Error sparse file not allowed on boot right after grub
the issue im having is that right after the grub bootloader screen in the top left corner of my screen it says
"Error: sparse file not allowed.
Loading Linux linux-zen …
Loading initial ramdisk …
Press any key to continue …"
The system still boots fine after that so its really more of an anoyance then an issue but still something id like to fix
Thanks in advance
╰─λ garuda-inxi
Kernel: 6.13.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=98337a5e-7d41-441c-aa61-b054de8972e4 rw rootflags=subvol=@
quiet resume=UUID=1fbfecb0-5cf4-42d7-afcd-dcc3e9733c79 loglevel=3
amd_iommu=on iommu=pt video=efib:off ibt=off
Mobo: ASUSTeK model: TUF GAMING B550-PLUS WIFI II v: Rev X.0x
UEFI: American Megatrends v: 3610 date: 08/30/2024
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
desc: 12x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 1960 min/max: 550/5619 boost: disabled scaling:
driver: amd-pstate-epp governor: performance,powersave cores: 1: 1960
2: 1960 3: 1960 4: 1960 5: 1960 6: 1960 7: 1960 8: 1960 9: 1960 10: 1960
11: 1960 12: 1960 13: 1960 14: 1960 15: 1960 16: 1960 17: 1960 18: 1960
19: 1960 20: 1960 21: 1960 22: 1960 23: 1960 24: 1960 bogomips: 201609
Device-1: Intel DG2 [Arc A750] driver: i915 v: kernel alternate: xe
arch: Xe-HPG code: Alchemist process: TSMC n6 (7nm) built: 2022+ pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 ports: active: DP-1 empty: DP-2, DP-3,
DP-4, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 09:00.0 chip-ID: 8086:56a1
Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.5
Screen-1: 0 s-res: 3840x2160 s-dpi: 216 s-size: 451x254mm (17.76x10.00")
s-diag: 518mm (20.38")
Monitor-1: DP-1 model: Roku TV built: 2020 res: mode: 3840x2160 hz: 60
scale: 100% (1) dpi: 122 gamma: 1.2 size: 800x450mm (31.5x17.72")
diag: 1263mm (49.7") ratio: 16:9 modes: max: 3840x2160 min: 720x400
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc A750 Graphics (DG2)
device-ID: 8086:56a1 memory: 7.75 GiB unified: no
API: Vulkan v: 1.4.303 layers: 14 device: 0 type: discrete-gpu name: Intel
Arc A750 Graphics (DG2) driver: N/A device-ID: 8086:56a1
Device-1: Intel DG2 Audio driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 0a:00.0 chip-ID: 8086:4f90 class-ID: 0403
lanes: 16 bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4.3:3
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
Device-4: Texas Instruments PCM2902 Audio Codec
lanes: 1 mode: 1.1 bus-ID: 3-4.4.4.4:9 chip-ID: 08bb:2902 class-ID: 0300
API: ALSA v: k6.13.2-zen1-1-zen status: kernel-api with: aoss
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
lanes: 1 bus-ID: 05:00.0 chip-ID: 14c3:7961 class-ID: 0280
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
IF-ID-2: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 13d3:3563
Local Storage: total: 3.87 TiB used: 504.82 GiB (12.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: SB-RKT4P-2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: R4PB47.4 temp: 36.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 046 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Patriot model: P210 256GB
tech: SSD serial: <filter> fw-rev: 4A0 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM003-1SB102
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC63 scheme: GPT
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 504.82 GiB (27.6%)
used: 588 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 504.82 GiB (27.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 24
ID-2: swap-2 type: partition size: 34.37 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 35.5 C mobo: N/A
Fan Speeds (rpm): fan-1: 541
Memory: total: 32 GiB available: 31.25 GiB used: 3.45 GiB (11.0%)
Processes: 461 Power: uptime: 10m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1924 libs: 553 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
Garuda (2.6.26-1.1):
System install date:     2024-10-18
Last full system update: 2025-02-10
hello Indigoknight,
can you please update your garuda and reboot.
open the terminal and type in upd =)
And try to update your grub
update-grub
Maybe this works for you too, but it seems you did not search before posting a help request :slight_smile:
Okay after an update on my system and grub here is the new inxi. no improvment on reboot
Kernel: 6.13.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
Desktop: KDE Plasma v: 6.3.1 tk: Qt v: N/A info: frameworks v: 6.11.0
inactive: wayland
API: Vulkan v: 1.4.303 layers: 12 device: 0 type: discrete-gpu name: Intel
API: ALSA v: k6.13.3-zen1-1-zen status: kernel-api with: aoss
Local Storage: total: 3.87 TiB used: 513.1 GiB (12.9%)
lanes: 4 tech: SSD serial: <filter> fw-rev: R4PB47.4 temp: 39.9 C
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 513.1 GiB (28.1%)
used: 513.1 GiB (28.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 38.4 C mobo: N/A
Fan Speeds (rpm): fan-1: 557
Memory: total: 32 GiB available: 31.25 GiB used: 2.8 GiB (9.0%)
Processes: 485 Power: uptime: 0m states: freeze,mem,disk suspend: deep
Packages: pm: pacman pkgs: 1925 libs: 554 tools: octopi,paru Compilers:
Last full system update: 2025-02-21
Thanks for the reply @SGS
I looked at the forum you sent and it suggests moving /boot to the ext4 file system instead of the btrfs file system. But I’m not sure how to do that. Ill have to do a bit more digging.
p.s
i had spent a fair bit of time looking through the garuda forms but hadn’t thought to check other distros. I’m still very much a beginner in the linux world
do you have a mobile phone with camera?
if you start your computer and the Grub Boot Menu comes up can you press the e button and take a picture of this configuration? then press esc to get back to boot menu and start normally to post the pics if you can.thx
May there is something wrong?
ive did just for fun delete my echos and if is start this boot entries it dont show me even loading linux-zen or loading ramdisk an goes directly to the login screen(onlt short message overdrive is enabled )
Just check and edit
  1. Edit /etc/default/grub. Change the line:
GRUB_DEFAULT=saved
Do something like the following, which will default to booting the first GRUB menu entry.
GRUB_DEFAULT=0
GRUB_SAVEDEFAULT=false
then
sudo update-grub
same like
sudo grub2-mkconfig -o /boot/grub2/grub.cfg
in short.
My /etc/default/grub
# GRUB boot loader configuration
GRUB_DEFAULT=0
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="Garuda"
GRUB_CMDLINE_LINUX_DEFAULT='quiet loglevel=3'
# Preload both GPT and MBR modules so that they are not missed
GRUB_PRELOAD_MODULES="part_gpt part_msdos"
# Uncomment to enable booting from LUKS encrypted devices
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'hidden' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=menu
# Uncomment to use basic console
GRUB_TERMINAL_INPUT=console
# Uncomment to disable graphical terminal
#GRUB_TERMINAL_OUTPUT=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `videoinfo'
GRUB_GFXMODE=auto
# Uncomment to allow the kernel use the same resolution used by grub
GRUB_GFXPAYLOAD_LINUX=keep
# Uncomment if you want GRUB to pass to the Linux kernel the old parameter
# format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors.  Used by normal and wallpaper
# modes only.  Entries specified as foreground/background.
#GRUB_COLOR_NORMAL="light-blue/black"
#GRUB_COLOR_HIGHLIGHT="light-cyan/blue"
# Uncomment one of them for the gfx desired, a image background or a gfxtheme
#GRUB_BACKGROUND="/path/to/wallpaper"
GRUB_THEME="/usr/share/grub/themes/catppuccin-mocha/theme.txt"
# Uncomment to get a beep at GRUB start
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
#GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
# Probing for other operating systems is disabled for security reasons. Read
# documentation on GRUB_DISABLE_OS_PROBER, if still want to enable this
# functionality install os-prober and uncomment to detect and include other
# operating systems.
GRUB_DISABLE_OS_PROBER=false
# This config file imports drop-in files from /etc/default/grub.d/.
for garuda_grub_d in ${sysconfdir}/default/grub.d/*.cfg ; do if [ -e "${garuda_grub_d}" ]; then source "${garuda_grub_d}"; fi; done
GRUB_EARLY_INITRD_LINUX_STOCK=''
Did you use grub-customizer or something, did you change anything?
Maybe you overread it.
This cryptic but mostly-harmless error message arises from GRUB not supporting writes to /boot/grub2/grubenv on a btrfs filesystem. The /boot/grub2/grubenv file is used to store and recall state information about which kernel you booted last and whether the kernel booted successfully. You can safely ignore the error message if you don’t need those features. If you would like to get rid of the error message completely you can either …
Just ignore the 2 :smiley:
You can try and edit with the garuda-boot-options app too IIRC :wink:
Thanks for the help, editing that grub file the way you suggested got rid of the error message so we are all good to go. It was the 2 that was throwing me off in the fedora fourm post so thanks for the clarification
