It has been popping every time I use the new "update" command to update the system. Should I care about that or is it fine to ignore?
Checking for keyring update, then update as needed..
error: package 'blackarch-keyring' was not found
Haven't found anything about that in the forums. Everything updates as it should and I did read the post here Improving garuda-common-settings - manual intervention required - after updating and using the command again, nothing pops.
Thank you in advance.
Edit: For some reason I can not reply. Here's proof that nothing pops for me.
