Hello.
I recently installed garuda Linux but I'm having problems connecting to the wifi network. The error is "no secrets were provided". I searched for solutions and tried everything I found, but the error still pops up. Can anyone help me?
I had the same problem with kubuntu the next command fixed my problem which simply changes the regulatory domain
sudo iw reg set US
just change the US to your country code
I tired adding:
[device]
wiFi.scan-rand-mac-address=no
in the network manager, I also tried restarting the wifi module from the garuda network assistant, but nothing changed
Especially for networking support providing inxi -Faz is quite important. Please provide this so helping can be more efficient
Since I'm running garuda on my pc, how do I have to provide the output of the command?
Hello.
inxi -Faz
Network: Device-1: Realtek RTL8111/8168/8411
PCI Express Gigabit Ethernet vendor:
ASUSTeK PRIME B450M-A driver:
r8169 v: kernel port: 3000 bus-ID:
02:00.0 chip-ID: 10ec:8168 class-
IF: enp2s0 state: down mac:<filter>
Device-2: Realtek RTL8192EU
802.11b/g/n WLAN Adapter type: USB
driver: rtl8xxxu bus-ID:1-14:3 chip-
ID: 0bda:818b class-ID: 0000 serial:.
<filter> IF:wlp0s20f0u14 state:down
mac:<filter>
Again
[quote=]
[/quote]
Edit your post.
You do it in
/etc/NetworkManager/conf.d/wifi_rand_mac.conf
Summary
Secrets were required, but not provided
If you attempt to connect to a network using nmcli device wifi connect SSID password password and received the following error:
Error: Connection activation failed: (7) Secrets were required, but not provided
The error can be resolved by deleting the connection profile and creating a new one:
$ nmcli connection delete SSID
$ nmcli device wifi connect SSID password password
You can also try disabling MAC address randomization:
[device] wifi.scan-rand-mac-address=no
I tried the command
and I got this output
Error: unknown connection 'Aria Wi-Fi' .
Error: cannot delete unknown connection(s): 'Aria Wi-Fi' .
Maybe you could try the following:
- Install crda
- Uncomment the correct Country Code in
/etc/conf.d/wireless-regdom - Reboot the system, because the setting is only read on boot
After rebooting I get a different error, it says "WiFi network could not be found"
I’m afraid this seems to be a very problematic wifi card. Just searched RTL8192EU in the forum and there was never a real solution.
The only reasonable thing to try seems to be this one (although it was not working in that case, that driver is meant for this card).
You don’t post your inxi, you do not answer
We are not psychics and would like to know if you have read and performed it.
In the template it says that without inxi -Faz we shoot the post etc…
Same in post #7
You were also asked three times in this topic to post it, how long do you think my patience is?
