root=UUID=d4f71312-d373-4bbb-8f13-b65701e08cf0 rw rootflags=subvol=@
Desktop: awesome v: 4.3 vt: 1 dm: SDDM Distro: Garuda Linux
Type: Desktop System: HP product: HP EliteDesk 800 G4 DM 35W v: N/A
serial: <superuser required> Chassis: type: 6 serial: <superuser required>
Mobo: HP model: 83E2 v: KBC Version 07.D1.00 serial: <superuser required>
UEFI: HP v: Q21 Ver. 02.15.00 date: 12/28/2020
Info: model: Intel Core i5-8500 bits: 64 type: MCP arch: Coffee Lake
desc: 1x9 MiB
Speed (MHz): avg: 3175 high: 4051 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 3000 2: 3000 3: 3000
4: 4051 5: 3000 6: 3000 bogomips: 36000
disabled
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT disabled
PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Hewlett-Packard
ports: active: HDMI-A-2 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:3e92 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4 driver: X:
loaded: intel unloaded: modesetting alternate: fbdev,vesa dri: i965
Monitor-1: HDMI-A-2 mapped: HDMI2 model: Dell S2421HN serial: <filter>
built: 2021 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 530x300mm (20.87x11.81") diag: 604mm (23.8") ratio: 16:9 modes:
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa
22.2.1 direct render: Yes
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bb class-ID: 0200
driver: btusb v: 0.8 bus-ID: 1-1:2 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 238.47 GiB used: 215.77 GiB (90.5%)
model: MZVLB256HAHQ-000H1 size: 238.47 GiB block-size: physical: 512 B
rev: EXD70H1Q temp: 48.9 C scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 238.17 GiB (100.00%) used: 215.77 GiB
(90.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 592 KiB
ID-3: /home raw-size: 238.17 GiB size: 238.17 GiB (100.00%) used: 215.77
GiB (90.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 238.17 GiB size: 238.17 GiB (100.00%) used: 215.77
ID-5: /var/tmp raw-size: 238.17 GiB size: 238.17 GiB (100.00%) used: 215.77
ID-1: swap-1 type: zram size: 15.4 GiB used: 0 KiB (0.0%) priority: 100
Src: /sys System Temperatures: cpu: 58.0 C pch: 53.0 C mobo: N/A
Processes: 221 Uptime: 8m wakeups: 1 Memory: 15.4 GiB used: 1.62 GiB
(10.5%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: 2057 pm: pacman pkgs: 2050 libs: 490
tools: octopi,pamac,paru pm: flatpak pkgs: 7 Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.22
Garuda (2.6.9-1):
System install date: 2022-04-03
Last full system update: 2022-10-27
Hi,
recently (idk but I think after an update) I started seeing my desktop shuts down but then the screen turns on again and after about 50 seconds shows an error message(?) and shuts down.
Ever since this started, nitrogen --restore
stopped working after startup.
This message is so overwhelming I can't even understand what the error is. I've searched about it online ofc but found nothing relevant. I did change my DisplayPort to HDMI adapter recently but I'm not sure but don't think that's when the problem started.
One more thing to note is that this does not happen on restarts, only shutdown
thanks in advance
