Garuda-update errors with malformed URL Input to function
Then why am I still getting error after error running it? This is a fresh install to boot. Something seems to be broken still to me.
╭─the******@Ma**l in ~ as 🧙 took 0s
✦ [🔴] × garuda-update
[sudo] password for the******:
garuda.db failed to download
core is up to date
extra                                            7.8 MiB  9.07 MiB/s 00:01 [------------------------------------------] 100%
multilib is up to date
chaotic-aur.db failed to download
error: failed retrieving file 'garuda.db' from cdn-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'chaotic-aur.db' from cdn-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'chaotic-aur.db' from cdn-mirror.chaotic.cx : The requested URL returned error: 404
warning: too many errors from cdn-mirror.chaotic.cx, skipping for the remainder of this transaction
error: failed retrieving file 'garuda.db' from cdn-mirror.chaotic.cx : The requested URL returned error: 404
error: failed to synchronize all databases (failed to retrieve some files)
chaotic-aur                                    629.9 KiB   206 KiB/s 00:03 [##########################################] 100%
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
spawn pacman -Su -yy
core                                           116.5 KiB   108 KiB/s 00:01 [------------------------------------------] 100%
extra                                            7.8 MiB  6.20 MiB/s 00:01 [------------------------------------------] 100%
multilib                                       134.9 KiB   125 KiB/s 00:01 [------------------------------------------] 100%
╭─the******@Ma**l in ~ as 🧙 took 1m19s
I’ve moved your issue report to a new post because it’s unrelated to the post you are replying to.
Please post your garuda-inxi output and we’ll go from there.
Please also post the file content of /etc/pacman.d/chaotic-mirrorlist
  Kernel: 6.13.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=262906d3-bcf2-41ff-a695-fc79b454e3da rw rootflags=subvol=@
    quiet resume=UUID=eabf4b20-2f73-49bd-88dd-f0503a630a95 loglevel=3 ibt=off
  Desktop: KDE Plasma v: 6.4.0 tk: Qt v: N/A info: frameworks v: 6.15.0
  Type: Laptop System: Micro-Star product: GS75 Stealth 10SGS v: REV:1.0
  Mobo: Micro-Star model: MS-17G3 v: REV:1.0 serial: <superuser required>
    part-nu: 17G3.1 uuid: <superuser required> UEFI: American Megatrends
    v: E17G3IMS.110 date: 03/05/2021
  ID-1: BAT1 charge: 52.6 Wh (96.0%) condition: 54.8/80.3 Wh (68.3%)
    volts: 16.3 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
    status: not charging
  Info: model: Intel Core i9-10980HK bits: 64 type: MT MCP arch: Comet Lake
    model-id: 0xA5 (165) stepping: 2 microcode: 0xFC
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB
    desc: 8x256 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 800 min/max: 800/5300 scaling: driver: intel_pstate
    governor: performance cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800
    7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800
    16: 800 bogomips: 99199
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
    ports: active: none off: eDP-1 empty: none bus-ID: 00:02.0
    chip-ID: 8086:9bc4 class-ID: 0300
  Device-2: NVIDIA TU104M [GeForce RTX 2080 SUPER Mobile / Max-Q]
    vendor: Micro-Star MSI driver: nouveau v: kernel non-free: 550-570.xx+
    status: current (as of 2025-04; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: HDMI-A-1
    empty: DP-1,DP-2,eDP-2 bus-ID: 01:00.0 chip-ID: 10de:1e93 class-ID: 0300
  Device-3: Bison HD Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:6 chip-ID: 5986:2127
    alternate: fbdev,intel,nv,vesa dri: iris,nouveau gpu: i915,nouveau
    display-ID: 0
  Monitor-1: HDMI-A-1 model: LG (GoldStar) ULTRAGEAR serial: <filter>
    built: 2022 res: mode: 2560x1440 hz: 120 scale: 100% (1) dpi: 93 gamma: 1.2
    max: 3840x2160 min: 640x480
  Monitor-2: eDP-1 model: AU Optronics 0x348e built: 2019 res: 1920x1080
    dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46") diag: 438mm (17.3")
    ratio: 16:9 modes: 1920x1080
  API: EGL v: 1.5 hw: drv: intel iris platforms: device: 1 drv: iris
    device: 2 drv: swrast gbm: drv: kms_swrast surfaceless: drv: iris wayland:
    drv: iris x11: drv: iris inactive: device-0
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.1.4-arch1.1
    device-ID: 8086:9bc4 memory: 30.43 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.313 layers: 9 device: 0 type: integrated-gpu name: Intel
    UHD Graphics (CML GT2) driver: mesa intel v: 25.1.4-arch1.1
    device-ID: 8086:9bc4 surfaces: N/A device: 1 type: cpu name: llvmpipe
  Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
  Device-2: NVIDIA TU104 HD Audio vendor: Micro-Star MSI
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f8
  Device-3: SteelSeries ApS Arctis 7
    lanes: 1 mode: 1.1 bus-ID: 1-5:4 chip-ID: 1038:12ad class-ID: 0300
  API: ALSA v: k6.13.5-zen1-1-zen status: kernel-api with: aoss
  Device-2: Intel Killer E3100X 2.5 Gigabit Ethernet driver: igc v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0
    chip-ID: 8086:3101 class-ID: 0200
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 8087:0026
  Local Storage: total: 953.87 GiB used: 17.62 GiB (1.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
    SDBPNTY-1T00-1032 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 11111000 temp: 36.9 C scheme: GPT
  ID-1: / raw-size: 919.3 GiB size: 919.3 GiB (100.00%) used: 17.62 GiB (1.9%)
  ID-3: /home raw-size: 919.3 GiB size: 919.3 GiB (100.00%)
    used: 17.62 GiB (1.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-4: /var/log raw-size: 919.3 GiB size: 919.3 GiB (100.00%)
  ID-5: /var/tmp raw-size: 919.3 GiB size: 919.3 GiB (100.00%)
  ID-1: swap-1 type: zram size: 31.16 GiB used: 0 KiB (0.0%) priority: 100
  ID-2: swap-2 type: partition size: 34.27 GiB used: 0 KiB (0.0%)
  System Temperatures: cpu: 63.0 C pch: 47.0 C mobo: N/A
  Memory: total: 32 GiB available: 31.16 GiB used: 6.4 GiB (20.5%)
  Processes: 376 Power: uptime: 3h 58m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 2 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.45 GiB services: org_kde_powerdevil,
  Packages: pm: pacman pkgs: 1756 libs: 528 tools: octopi,paru Compilers:
    clang: 20.1.6 gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
  System install date:     2025-06-23
  Last full system update: 2025-06-24 ↻
  Is partially upgraded:   Yes
Thank you, they felt very related because I was experiencing the same problem as the user in that post but had been working on correcting it myself and had already did a split of the nvidia resources.
Let me know if I didn’t post the necessary information from the inxi. I am new to Garuda.
Please also post the file content of /etc/pacman.d/chaotic-mirrorlist as well as the output of the command pacman -Syy --debug.
Inxi looks good, thank you
The chaotic-mirrorlist was empty when I checked it initially. I’ve been attempting to correct it manually following some guidance found on the web and digging into dependable mirrors, but I’m not confident it’s correct. Here’s the current state of the file:
File: /etc/pacman.d/chaotic-mirrorlist
## Chaotic-AUR Mirrorlist
Server = https://cdn-mirror.chaotic.cx/chaotic-aur/$repo/$arch
Let me get that output into a pastebin for you. It seems like Netcat isn’t installed by default.
https://termbin.com/r4ty
Something seems a little off with your chaotic mirrorlist file.
Could you please do me a favor and send the file content of /etc/pacman.d/chaotic-mirrorlist? This is really important and this is the third time I’ve asked for it for a reason!
It was empty, I edited it trying to find a stable mirror so I could get apps installed. Here is the termbin for the command:
╭─thewitchybish@Mal in ~ took 0s
✦  ╰─λ cat /etc/pacman.d/chaotic-mirrorlist | nc termbin.com 9999
Termbin Chaotic-Mirrorlist
Not sure how else to get you the contents.
I don’t know how exactly this file manifested on your system but this is definitely not right.
You can restore the file to a correct state by running:
sudo wget https://aur.chaotic.cx/mirrorlist.txt -O /etc/pacman.d/chaotic-mirrorlist
garuda-update
This is a brand new install done yesterday morning here in Central Time Zone US. The whole intiital udpate was riddled with errors. Even the command you just gave me is tossing errors. I am guessing that something was broken upline. I am guessing whatever it was involved the nvidia problem too because I also had that issue. Since this is pretty much a clean install, maybe I should download the ISO all over again and do another clean install? Here is the output of what you just handed me.
╰─λ wget https://aur.chaotic.cx/mirrorlist.txt -O /etc/pacman.d/chaotic-mirrorlist
garuda-update
/etc/pacman.d/chaotic-mirrorlist: Permission denied
[sudo] password for thewitchybish:
core is up to date
extra                                            7.8 MiB  4.56 MiB/s 00:02 [------------------------------------------] 100%
chaotic-aur                                    629.9 KiB   186 KiB/s 00:03 [##########################################] 100%
core downloading...
core                                           116.5 KiB   203 KiB/s 00:01 [------------------------------------------] 100%
extra                                            7.8 MiB  7.74 MiB/s 00:01 [------------------------------------------] 100%
multilib                                       134.9 KiB   370 KiB/s 00:00 [------------------------------------------] 100%
You need to run the wget command as root. You don’t have sufficient permissions to write to a system file without root permissions.
Try again after you’ve run the wget command (the first one in the list) as root.
Good catch! Thank you! Sorry going screen blind have been at this desk for like 9 hours dealing with this failed install. This will be my fourth install across 4 different machines in the last 8 weeks and the only failed. It’s updating now will post output.
All good. I edited my original message to add the sudo, you didn’t miss it.
╰─λ sudo garuda-update
garuda                                          53.0 KiB  24.0 KiB/s 00:02 [------------------------------------------] 100%
core is up to date
extra is up to date
chaotic-aur is up to date
core downloading...
spawn pacman -Su
warning: snapper-tools: local (1.3.1-1.6) is newer than chaotic-aur (1.3.1-1)
resolving dependencies...
Package (5)                     Old Version    New Version    Net Change  Download Size
chaotic-aur/chaotic-mirrorlist  20240724-2     20240724-3       0.00 MiB
extra/discord                   1:0.0.98-1     1:0.0.99-1       0.00 MiB      76.23 MiB
garuda/firedragon               1:11.27.0_1-1  1:11.28.0_1-1    0.07 MiB     109.08 MiB
extra/xorg-server               21.1.18-1      21.1.18-2       -0.01 MiB       1.47 MiB
extra/xorg-server-common        21.1.18-1      21.1.18-2        0.00 MiB       0.03 MiB
Total Download Size:   186.80 MiB
Total Installed Size:  549.43 MiB
Net Upgrade Size:        0.06 MiB
:: Retrieving packages...
xorg-server-common-21.1.18-2-x86_64             27.5 KiB  76.5 KiB/s 00:00 [------------------------------------------] 100%
xorg-server-21.1.18-2-x86_64                  1507.7 KiB  2.62 MiB/s 00:01 [------------------------------------------] 100%
discord-1:0.0.99-1-x86_64                       76.2 MiB  38.4 MiB/s 00:02 [------------------------------------------] 100%
firedragon-1:11.28.0_1-1-x86_64                109.1 MiB  33.3 MiB/s 00:03 [------------------------------------------] 100%
Total (4/4)                                    186.8 MiB  53.5 MiB/s 00:03 [------------------------------------------] 100%
(5/5) checking keys in keyring                                              [------------------------------------------] 100%
(5/5) checking package integrity                                            [------------------------------------------] 100%
(5/5) loading package files                                                 [------------------------------------------] 100%
(5/5) checking for file conflicts                                           [------------------------------------------] 100%
(5/5) checking available disk space                                         [------------------------------------------] 100%
(1/3) Rejecting pacman transaction if running in snapshot...
(2/3) Performing snapper pre snapshots for the following configurations...
==> root: 14
(3/3) Remove FireDragon Distribution Settings
(1/5) upgrading chaotic-mirrorlist                                          [------------------------------------------] 100%
(2/5) upgrading discord                                                     [------------------------------------------] 100%
(3/5) upgrading firedragon                                                  [------------------------------------------] 100%
(4/5) upgrading xorg-server-common                                          [------------------------------------------] 100%
(5/5) upgrading xorg-server                                                 [------------------------------------------] 100%
( 1/10) Arming ConditionNeedsUpdate...
( 2/10) Checking for package with missing dependencies...
( 3/10) Foreign/AUR package notification
kitemmodels5 5.116.0-1
( 4/10) Orphaned package notification...
adobe-source-code-pro-fonts 2.042u+1.062i+1.026vf-2
fish-autopair 1.0.4-2
lib32-attr 2.5.2-1
lib32-gettext 0.25-1
lib32-libpcap 1.10.5-3
libsigc++-3.0 3.6.0-1
qt5-charts 5.15.17-1
qt5-quickcontrols2 5.15.17+kde+r5-1
quazip-qt5 1.5-1
vulkan-headers 1:1.4.313.0-1
( 5/10) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/hosts.pacnew
Please check and merge
( 6/10) Copy FireDragon Distribution Settings
( 7/10) Updating icon theme caches...
( 8/10) Updating the desktop file MIME type cache...
( 9/10) Performing snapper post snapshots for the following configurations...
==> root: 15
(10/10) Syncing all file systems...
System updated! 🐧
Update notices:
The GRUB bootloader at /EFI/Garuda has been updated/reinstalled using 'grub-install'. If this looks correct, no further action has to be taken.
That looks good! You’re good to go.
Thank you so much. Yeah I know it wasn’t in the command above but I know better lol. I am new to Garuda but not *nix. I was banging my head on this one. I have fallen in love with the Distro and hope to be running it for a long time!
Glad this has been solved, I still wonder some things though
What does “pretty much” entail? Are you certain you didn’t do anything that could be related before it was empty? I’m very curious what led up to this.
This failed when using that same media which succeeded so much elsewhere!? If so, you might want to confirm health of the drive you installed to. Passive corruption without a reasonable cause (like bad source files for the installer) is often a sign of impending hardware failure
You say the install was “riddled with errors”, but what and where were they exactly, or were you just referencing the solved mirrorlist problem?
What confuses me most is that the file is not just empty, but straight up wrong. The server URL just straight up isn’t correct.
