Error: linux-firmware-nvidia: /usr/lib/firmware/nvidia/... exists in filesystem
… i have used these two commands and hope it’s the same as:
garuda-update, alias update, alias upd is a Garuda-specific sudo pacman -Syu.
This shouldn’t matter in the case of the firmware update, however.
# means that you have already entered your sudo password, so you can enter it without prefixing sudo.
Conclusion: It’s the same thing.
Hello, can I safely remove linux-firmware-nvidia if I have radeon laptop?
Regards.
Short answer: No.
Long answer: Unless you want a broken dependency tree, no.
This issue is now automatically resolved by garuda-update version 4.10.2. We do this without doing any funky -Rdd stuff, so this is a safer way and will allow for a safe reboot even if the update process was unable to complete for another reason. (Since the removal command of linux-firmware will succeed, while the normal system update could be cancelled for another reason)
In short:
Run garuda-update as always. No further intervention is needed.
A post was split to a new topic: Garuda-update errors with malformed URL Input to function
A post was split to a new topic: AMD graphics driver not loading after linux-firmware update
