Error running `garuda-nix-subsystem install`: "Unexpected response received from GitLab"
Hi, when running the above command, I’m getting this response:
╰─λ garuda-nix-subsystem install # trigger the installation process
[sudo] password for p:
--> Mounting nix subvolume
--> Launching installer 🍵
error:
… while fetching the input 'gitlab:garuda-linux/garuda-nix-subsystem/v2'
error: Unexpected response received from GitLab: [{"author_email":"ci@garudalinux.org","author_name":"Gitlab CI","authored_date":"2024-06-25T04:04:23.000+00:00","committed_date":"2024-06-25T04:04:23.000+00:00","committer_email":"ci@garudalinux.org","committer_name":"Gitlab CI","created_at":"2024-06-25T04:04:23.000+00:00","extended_trailers":{},"id":"0d7953e5a44b054831d8d800c1cfb8fca61aec04","message":"chore(flake.lock): bump flakes\n","parent_ids":["e720265d6af00cf249b505682ab70c4e5999708a"],"short_id":"0d7953e5","title":"chore(flake.lock): bump flakes","trailers":{},"web_url":"https://gitlab.com/garuda-linux/
<snip>
tter_name":"Gitlab CI","created_at":"2024-06-05T04:03:13.000+00:00","extended_trailers":{},"id":"fc3b01f88912b6937561cc9ec6b44d9cb4955357","message":"chore(flake.lock): bump flakes\n","parent_ids":["d9b673b2fe7a5bbae1ae46320736e21048462bc3"],"short_id":"fc3b01f8","title":"chore(flake.lock): bump flakes","trailers":{},"web_url":"https://gitlab.com/garuda-linux/garuda-nix-subsystem/-/commit/fc3b01f88912b6937561cc9ec6b44d9cb4955357"}]
I edited the very large JSON reponse above for brevity but if it would be helpful, let me know and I’ll include it all.
Any help or advice appreciated.
Advise you post your ‘garuda-inxi’ output before @SGS disposes of your post. Them’s the rules. :slight_smile:
Sorry. garuda-inxi:
Kernel: 6.6.35-2-lts arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=ede2902b-56dc-4896-956e-3632ad9d64ee rw rootflags=subvol=@
quiet rd.luks.uuid=094360e6-2196-486b-ab4c-fad9c2403418
rd.luks.uuid=f2209df3-8371-4947-8287-b972d0e54920
resume=/dev/mapper/luks-f2209df3-8371-4947-8287-b972d0e54920 loglevel=3
Desktop: KDE Plasma v: 6.1.0 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Laptop System: Acer product: Predator PH18-71 v: V1.15
Mobo: RPL model: EQS_RTX v: V1.15 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI: INSYDE v: 1.15
date: 09/07/2023
ID-1: BAT1 charge: 64.1 Wh (79.6%) condition: 80.5/90.6 Wh (88.9%)
volts: 16.3 min: 15.4 model: LGC AP21A8T type: Li-ion serial: <filter>
status: charging cycles: 33
Info: model: 13th Gen Intel Core i7-13700HX bits: 64 type: MST AMCP
process: Intel 7 (10nm) family: 6 model-id: 0xBF (191) stepping: 2
microcode: 0x35
Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
L2: 14 MiB desc: 8x1.2 MiB, 2x2 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 946 high: 2849 min/max: 800/4800:5000:3700 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 2849 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 1900 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 1166
24: 800 bogomips: 110616
Device-1: Intel Alder Lake-HX GT1 [UHD Graphics 770]
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-12.2
process: Intel 10nm built: 2021-22+ ports: active: eDP-2 empty: none
bus-ID: 0000:00:02.0 chip-ID: 8086:4688 class-ID: 0300
Device-2: NVIDIA AD106M [GeForce RTX 4070 Max-Q / Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 550.90.07
alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ ports: active: none off: HDMI-A-1
empty: DP-1,DP-2,eDP-1 bus-ID: 0000:01:00.0 chip-ID: 10de:2860
Device-3: Quanta Acer FHD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:4 chip-ID: 0408:4036
gpu: i915,nvidia d-rect: 3520x2080 display-ID: 0
Monitor-1: HDMI-A-1 pos: top-right res: 1920x1080 size: N/A modes: N/A
Monitor-2: eDP-2 pos: bottom-l res: 1600x1000 size: N/A modes: N/A
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.1.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (ADL-S GT1)
device-ID: 8086:4688 memory: 7.5 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 10 device: 0 type: integrated-gpu
name: Intel UHD Graphics (ADL-S GT1) driver: mesa intel v: 24.1.2-arch1.1
device-ID: 8086:4688 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce RTX 4070 Laptop GPU driver: nvidia
v: 550.90.07 device-ID: 10de:2860 surfaces: xcb,xlib,wayland device: 2
type: cpu name: llvmpipe (LLVM 17.0.6 256 bits) driver: mesa llvmpipe
v: 24.1.2-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: Intel Raptor Lake High Definition Audio
vendor: Acer Incorporated ALI driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:7a50 class-ID: 0401
Device-2: NVIDIA AD106M High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus-ID: 0000:01:00.1 chip-ID: 10de:22bd class-ID: 0403
Device-3: JMTek LLC. USB PnP Audio Device
lanes: 1 mode: 1.1 bus-ID: 1-11:6 chip-ID: 0c76:1694 class-ID: 0300
API: ALSA v: k6.6.35-2-lts status: kernel-api with: aoss
Device-1: Intel Raptor Lake-S PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 0000:00:14.3 chip-ID: 8086:7a70
Device-2: Realtek Killer E2600 GbE vendor: Acer Incorporated ALI
driver: r8169 v: kernel port: 3000 bus-ID: 0000:6d:00.0 chip-ID: 10ec:2600
IF: enp109s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 8087:0033
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.3 lmp-v: 12
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 953.88 GiB used: 24.27 GiB (2.5%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Micron model: 2400 MTFDKBA512QFM
lanes: 4 tech: SSD serial: <filter> fw-rev: V3MA001 temp: 41.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
model: MZVL2512HCJQ-00B07 size: 476.94 GiB block-size: physical: 512 B
fw-rev: GXA7402Q temp: 51.9 C scheme: GPT
ID-1: / raw-size: 459.75 GiB size: 459.75 GiB (100.00%)
used: 24.27 GiB (5.3%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-094360e6-2196-486b-ab4c-fad9c2403418
used: 728 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-3: /home raw-size: 459.75 GiB size: 459.75 GiB (100.00%)
ID-4: /var/log raw-size: 459.75 GiB size: 459.75 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.75 GiB size: 459.75 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.89 GiB used: 0 KiB (0.0%)
mapped: luks-f2209df3-8371-4947-8287-b972d0e54920
ID-2: swap-2 type: zram size: 15.36 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 47.0 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.36 GiB used: 4.9 GiB (31.9%)
Processes: 454 Power: uptime: 13m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.1 GiB services: org_kde_powerdevil,
Packages: pm: nix-default pkgs: 0 pm: nix-sys pkgs: 0 pm: nix-usr pkgs: 0
pm: pacman pkgs: 1942 libs: 577 tools: octopi,paru Compilers: clang: 17.0.6
gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.35
System install date:     2024-06-24
Last full system update: 2024-06-25
Have you already signed in/signed up?
https://gitlab.com/users/sign_in
Sorry, I don’t quite understand. I need to create a Gitlab account for the install script to work? Once I’ve got a Gitlab account, how do I tell the script?
I don’t know as I don’t use it. Did you follow the prompts and do what it says? That’s how things tend to work, generally.
Yeah, the only prompt I got was for the sudo password and then it failed fetching from GitLab.
It’s not important, the normal Garuda system is my daily driver and that works very well. I was just wanting to play around with NixOS since I saw it was an experimental option.
This error appears to be related to this recent commit, which has some kind of problem:
I don’t know exactly what the deal is with that, but it appears the pipeline has failed–perhaps that is related to the issue you have encountered. You’ll have to hold off for now, until @dr460nf1r3 and @TNE have a chance to take a look.
This was just an expired access token, which was used to provide the possibility of pushing back changes to the repo. I’ve fixed that one.
As for the input, I’ve just tested this without issues on my machine.
Sounds good, @PeterR give it another shot.
I’m still getting the exact same failure at the same point.
Not to worry, I can play with NixOS in a VM.
Interesting. Would you be so kind to provide the full log in this case? (e.g. uploaded to bin.garudalinux.org) I’m not sure what exactly this json is supposed to be :thinking:
edit: must be a JSON dump of the commit itself… hum. Didn’t test the installer itself, but via using the flake input in an already installed system.
I guess it’s not that big in retrospect. I just didn’t want my first post on these forums to be a wall of text given I wasn’t familiar with the rules and etiquette.
error:
error: Unexpected response received from GitLab: [{"author_email":"root@dr460nf1r3.org","author_name":"Nico Jensch","authored_date":"2024-06-28T10:49:24.000+02:00","committed_date":"2024-06-28T10:49:36.000+02:00","committer_email":"root@dr460nf1r3.org","committer_name":"Nico Jensch","created_at":"2024-06-28T10:49:36.000+02:00","extended_trailers":{},"id":"ba379293264234693736e2488ea039dd406048bc","message":"chore(catppuccin): remove redundant envvar\n","parent_ids":["15e68fc05a39cd0aa3f70df71f6c383c1c6e008f"],"short_id":"ba379293","title":"chore(catppuccin): remove redundant envvar","trailers":{},"web_url":"https://gitlab.com/garuda-linux/garuda-nix-subsystem/-/commit/ba379293264234693736e2488ea039dd406048bc"},{"author_email":"ci@garudalinux.org","author_name":"Gitlab CI","authored_date":"2024-06-28T04:03:23.000+00:00","committed_date":"2024-06-28T04:03:23.000+00:00","committer_email":"ci@garudalinux.org","committer_name":"Gitlab CI","created_at":"2024-06-28T04:03:23.000+00:00","extended_trailers":{},"id":"15e68fc05a39cd0aa3f70df71f6c383c1c6e008f","message":"chore(flake.lock): bump flakes\n","parent_ids":["c77905ae2a70d56c772047cf19e7a1217756d16d"],"short_id":"15e68fc0","title":"chore(flake.lock): bump flakes","trailers":{},"web_url":"https://gitlab.com/garuda-linux/garuda-nix-subsystem/-/commit/15e68fc05a39cd0aa3f70df71f6c383c1c6e008f"},{"author_email":"root@dr460nf1r3.org","author_name":"Nico Jensch","authored_date":"2024-06-27T18:12:58.000+02:00","committed_date":"2024-06-27T18:12:58.000+02:00","committer_email":"root@dr460nf1r3.org","committer_name":"Nico Jensch","created_at":"2024-06-27T18:12:58.000+02:00","extended_trailers":{},"id":"c77905ae2a70d56c772047cf19e7a1217756d16d","message":"feat(catppuccin): fix GTK, add SDDM and other theming\n","parent_ids":["d4164407032cbfefbc4171b7c05bef5447ee1710"],"short_id":"c77905ae","title":"feat(catppuccin): fix GTK, add SDDM and other theming","trailers":{},"web_url":"https://gitlab.com/garuda-linux/garuda-nix-subsystem/-/commit/c77905ae2a70d56c772047cf19e7a1217756d16d"},{"author_email":"root@dr460nf1r3.org","author_name":"Nico Jensch","authored_date":"2024-06-27T17:22:34.000+02:00","committed_date":"2024-06-27T17:22:52.000+02:00","committer_email":"root@dr460nf1r3.org","committer_name":"Nico Jensch","created_at":"2024-06-27T17:22:52.000+02:00","extended_trailers":{},"id":"d4164407032cbfefbc4171b7c05bef5447ee1710","message":"feat(home-manager): don't fail on home-manager activation because of existing files\n","parent_ids":["99e496da3e6e0b7660bd44fd6a55d9e7dc04549f"],"short_id":"d4164407","title":"feat(home-manager): don't fail on home-manager activation because of existing files","trailers":{},"web_url":"https://gitlab.com/garuda-linux/garuda-nix-subsystem/-/commit/d4164407032cbfefbc4171b7c05bef5447ee1710"},{"author_email":"ci@garudalinux.org","author_name":"Gitlab CI","authored_date":"2024-06-27T13:07:16.000+00:00","committed_date":"2024-06-27T13:07:16.000+00:00","committer_email":"ci@garudalinux.org","committer_name":"Gitlab CI","created_at":"2024-06-27T13:07:16.000+00:00","extended_trailers":{},"id":"99e496da3e6e0b7660bd44fd6a55d9e7dc04549f","message":"chore(flake.lock): bump flakes\n","parent_ids":["3e118b9cd652d23fc1bcdacd19c0acfe3d748adb"],"short_id":"99e496da","title":"chore(flake.lock): bump flakes","trailers":{},"web_url":"https://gitlab.com/garuda-linux/garuda-nix-subsystem/-/commit/99e496da3e6e0b7660bd44fd6a55d9e7dc04549f"},{"author_email":"root@dr460nf1r3.org","author_name":"Nico Jensch","authored_date":"2024-06-26T17:29:12.000+02:00","committed_date":"2024-06-26T17:29:12.000+02:00","committer_email":"root@dr460nf1r3.org","committer_name":"Nico Jensch","created_at":"2024-06-26T17:29:12.000+02:00","extended_trailers":{},"id":"3e118b9cd652d23fc1bcdacd19c0acfe3d748adb","message":"fix(catppuccin): use pointerCursor flake option\n","parent_ids":["0d7953e5a44b054831d8d800c1cfb8fca61aec04"],"short_id":"3e118b9c","title":"fix(catppuccin): use pointerCursor flake option","trailers":{},"web_url":"https://gitlab.com/garuda-linux/garuda-nix-subsystem/-/commit/3e118b9cd652d23fc1bcdacd19c0acfe3d748adb"},{"author_email":"ci@garudalinux.org","author_name":"Gitlab CI","authored_date":"2024-06-25T04:04:23.000+00:00","committed_date":"2024-06-25T04:04:23.000+00:00","committer_email":"ci@garudalinux.org","committer_name":"Gitlab CI","created_at":"2024-06-25T04:04:23.000+00:00","extended_trailers":{},"id":"0d7953e5a44b054831d8d800c1cfb8fca61aec04","message":"chore(flake.lock): bump flakes\n","parent_ids":["e720265d6af00cf249b505682ab70c4e5999708a"],"short_id":"0d7953e5","title":"chore(flake.lock): bump flakes","trailers":{},"web_url":"https://gitlab.com/garuda-linux/garuda-nix-subsystem/-/commit/0d7953e5a44b054831d8d800c1cfb8fca61aec04"},{"author_email":"ci@garudalinux.org","author_name":"Gitlab CI","authored_date":"2024-06-24T04:03:38.000+00:00","committed_date":"2024-06-24T04:03:38.000+00:00","committer_email":"ci@garudalinux.org","committer_name":"Gitlab CI","created_at":"2024-06-24T04:03:38.000+00:00","extended_trailers":{},"id":"e720265d6af00cf249b505682ab70c4e5999708a","message":"chore(flake.lock): bump flakes\n","parent_ids":["0d8b6bc98c1e89cb2aa078ca697f257125a2b9cb"],"short_id":"e720265d","title":"chore(flake.lock): bump flakes","trailers":{},"web_url":"https://gitlab.com/garuda-linux/garuda-nix-subsystem/-/commit/e720265d6af00cf249b505682ab70c4e5999708a"},{"author_email":"root@dr460nf1r3.org","author_name":"Nico Jensch","authored_date":"2024-06-23T18:24:57.000+02:00","committed_date":"2024-06-23T18:24:57.000+02:00","committer_email":"root@dr460nf1r3.org","committer_name":"Nico Jensch","created_at":"2024-06-23T18:24:57.000+02:00","extended_trailers":{},"id":"0d8b6bc98c1e89cb2aa078ca697f257125a2b9cb","message":"fix(shells): improve NixOS logo location\n","parent_ids":["8f30df1d57337ec0a9d030647900253c882a0df3"],"short_id":"0d8b6bc9","title":"fix(shells): improve NixOS logo location","trailers":{},"web_url":"https://gitlab.com/garuda-linux/garuda-nix-subsystem/-/commit/0d8b6bc98c1e89cb2aa078ca697f257125a2b9cb"},{"author_email":"root@dr460nf1r3.org","author_name":"Nico Jensch","authored_date":"2024-06-23T18:07:53.000+02:00","committed_date":"2024-06-23T18:08:36.000+02:00","committer_email":"root@dr460nf1r3.org","committer_name":"Nico Jensch","created_at":"2024-06-23T18:08:36.000+02:00","extended_trailers":{},"id":"8f30df1d57337ec0a9d030647900253c882a0df3","message":"fix(catppuccin): cursors requires variant to be set\n","parent_ids":["623bec31438289988ca42b8d406d49f6a69a3654"],"short_id":"8f30df1d","title":"fix(catppuccin): cursors requires variant to be set","trailers":{},"web_url":"https://gitlab.com/garuda-linux/garuda-nix-subsystem/-/commit/8f30df1d57337ec0a9d030647900253c882a0df3"},{"author_email":"ci@garudalinux.org","author_name":"Gitlab CI","authored_date":"2024-06-23T04:03:43.000+00:00","committed_date":"2024-06-23T04:03:43.000+00:00","committer_email":"ci@garudalinux.org","committer_name":"Gitlab CI","created_at":"2024-06-23T04:03:43.000+00:00","extended_trailers":{},"id":"623bec31438289988ca42b8d406d49f6a69a3654","message":"chore(flake.lock): bump flakes\n","parent_ids":["ec845985d4a1cbb796e83b5f97700b96f68c0596"],"short_id":"623bec31","title":"chore(flake.lock): bump flakes","trailers":{},"web_url":"https://gitlab.com/garuda-linux/garuda-nix-subsystem/-/commit/623bec31438289988ca42b8d406d49f6a69a3654"},{"author_email":"root@dr460nf1r3.org","author_name":"Nico Jensch","authored_date":"2024-06-22T13:55:49.000+02:00","committed_date":"2024-06-22T13:55:49.000+02:00","committer_email":"root@dr460nf1r3.org","committer_name":"Nico Jensch","created_at":"2024-06-22T13:55:49.000+02:00","extended_trailers":{},"id":"ec845985d4a1cbb796e83b5f97700b96f68c0596","message":"fix(hardware): hardware.opengl -> graphics.X renamed option\n","parent_ids":["6626d56eabc7852529095fd617a0084645a98c10"],"short_id":"ec845985","title":"fix(hardware): hardware.opengl -> graphics.X renamed option","trailers":{},"web_url":"https://gitlab.com/garuda-linux/garuda-nix-subsystem/-/commit/ec845985d4a1cbb796e83b5f97700b96f68c0596"},{"author_email":"root@dr460nf1r3.org","author_name":"Nico Jensch","authored_date":"2024-06-22T12:02:39.000+02:00","committed_date":"2024-06-22T12:02:39.000+02:00","committer_email":"root@dr460nf1r3.org","committer_name":"Nico Jensch","created_at":"2024-06-22T12:02:39.000+02:00","extended_trailers":{},"id":"6626d56eabc7852529095fd617a0084645a98c10","message":"fix: remove obsolete option\n","parent_ids":["06717e120f1c84f12a206730747f114f967d20d4"],"short_id":"6626d56e","title":"fix: remove obsolete option","trailers":{},"web_url":"https://gitlab.com/garuda-linux/garuda-nix-subsystem/-/commit/6626d56eabc7852529095fd617a0084645a98c10"},{"author_email":"root@dr460nf1r3.org","author_name":"Nico Jensch","authored_date":"2024-06-15T19:05:38.000+02:00","committed_date":"2024-06-15T19:05:38.000+02:00","committer_email":"root@dr460nf1r3.org","committer_name":"Nico Jensch","created_at":"2024-06-15T19:05:38.000+02:00","extended_trailers":{},"id":"06717e120f1c84f12a206730747f114f967d20d4","message":"fix(catppuccin): cursor theme name is spelled lowercase. Hell <.<\n","parent_ids":["e3b0904ec80bdf66d87848063f4d5beef8ecc4cc"],"short_id":"06717e12","title":"fix(catppuccin): cursor theme name is spelled lowercase. Hell <.<","trailers":{},"web_url":"https://gitlab.com/garuda-linux/garuda-nix-subsystem/-/commit/06717e120f1c84f12a206730747f114f967d20d4"},{"author_email":"ci@garudalinux.org","author_name":"Gitlab CI","authored_date":"2024-06-15T04:03:27.000+00:00","committed_date":"2024-06-15T04:03:27.000+00:00","committer_email":"ci@garudalinux.org","committer_name":"Gitlab CI","created_at":"2024-06-15T04:03:27.000+00:00","extended_trailers":{},"id":"e3b0904ec80bdf66d87848063f4d5beef8ecc4cc","message":"chore(flake.lock): bump flakes\n","parent_ids":["d9affd6869428eec4840b430e9516cee4e0ce320"],"short_id":"e3b0904e","title":"chore(flake.lock): bump flakes","trailers":{},"web_url":"https://gitlab.com/garuda-linux/garuda-nix-subsystem/-/commit/e3b0904ec80bdf66d87848063f4d5beef8ecc4cc"},{"author_email":"ci@garudalinux.org","author_name":"Gitlab CI","authored_date":"2024-06-14T04:03:30.000+00:00","committed_date":"2024-06-14T04:03:30.000+00:00","committer_email":"ci@garudalinux.org","committer_name":"Gitlab CI","created_at":"2024-06-14T04:03:30.000+00:00","extended_trailers":{},"id":"d9affd6869428eec4840b430e9516cee4e0ce320","message":"chore(flake.lock): bump flakes\n","parent_ids":["ae38033a903f07e7f1176e27da3898e534b4a12d"],"short_id":"d9affd68","title":"chore(flake.lock): bump flakes","trailers":{},"web_url":"https://gitlab.com/garuda-linux/garuda-nix-subsystem/-/commit/d9affd6869428eec4840b430e9516cee4e0ce320"},{"author_email":"ci@garudalinux.org","author_name":"Gitlab CI","authored_date":"2024-06-13T04:03:48.000+00:00","committed_date":"2024-06-13T04:03:48.000+00:00","committer_email":"ci@garudalinux.org","committer_name":"Gitlab CI","created_at":"2024-06-13T04:03:48.000+00:00","extended_trailers":{},"id":"ae38033a903f07e7f1176e27da3898e534b4a12d","message":"chore(flake.lock): bump flakes\n","parent_ids":["38f14ab92648a951a023f32f1026aac2b9051dd3"],"short_id":"ae38033a","title":"chore(flake.lock): bump flakes","trailers":{},"web_url":"https://gitlab.com/garuda-linux/garuda-nix-subsystem/-/commit/ae38033a903f07e7f1176e27da3898e534b4a12d"},{"author_email":"ci@garudalinux.org","author_name":"Gitlab CI","authored_date":"2024-06-12T12:04:51.000+00:00","committed_date":"2024-06-12T12:04:51.000+00:00","committer_email":"ci@garudalinux.org","committer_name":"Gitlab CI","created_at":"2024-06-12T12:04:51.000+00:00","extended_trailers":{},"id":"38f14ab92648a951a023f32f1026aac2b9051dd3","message":"chore(flake.lock): bump flakes\n","parent_ids":["9633c2b2e9538b1d00a041f957b826ce2529e217"],"short_id":"38f14ab9","title":"chore(flake.lock): bump flakes","trailers":{},"web_url":"https://gitlab.com/garuda-linux/garuda-nix-subsystem/-/commit/38f14ab92648a951a023f32f1026aac2b9051dd3"},{"author_email":"ci@garudalinux.org","author_name":"Gitlab CI","authored_date":"2024-06-12T04:03:20.000+00:00","committed_date":"2024-06-12T04:03:20.000+00:00","committer_email":"ci@garudalinux.org","committer_name":"Gitlab CI","created_at":"2024-06-12T04:03:20.000+00:00","extended_trailers":{},"id":"9633c2b2e9538b1d00a041f957b826ce2529e217","message":"chore(flake.lock): bump flakes\n","parent_ids":["6d8384869e4afc1c329e0d48c00e24bdf562dd4d"],"short_id":"9633c2b2","title":"chore(flake.lock): bump flakes","trailers":{},"web_url":"https://gitlab.com/garuda-linux/garuda-nix-subsystem/-/commit/9633c2b2e9538b1d00a041f957b826ce2529e217"},{"author_email":"ci@garudalinux.org","author_name":"Gitlab CI","authored_date":"2024-06-11T04:03:28.000+00:00","committed_date":"2024-06-11T04:03:28.000+00:00","committer_email":"ci@garudalinux.org","committer_name":"Gitlab CI","created_at":"2024-06-11T04:03:28.000+00:00","extended_trailers":{},"id":"6d8384869e4afc1c329e0d48c00e24bdf562dd4d","message":"chore(flake.lock): bump flakes\n","parent_ids":["63966d20a52e612d6e5e84258438dbaf738d7405"],"short_id":"6d838486","title":"chore(flake.lock): bump flakes","trailers":{},"web_url":"https://gitlab.com/garuda-linux/garuda-nix-subsystem/-/commit/6d8384869e4afc1c329e0d48c00e24bdf562dd4d"}]
You can post up to 32000 chars, IIRC.
Since it will expire in 29 days, I just edit your post :wink:
