 24.91 GiB size: 24.91 GiB (100.00%) used: 11.81 GiB (47.4%) fs: btrfs
  Kernel: swappiness: 180 (default 60) cache-pressure: 50 (default 100) zswap: no
  ID-1: swap-1 type: zram size: 7.62 GiB used: 462.4 MiB (5.9%) priority: 100 comp: zstd
    avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 4 dev: /dev/zram0
  System Temperatures: cpu: 45.0 C pch: 39.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 2000
  Memory: total: 8 GiB available: 7.62 GiB used: 4.56 GiB (59.8%)
  Processes: 281 Power: uptime: 9h 31m states: freeze,mem,disk suspend: deep avail: s2idle
    wakeups: 1 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 3.04 GiB
    services: gsd-power, power-profiles-daemon, upowerd Init: systemd v: 255 default: graphical
  Packages: 1219 pm: pacman pkgs: 1208 libs: 312 tools: pamac,paru pm: flatpak pkgs: 11
    Compilers: gcc: 13.2.1 Client: shell wrapper v: 5.2.26-release inxi: 3.3.33
Garuda (2.6.23-1):
  System install date:     2023-11-27
  Last full system update: 2024-03-01 ↻
why am i having this error when updating ? i only have Gnome installed , i haven’t installed Plasma before .
update         ✔
[sudo] password for houssem:
 garuda is up to date
 core-x86-64-v3 is up to date
 extra-x86-64-v3 is up to date
 core is up to date
 extra                                                   8.3 MiB   484 KiB/s 00:18 [-----------------------------------------------] 100%
 chaotic-aur                                             2.5 MiB   134 KiB/s 00:19 [-----------------------------------------------] 100%
error: target not found: plasma-workspace>=6.0.0
 there is nothing to do
Any of these packages are installed?
fish❯ pactree -sr plasma-workspace
plasma-workspace
├─fancytasks
├─kcm-wacomtablet
├─kdeplasma-addons
│ └─plasma-meta
├─kf5-servicemenus-encfs
├─kget
│ └─kde-network-meta
│   └─kde-applications-meta
├─khotkeys
│ └─plasma-meta
├─plasma-browser-integration
│ ├─firedragon-extension-plasma-integration
│ ├─librewolf-extension-plasma-integration
│ └─plasma-meta
├─plasma-nm
│ ├─plasma-bigscreen
│ └─plasma-meta
├─plasma-pa
│ └─plasma-meta
├─plasma-pass
├─plasma-remotecontrollers
│ └─plasma-bigscreen
├─plasma-vault
│ └─plasma-meta
├─plasma-wayland-session
├─plasma5-applets-audio-device-switcher
├─plasma5-applets-betterinlineclock-git
│ └─garuda-dr460nized
├─plasma5-applets-bigsur-inlinebattery
├─plasma5-applets-control-centre
├─plasma5-applets-corner-menu
├─plasma5-applets-eventcalendar
├─plasma5-applets-fokus
├─plasma5-applets-latte-separator
├─plasma5-applets-netspeed
├─plasma5-applets-plasma-drawer
├─plasma5-applets-thermal-monitor
├─plasma5-applets-virtual-desktop-bar-git
├─plasma5-applets-weather-widget-2
├─plasma5-applets-window-appmenu
├─plasma5-applets-window-buttons
├─plasma5-applets-window-title
├─plasma5-wallpapers-blurredwallpaper
├─plasma6-applets-window-title
│ └─garuda-dr460nized-git
├─powerdevil
│ ├─plasma-desktop
│ │ ├─breeze-enhanced-git
│ │ ├─plasma-meta
│ │ ├─plasma5-theme-qogir-git
│ │ └─plasma5-themes-chromeos-git
│ └─plasma-meta
└─systemsettings
  ├─flatpak-kcm
  ├─kcm-colorful-git
  ├─kgamma
  │ └─plasma-meta
  ├─kinfocenter
  │ ├─plasma-disks
  │ │ └─plasma-meta
  │ └─plasma-meta
  ├─plasma-desktop
  ├─plasma-firewall
  │ └─plasma-meta
  ├─plasma-thunderbolt
  │ └─plasma-meta
  ├─plymouth-kcm
  └─sddm-kcm
    └─plasma-meta
is there a way to easily check that ?
Excluding all the “plasma” ones
fish❯ pactree -sr plasma-workspace |grep -v plasma
├─fancytasks
├─kcm-wacomtablet
├─kget
├─khotkeys
├─powerdevil
└─systemsettings
  ├─flatpak-kcm
  ├─kcm-colorful-git
  ├─kgamma
  ├─kinfocenter
  ├─plymouth-kcm
  └─sddm-kcm
then e.g. pacman -Q powerdevil
There is a helper script running with Garuda Update which is meant to detect if Plasma 6 is installed and apply some interventions if it is.
I think the error comes from this part here:
remove-chaotic-kf5-dummy() {
	# Hacky, fast way to check
	if package-exists-fast chaotic-kf5-dummy && $PACMAN -Sddp "plasma-workspace>=6.0.0" --print-format "%v"; then
		SNAP_PAC_SKIP=y $PACMAN -Rdd --noconfirm chaotic-kf5-dummy
	fi
Since you aren’t even using Plasma I wouldn’t worry about it, I think you should be fine to just ignore the error message.
Probably we should make an adjustment to the script so the error message is hidden, or at least make it clear to the user that no action is required. :eyes:
I understand , thank you guys.
