Hello, I've been using Linux for quite few years now in different flavors... but firs time using Arch hooked by "Garuda", what a great experience in Linux distros. All thanks to Arch.
Well my only regular issue is, after installing some Dev tools it works fine but after a reboot I get this error: ( error: failure reading sector 0x2419580 from 'hd0' ) then I disabled UEFI in boot menu still don't work. Are solution on regard this issue included on documentation? Restoring from "Snapshots" does bring it back, but in that way I think I am losing.
Post your terminal/konsole in- and output as text (nopictures) from:
inxi -Faz
Hey guys, I did exactly as you've instructed me to do so... Just wanted to say thank you, no problem with ma Garuda up to so far as I've been on it the whole night and I can tell that's pretty awesome indeed.
Yeah... Everything works fine, and I just installed Docker so simple with Garuda "Arch" native commands unlike any other distros.. Thanks
