error: no servers configured for repository: extra
(3/3) checking keys in keyring [-------------------------------------------] 100%
(3/3) checking package integrity [-------------------------------------------] 100%
error: failed to commit transaction (wrong or NULL argument passed)
Hi there, welcome.
Can we see the contents of your /etc/pacman.conf
Please always include the text blocks from terminal between
text here…
In addition to that, have you refreshed your mirrors recently? Was this a part of the output of an update
command?
file:///etc/pacman.d/gnupg
file:///etc/pacman.d/hooks
file:///etc/pacman.d/hooks.bin
file:///etc/pacman.d/chaotic-mirrorlist
file:///etc/pacman.d/mirrorlist
file:///etc/pacman.d/mirrorlist.pacnew
sudo micro /etc/pacman.conf
For the contents.
then i got this error
[sudo] password for rrj:
:: There are 3 providers available for mysql:
:: Repository extra
1) mariadb
:: Repository community
2) percona-server
:: Repository chaotic-aur
3) mysql57
Enter a number (default=1): 1
resolving dependencies...
Packages (3) jemalloc-1:5.2.1-6 mariadb-clients-10.6.5-2 mariadb-10.6.5-2
Total Download Size: 30.80 MiB
Total Installed Size: 283.73 MiB
~~~:: Proceed with installation? [Y/n] y
(3/3) checking keys in keyring [------------------------------------] 100%
(3/3) checking package integrity [------------------------------------] 100%
Errors occurred, no packages were upgraded.~~~
now please help me to solve this?
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir = /
#DBPath = /var/lib/pacman/
CacheDir = /var/cache/pacman/pkg/
#LogFile = /var/log/pacman.log
#GPGDir = /etc/pacman.d/gnupg/
#HookDir = /etc/pacman.d/hooks/
HoldPkg = pacman glibc garuda-system
#XferCommand = /usr/bin/curl -L -C - -f -o %o %u
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
Architecture = auto
# Pacman won't upgrade packages listed in IgnorePkg and members of IgnoreGroup
#IgnorePkg =
#IgnoreGroup =
#NoUpgrade =
#NoExtract =
# Misc options
#UseSyslog
Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
ParallelDownloads = 5
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel = Required DatabaseOptional
LocalFileSigLevel = Optional
#RemoteFileSigLevel = Required
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Arch Linux
# packagers with `pacman-key --populate archlinux`.
# REPOSITORIES
# - can be defined here or included from another file
# - pacman will search repositories in the order defined here
# - local/custom mirrors can be added here or in separate files
# - repositories listed first will take precedence when packages
# have identical names, regardless of version number
# - URLs will have $repo replaced by the name of the current repo
# - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
# [repo-name]
# Server = ServerName
# Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
[core]
Include = /etc/pacman.d/mirrorlist
[extra]
[community]
[multilib]
[chaotic-aur]
Include = /etc/pacman.d/chaotic-mirrorlist
# An example of a custom package repository. See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
Have you already tried to refresh your mirrorlist, e.g. with the Garuda Assistant?
As @filo mentioned, was the error in the opening post from the update
command or not?
Without an inxi -Faz
output, we can only guess what is the last time you updated.
yes, sir i upd
Kernel: 5.16.0-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=0817f567-9150-4274-8000-aaabab00e8bc rw rootflags=subvol=@
Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
Mobo: HP model: 81EC v: 61.38 serial: <superuser required>
UEFI-[Legacy]: Insyde v: F.21 date: 10/27/2016
ID-1: BAT1 charge: 0% condition: 21.5/41.6 Wh (51.6%) volts: 10.8 min: 14.6
model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter>
status: N/A
Info: model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xEA
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2733 high: 2756 min/max: 400/2800 scaling:
driver: intel_pstate governor: powersave cores: 1: 2744 2: 2715 3: 2756
4: 2718 bogomips: 19200
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 /
Radeon 520 Mobile]
vendor: Hewlett-Packard driver: radeon v: kernel alternate: amdgpu
bus-ID: 01:00.0 chip-ID: 1002:6660 class-ID: 0380
Device-3: Cheng Uei Precision Industry (Foxlink) HP TrueVision HD
type: USB driver: uvcvideo bus-ID: 1-5:4 chip-ID: 05c8:038f class-ID: 0e02
loaded: ati,intel,radeon unloaded: modesetting alternate: fbdev,vesa
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143
size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
Sound Server-1: ALSA v: k5.16.0-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.20 running: no
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus-ID: 02:00.0
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8723be v: kernel port: 3000
bus-ID: 03:00.0 chip-ID: 10ec:b723 class-ID: 0280
bus-ID: 1-4:3 chip-ID: 0bda:b008 class-ID: e001 serial: <filter>
Local Storage: total: 931.51 GiB used: 54.62 GiB (5.9%)
model: WD10JPVX-60JC3T0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: MBR
used: 54.62 GiB (5.9%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: zram size: 7.66 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 29.8 C pch: 38.5 C mobo: 27.8 C gpu: radeon
temp: 34.0 C
Processes: 253 Uptime: 3h 51m wakeups: 22 Memory: 7.66 GiB
used: 3.46 GiB (45.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1313 lib: 340 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.11 ~~~
Could you please post the complete output when you enter update
in terminal?
#output of update in terminal
update
error: failed to synchronize all databases (no servers configured for repository)
--> Refreshing mirrorlists using rate-mirrors, please be patient..
core 136.4 KiB 144 KiB/s 00:01 [----------------------------------------------------------------------------------------] 100%
extra 1556.8 KiB 442 KiB/s 00:04 [----------------------------------------------------------------------------------------] 100%
community 6.0 MiB 1146 KiB/s 00:05 [----------------------------------------------------------------------------------------] 100%
multilib 149.3 KiB 154 KiB/s 00:01 [----------------------------------------------------------------------------------------] 100%
chaotic-aur 1734.0 KiB 23.4 KiB/s 01:14 [----------------------------------------------------------------------------------------] 100%
--> Checking for keyring update before starting full system update..
warning: garuda-hotfixes-1.0.4-1 is up to date -- skipping
warning: archlinux-keyring-20220114-1 is up to date -- skipping
warning: chaotic-keyring-20210617-2 is up to date -- skipping
there is nothing to do
Packages (16) efivar-38-2 expat-2.4.3-1 firedragon-96.0.1-1 grub-2:2.06-4 gtk-update-icon-cache-1:4.6.0-2 hostapd-2.10-1 jack2-1.9.20-3 lib32-expat-2.4.3-1 libuv-1.43.0-1 libxml2-2.9.12-7 linux-zen-5.16.1.zen1-1
linux-zen-headers-5.16.1.zen1-1 mysql-workbench-8.0.28-1 python-setuptools-1:59.1.1-1 reflector-2021.11-2 rest-0.8.1+r4+ge5ee6ef-1
Total Download Size: 291.23 MiB
Total Installed Size: 676.65 MiB
Net Upgrade Size: 0.66 MiB
:: Retrieving packages...
grub-2:2.06-4-x86_64 6.7 MiB 1097 KiB/s 00:06 [----------------------------------------------------------------------------------------] 100%
libxml2-2.9.12-7-x86_64 1386.5 KiB 1269 KiB/s 00:01 [----------------------------------------------------------------------------------------] 100%
hostapd-2.10-1-x86_64 754.9 KiB 779 KiB/s 00:01 [----------------------------------------------------------------------------------------] 100%
python-setuptools-1:59.1.1-1-any 560.8 KiB 445 KiB/s 00:01 [----------------------------------------------------------------------------------------] 100%
jack2-1.9.20-3-x86_64 473.3 KiB 196 KiB/s 00:02 [----------------------------------------------------------------------------------------] 100%
libuv-1.43.0-1-x86_64 226.6 KiB 122 KiB/s 00:02 [----------------------------------------------------------------------------------------] 100%
efivar-38-2-x86_64 145.5 KiB 80.2 KiB/s 00:02 [----------------------------------------------------------------------------------------] 100%
expat-2.4.3-1-x86_64 115.4 KiB 146 KiB/s 00:01 [----------------------------------------------------------------------------------------] 100%
rest-0.8.1+r4+ge5ee6ef-1-x86_64 96.1 KiB 133 KiB/s 00:01 [----------------------------------------------------------------------------------------] 100%
lib32-expat-2.4.3-1-x86_64 72.8 KiB 94.6 KiB/s 00:01 [----------------------------------------------------------------------------------------] 100%
reflector-2021.11-2-any 26.7 KiB 67.8 KiB/s 00:00 [----------------------------------------------------------------------------------------] 100%
gtk-update-icon-cache-1:4.6.0-2-x86_64 16.5 KiB 37.8 KiB/s 00:00 [----------------------------------------------------------------------------------------] 100%
linux-zen-headers-5.16.1.zen1-1-x86_64 26.7 MiB 924 KiB/s 00:30 [----------------------------------------------------------------------------------------] 100%
mysql-workbench-8.0.28-1-x86_64 22.5 MiB 675 KiB/s 00:34 [----------------------------------------------------------------------------------------] 100%
firedragon-96.0.1-1-x86_64 71.0 MiB 1199 KiB/s 01:01 [----------------------------------------------------------------------------------------] 100%
linux-zen-5.16.1.zen1-1-x86_64 160.5 MiB 1776 KiB/s 01:33 [----------------------------------------------------------------------------------------] 100%
Total (16/16) 291.2 MiB 3.14 MiB/s 01:33 [----------------------------------------------------------------------------------------] 100%
(16/16) checking keys in keyring [----------------------------------------------------------------------------------------] 100%
(16/16) checking package integrity [----------------------------------------------------------------------------------------] 100%
(16/16) loading package files [----------------------------------------------------------------------------------------] 100%
(16/16) checking for file conflicts [----------------------------------------------------------------------------------------] 100%
(16/16) checking available disk space [----------------------------------------------------------------------------------------] 100%
(1/4) Performing snapper pre snapshots for the following configurations...
==> root: 43
(2/4) Saving Linux kernel modules...
(3/4) Removing linux initcpios...
(4/4) Remove FireDragon Distribution Settings
( 1/16) upgrading efivar [----------------------------------------------------------------------------------------] 100%
( 2/16) upgrading expat [----------------------------------------------------------------------------------------] 100%
( 3/16) upgrading jack2 [----------------------------------------------------------------------------------------] 100%
( 4/16) upgrading libxml2 [----------------------------------------------------------------------------------------] 100%
( 5/16) upgrading gtk-update-icon-cache [----------------------------------------------------------------------------------------] 100%
( 6/16) upgrading rest [----------------------------------------------------------------------------------------] 100%
( 7/16) upgrading firedragon [----------------------------------------------------------------------------------------] 100%
To use profile-sync-daemon add firedragon to ~/.config/psd/psd.conf
If you prefer strict hardened settings execute 'cp /usr/lib/firedragon/firedragon.overrides.cfg ~/.firedragon/'
( 8/16) upgrading grub [----------------------------------------------------------------------------------------] 100%
New optional dependencies for grub
lzop: For grub-mkrescue LZO support [installed]
( 9/16) upgrading hostapd [----------------------------------------------------------------------------------------] 100%
(10/16) upgrading lib32-expat [----------------------------------------------------------------------------------------] 100%
(11/16) upgrading libuv [----------------------------------------------------------------------------------------] 100%
(12/16) upgrading linux-zen [----------------------------------------------------------------------------------------] 100%
(13/16) upgrading linux-zen-headers [----------------------------------------------------------------------------------------] 100%
(14/16) upgrading mysql-workbench [----------------------------------------------------------------------------------------] 100%
(15/16) upgrading python-setuptools [----------------------------------------------------------------------------------------] 100%
(16/16) upgrading reflector [----------------------------------------------------------------------------------------] 100%
( 1/17) Restoring Linux kernel modules...
++ uname -r
+ KVER=5.16.0-zen1-1-zen
+ test -e /usr/lib/modules/backup/5.16.0-zen1-1-zen
+ rsync -AHXal --ignore-existing /usr/lib/modules/backup/5.16.0-zen1-1-zen /usr/lib/modules/
+ rm -rf /usr/lib/modules/backup
( 2/17) Enabling os-prober...
( 3/17) Reloading system manager configuration...
( 4/17) Arming ConditionNeedsUpdate...
( 5/17) Updating the MIME type database...
( 6/17) Updating module dependencies...
( 7/17) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'default'
-> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen.img
==> Starting build: 5.16.1-zen1-1-zen
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [autodetect]
-> Running build hook: [modconf]
-> Running build hook: [block]
==> WARNING: Possibly missing firmware for module: xhci_pci
-> Running build hook: [keyboard]
-> Running build hook: [keymap]
-> Running build hook: [consolefont]
-> Running build hook: [plymouth]
-> Running build hook: [filesystems]
Decompress: 1/38 files. Current: ..._generic.ko.zst : 0 B... ==> Generating module dependencies
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-zen.img
==> Image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'fallback'
-> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: aic94xx
==> WARNING: Possibly missing firmware for module: wd719x
Decompress: 462/643 files. Current: ...hid-axff.ko.zst : 0 B... ==> Generating module dependencies
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-zen-fallback.img
( 8/17) GRUB update after transactions...
Found theme: /usr/share/grub/themes/garuda-dr460nized/theme.txt
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-zen-fallback.img
Detecting snapshots ...
Found snapshot: 2022-01-18 16:51:41 | @/.snapshots/43/snapshot | pre | pacman -Su |
Found snapshot: 2022-01-18 04:14:03 | @/.snapshots/42/snapshot | post | gnome-keyring google-chrome |
Found snapshot: 2022-01-18 04:13:48 | @/.snapshots/41/snapshot | pre | /usr/bin/pamac-daemon |
Found snapshot: 2022-01-17 10:15:22 | @/.snapshots/40/snapshot | post | zoom |
Found snapshot: 2022-01-17 10:15:04 | @/.snapshots/39/snapshot | pre | /usr/bin/pacman -U /home/rrj/zoom/zoom-5.9.1-1-x86_64.pkg.tar.zst |
Found snapshot: 2022-01-17 09:42:37 | @/.snapshots/38/snapshot | post | zoom |
Found snapshot: 2022-01-17 09:42:26 | @/.snapshots/37/snapshot | pre | /usr/bin/pamac-daemon |
Found snapshot: 2022-01-16 20:34:14 | @/.snapshots/36/snapshot | post | mathjax2 notepadqq qt5-webkit |
Found snapshot: 2022-01-16 20:34:06 | @/.snapshots/35/snapshot | pre | /usr/bin/pamac-daemon |
Found snapshot: 2022-01-16 20:31:00 | @/.snapshots/34/snapshot | post | antlr4-runtime atkmm cairomm gtkmm3 mysql-workbench pangomm proj rapidjs |
Found snapshot: 2022-01-16 20:30:53 | @/.snapshots/33/snapshot | pre | /usr/bin/pamac-daemon |
Found 11 snapshot(s)
Unmount /tmp/grub-btrfs.SeBSZ1OGw5 .. Success
done
( 9/17) Copy FireDragon Distribution Settings
(10/17) Foreign/AUR package notification
=> No foreign/AUR packages found.
(11/17) Updating icon theme caches...
(12/17) Orphaned package notification...
celt 0.11.3-4
go 2:1.17.6-2
zita-alsa-pcmi 0.4.0-1
zita-resampler 1.8.0-1
(13/17) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/pamac.conf.pacnew
Please check and merge
(14/17) Updating the info directory file...
(15/17) Updating the desktop file MIME type cache...
(16/17) Performing snapper post snapshots for the following configurations...
==> root: 44
(17/17) Syncing all file systems...
--> Updating mlocate index..
Parsing man pages and writing completions to /home/rrj/.local/share/fish/generated_completions/
6722 / 6722 : zramctl.8.gz
Checking for plugin updates
Nothing to install / update
System updated! 🐧
was having a similar issue
error: no servers configured for repository: community
(14/14) checking keys in keyring [------------------------------------] 100%
(14/14) checking package integrity [------------------------------------] 100%
Refreshing mirror list and saving it through garuda assistant fixed it
Yes, that should have been done after post #7, with no results I guess.
i got this output
reflector-simple: info: file /etc/reflector-simple.conf not found, using defaults.
(yad:12201): Gtk-WARNING **: 17:18:52.934: Theme parsing error: gtk-dark.css:5822:26: '-shadow' is not a valid
color name
(yad:12201): Gtk-WARNING **: 17:18:52.934: Theme parsing error: gtk-dark.css:5825:14: not a number
(yad:12201): Gtk-WARNING **: 17:18:52.934: Theme parsing error: gtk-dark.css:5826:13: not a number
(yad:12201): Gtk-WARNING **: 17:18:52.934: Theme parsing error: gtk-dark.css:5827:11: Expected a length
Gtk-Message: 17:18:53.019: Failed to load module "appmenu-gtk-module"
(yad:12250): Gtk-WARNING **: 17:19:41.425: Theme parsing error: gtk-dark.css:5822:26: '-shadow' is not a valid
color name
(yad:12250): Gtk-WARNING **: 17:19:41.426: Theme parsing error: gtk-dark.css:5825:14: not a number
(yad:12250): Gtk-WARNING **: 17:19:41.426: Theme parsing error: gtk-dark.css:5826:13: not a number
(yad:12250): Gtk-WARNING **: 17:19:41.426: Theme parsing error: gtk-dark.css:5827:11: Expected a length
Gtk-Message: 17:19:41.484: Failed to load module "appmenu-gtk-module"
/usr/bin/reflector-simple: line 1049: eos-latest-arch-mirrorlist: command not found
reflector-simple: warning: cannot fetch Arch mirror list.
(yad:12280): Gtk-WARNING **: 17:19:46.293: Theme parsing error: gtk-dark.css:5822:26: '-shadow' is not a valid
color name
(yad:12280): Gtk-WARNING **: 17:19:46.293: Theme parsing error: gtk-dark.css:5825:14: not a number
(yad:12280): Gtk-WARNING **: 17:19:46.293: Theme parsing error: gtk-dark.css:5826:13: not a number
(yad:12280): Gtk-WARNING **: 17:19:46.293: Theme parsing error: gtk-dark.css:5827:11: Expected a length
Gtk-Message: 17:19:46.342: Failed to load module "appmenu-gtk-module"
reflector-simple: info: New /etc/pacman.d/mirrorlist saved.
Press enter to exit~~~
The mirrorlist should have been refreshed, with rate-mirrors, which is the new standard package in the update script.
Now, first of all, reboot (you had a kernel update).
Then maybe try to clear your pacman cache with sudo pacman -Scc
and see if the issue persists.
thanks a lot for solving this issue ; may god bless you
I took the liberty to mark the Solution where I think it was more appropriate..
In my opinion clearing the chace was the key point, since there was probably something wrong there, maybe some leftover from a previous partial attempt.
I think the title should be changed as it doesn't describe the problem clearly
Good point, hard to do
I used a generic "error: no servers configured for repository", since the "extra" was only due to the fact that mariadb is in that repository, but the problem could occur in other cases.
