Error "couldn't access control socket" when opening terminal
Hi everyone.
(sorry in advance if I do anything wrong, first post here)
I've been getting a weird error at the top of my terminal every time I open a new one. Until today it didn't affect anything I did so I didn't address it but today I wanted to "debtap" a package and the same error was thrown so I started searching for causes and fixes.
I saw this post
https://bbs.archlinux.org/viewtopic.php?pid=1640936#p1640936
that shows a similar problem and a solution, but running
sudo pwck
sudo grpck
and checking the /etc/passwd and /etc/group with
sudo vipw
sudo vigr
I didn't see any user or group that shouldn't be there.
So now i'm looking for help to fix this issue! And thank you in advance for the help!!
The full error message on the top of the terminal is:
couldn't access control socket: /run/user/1000/keyring SSH_AUTH_SOCK /run/user/1000/keyring/ssh/control: No such file or directory
discover_other_daemon: 1
The full error message when I tried to debtap:
discover_other_daemon: 1Incorrect parameters
mv: impossible to get information for '*.zst': No such file or directory
Running debtap as root doesn't show the error message, only the "Incorrect parameters
mv: impossible to get information for '*.zst': No such file or directory"
My garuda-inxi output:
Kernel: 5.19.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=75a46e81-f4b1-4d97-8f31-411c88687e45 rw rootflags=subvol=@
systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
Mobo: ASUSTeK model: TUF GAMING B550-PLUS (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2423
date: 08/10/2021
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3705 high: 3763 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3700 2: 3700
3: 3700 4: 3700 5: 3700 6: 3700 7: 3700 8: 3700 9: 3763 10: 3700 11: 3700
12: 3700 bogomips: 88808
Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate] vendor: ASUSTeK
driver: nvidia v: 515.76 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-08) arch: Ampere code: GAxxx process: TSMC n7
(7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 08:00.0 chip-ID: 10de:2489 class-ID: 0300
Device-2: Trust USB Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-2:3 chip-ID: 145f:0203 class-ID: 0102 serial: <filter>
Screen-1: 0 s-res: 2560x1080 s-dpi: 81 s-size: 803x343mm (31.61x13.50")
s-diag: 873mm (34.38")
Monitor-1: DP-2 res: 2560x1080 dpi: 81 size: 798x334mm (31.42x13.15")
diag: 865mm (34.06") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA
515.76 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel bus-ID: 3-2:3 v: kernel chip-ID: 145f:0203 pcie:
class-ID: 0102 gen: 4 speed: 16 GT/s serial: <filter> lanes: 16
bus-ID: 08:00.1 chip-ID: 10de:228b class-ID: 0403
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Trust USB Camera type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.19.10-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.21 running: no
Sound Server-4: PipeWire v: 0.3.58 running: yes
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
bus-ID: 1-5:2 chip-ID: 8087:0029 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 5.46 TiB used: 3.29 TiB (60.3%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Western Digital
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
rev: 111130WD temp: 34.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: KIOXIA model: EXCERIA SSD
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: ECFA12.9
temp: 35.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM004-2CV104
type: HDD rpm: 5425 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 931.26 GiB size: 931.26 GiB (100.00%) used: 540.35 GiB
(58.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 25.5 MiB
(10.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 931.26 GiB size: 931.26 GiB (100.00%) used: 540.35
GiB (58.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
ID-4: /var/log raw-size: 931.26 GiB size: 931.26 GiB (100.00%) used: 540.35
ID-5: /var/tmp raw-size: 931.26 GiB size: 931.26 GiB (100.00%) used: 540.35
ID-1: swap-1 type: zram size: 31.26 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: 37.5 C mobo: N/A gpu: nvidia temp: 41 C
Processes: 372 Uptime: 23m wakeups: 0 Memory: 31.26 GiB used: 3.84 GiB
(12.3%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1757 pm: pacman pkgs: 1753
libs: 470 tools: octopi,paru,yay pm: flatpak pkgs: 4 Shell: fish v: 3.5.1
running-in: konsole inxi: 3.3.21
Garuda (2.6.7-1):
System install date:     2021-11-25
Last full system update: 2022-09-25
For the error on top of your terminal, try resetting your fish config (and whatever other shells you use) in Garuda Assistant.
Source: GNOME/Keyring - ArchWiki under "6.5" section.
As for the debtap issue, I couldn't find information on that exact error, but maybe somebody experienced on using debtap will chime in on that.
Thank you, editing my config.fish solved the issue.
For the debtap portion I just found a issue on their github adressing this error
It's marked as solved but looks like it's back. I already commented on the issue and will see if I can help on that side.
