Hey guys, so the below error is happening when I run the update command. I tried installing ffmpeg4.4 which installed but Garuda now warns of a partial update.
:: installing x264 (3:0.164.r3081.19856cc-1) breaks dependency 'libx264.so=163-64' required by ffmpeg4.4
This happened after running the below command in order to update some extra packages
curl https://iso.builds.garudalinux.org/iso/garuda/dr460nized/220217/garuda-dr460nized-linux-zen-220217.pkgs.txt | grep -Eo '^[^ ]+' | paru -Syu --needed -
Here is my garuda -inxi
System: Kernel: 5.16.9-2-cachyos x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=95b636ca-42a5-47b4-9b7a-038581af6cdf rw [email protected] quiet splash
resume=UUID=41193397-191d-45b5-8c2b-405cf71e73b2 loglevel=3
Desktop: KDE Plasma 5.24.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_wayland vt: 2 dm: SDDM
Machine: Type: Laptop System: ASUSTeK product: X510UA v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X510UA v: 1.0 serial: <filter> UEFI: American Megatrends v: X510UA.312
date: 04/29/2020
Battery: ID-1: BAT0 charge: 6.9 Wh (25.9%) condition: 26.6/42.1 Wh (63.3%) volts: 11.5 min: 11.5
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Discharging cycles: 437
CPU: Info: Dual Core model: Intel Core i7-7500U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check family: 6 model-id: 8E (142) stepping: 9 microcode: EC cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23220
Speed: 2960 MHz min/max: 400/3500 MHz Core speeds (MHz): 1: 2960 2: 2445 3: 2744 4: 2869
Graphics: Device-1: Intel HD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel bus-ID: 00:02.0
Device-2: IMC Networks VGA UVC WebCam type: USB driver: uvcvideo bus-ID: 1-6:4
chip-ID: 13d3:5a07 class-ID: 0e02 serial: <filter>
Display: wayland server: X.Org 1.21.1.4 compositor: kwin_wayland driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3") s-diag: 583mm (23")
Monitor-1: XWAYLAND0 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.3.6 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.16.9-2-cachyos running: yes
Network: Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel bus-ID: 02:00.0
chip-ID: 8086:24fd class-ID: 0280
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-8:5
chip-ID: 8087:0a2b class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block:
Drives: Local Storage: total: 1.57 TiB used: 331.64 GiB (20.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB size: 465.76 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 1B6Q
ID-2: /dev/sdb maj-min: 8:16 vendor: Micron model: 1100 MTFDDAV256TBN size: 238.47 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: A020
ID-3: /dev/sdd maj-min: 8:48 type: USB vendor: Seagate model: ST1000LM035-1RK172
size: 903.57 GiB block-size: physical: 4096 B logical: 512 B type: HDD rpm: 5400
serial: <filter> scheme: GPT
Partition: ID-1: / raw-size: 448.4 GiB size: 448.4 GiB (100.00%) used: 326.63 GiB (72.8%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 584 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 448.4 GiB size: 448.4 GiB (100.00%) used: 326.63 GiB (72.8%) fs: btrfs
ID-4: /var/log raw-size: 448.4 GiB size: 448.4 GiB (100.00%) used: 326.63 GiB (72.8%) fs: btrfs
ID-5: /var/tmp raw-size: 448.4 GiB size: 448.4 GiB (100.00%) used: 326.63 GiB (72.8%) fs: btrfs
ID-1: swap-1 type: partition size: 17.06 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
maj-min: 8:3
ID-2: swap-2 type: zram size: 15.52 GiB used: 1024 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 56.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3200
Info: Processes: 253 Uptime: 1h 38m wakeups: 1 Memory: 15.52 GiB used: 3.74 GiB (24.1%) Init: systemd
v: 250 tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1551 lib: 388
Shell: fish v: 3.3.1 running-in: konsole inxi: 3.3.07
Garuda (2.5.4-2):
System install date: 2022-01-27
Last full system update: 2022-02-17
Is partially upgraded: Yes
Failed units: systemd-sysctl.service
Any help would be greatly appreciated thank you
