Hello Garuda users.
i am trying to install pip install pyttsx3 in my garuda kde linux but it showing me an error an i have try to solve it but i can’t
╭─balwant@balwant in ~ took 482ms
╰─λ pip install pyttsx3
error: externally-managed-environment
× This environment is externally managed
╰─> To install Python packages system-wide, try 'pacman -S python-xyz', where xyz is the package you are trying to install.
If you wish to install a non-Arch-packaged Python package, create a virtual environment using 'python -m venv path/to/venv'. Then use path/to/venv/bin/python and path/to/venv/bin/pip.
If you wish to install a non-Arch packaged Python application, it may be easiest to use 'pipx install xyz', which will manage a virtual environment for you. Make sure you have python-pipx installed via pacman.
note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
hint: See PEP 668 for the detailed specification.
help
