### Bug description
Tried to install Roblox using Lutris, but when I got to t…he part of installing Grapejuice error 256 appears. Ive so far tried to reinstall Lutris and Wine, tried to delete ~/.wine, tried to delete user_settings.json from ~/.config/brinkervii/grapejuice/ (as shown you should do if you get this error), and switched from wine-staging to normal wine, none of which have worked.
### How to Reproduce
Steps to reproduce the behavior:
1. Open Lutris
2. Search the Lutris Website for installers
3. Look up Roblox and click install on Grapejuice
### Expected behavior
Install Grapejuice on the PC, and after that install Roblox.
### Log output
```shell
INFO 2023-05-18 14:58:26,642 [startup.init_lutris:209]:Starting Lutris 0.5.13
INFO 2023-05-18 14:58:26,644 [startup.check_driver:65]:Using NVIDIA drivers 390.157 for x86_64
INFO 2023-05-18 14:58:26,644 [startup.check_driver:69]:GPU: GeForce 605
INFO 2023-05-18 14:58:26,644 [startup.check_driver:85]:GPU: 10DE:1048 107D:5AFD (nvidia drivers)
WARNING 2023-05-18 14:58:27,765 [startup.check_vulkan:144]:Vulkan is not available or your system isn't Vulkan capable
WARNING 2023-05-18 14:58:27,767 [system.get_vulkan_gpu_name:611]:vulkaninfo not available, unable to list GPUs
WARNING 2023-05-18 14:58:27,768 [system.get_vulkan_gpu_name:611]:vulkaninfo not available, unable to list GPUs
WARNING 2023-05-18 14:58:27,769 [system.get_vulkan_gpu_name:611]:vulkaninfo not available, unable to list GPUs
DEBUG 2023-05-18 14:58:27,988 [lutris.get_missing_game_ids:191]:Checking for missing games
DEBUG 2023-05-18 14:58:41,836 [application.show_window:339]:Showing window AddGamesWindow{}
DEBUG 2023-05-18 14:58:45,187 [http._request:88]:GET https://lutris.net/api/games?search=roblox&with-installers=True
DEBUG 2023-05-18 14:58:48,078 [api.get_game_installers:171]:Fetching installer https://lutris.net/api/installers/roblox
DEBUG 2023-05-18 14:58:48,078 [http._request:88]:GET https://lutris.net/api/installers/roblox
DEBUG 2023-05-18 14:58:48,430 [application.show_window:339]:Showing window InstallerWindowroblox
DEBUG 2023-05-18 14:58:48,430 [application.on_app_window_destroyed:357]:Removed window AddGamesWindow{}
DEBUG 2023-05-18 14:58:50,046 [displayconfig.get_current_resolution:643]:Retrieving current resolution
DEBUG 2023-05-18 14:58:56,383 [downloader.start:67]:⬇ https://gitlab.com/brinkervii/grapejuice/-/archive/v7.2.1/grapejuice-v7.2.1.zip
DEBUG 2023-05-18 14:58:56,390 [downloader.start:67]:⬇ https://raw.githubusercontent.com/nt74/robloxwine/main/robloxwine.py
DEBUG 2023-05-18 14:58:56,504 [downloader.on_download_completed:170]:Finished downloading https://raw.githubusercontent.com/nt74/robloxwine/main/robloxwine.py
DEBUG 2023-05-18 14:58:56,797 [downloader.on_download_completed:170]:Finished downloading https://gitlab.com/brinkervii/grapejuice/-/archive/v7.2.1/grapejuice-v7.2.1.zip
INFO 2023-05-18 14:58:56,884 [file_box.on_download_complete:239]:Download completed
DEBUG 2023-05-18 14:58:56,884 [files_box.on_file_available:108]:grapejuice is available
INFO 2023-05-18 14:58:56,891 [file_box.on_download_complete:239]:Download completed
DEBUG 2023-05-18 14:58:56,891 [files_box.on_file_available:108]:robloxwine is available
INFO 2023-05-18 14:58:56,891 [files_box.on_file_available:114]:All files available
INFO 2023-05-18 14:58:56,892 [installerwindow.on_files_available:635]:All files are available, continuing install
DEBUG 2023-05-18 14:58:56,893 [interpreter.create_game_folder:218]:Creating destination path /home/arch/Games/roblox
DEBUG 2023-05-18 14:58:56,894 [interpreter._iter_commands:361]:Installer command: {'extract': {'dst': '$CACHE', 'file': 'grapejuice', 'format': 'zip'}}
DEBUG 2023-05-18 14:58:56,895 [commands.extract:194]:Extracting grapejuice-v7.2.1.zip
DEBUG 2023-05-18 14:58:56,896 [commands.extract:198]:extracting file /home/arch/.cache/lutris/installer/roblox/grapejuice/grapejuice-v7.2.1.zip to /home/arch/.cache/lutris/installer/roblox
DEBUG 2023-05-18 14:58:56,920 [extract.extract_archive:127]:Extracting /home/arch/.cache/lutris/installer/roblox/grapejuice/grapejuice-v7.2.1.zip to /home/arch/.cache/lutris/installer/roblox
7-Zip [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21
p7zip Version 16.02 (locale=C.UTF-8,Utf16=on,HugeFiles=on,64 bits,4 CPUs x64)
Scanning the drive for archives:
1 file, 443275 bytes (433 KiB)
Extracting archive: /home/arch/.cache/lutris/installer/roblox/grapejuice/grapejuice-v7.2.1.zip
Path = /home/arch/.cache/lutris/installer/roblox/grapejuice/grapejuice-v7.2.1.zip
Type = zip
Physical Size = 443275
Comment = 80986fbecab5b867a71bd523062699d1cd86f7bb
Everything is Ok
Folders: 64
Files: 210
Compressed: 443275
DEBUG 2023-05-18 14:58:56,955 [system.remove_folder:321]:Removing folder /home/arch/.cache/lutris/installer/roblox/.extract-02685685
DEBUG 2023-05-18 14:58:56,955 [extract.extract_archive:179]:Finished extracting /home/arch/.cache/lutris/installer/roblox/grapejuice/grapejuice-v7.2.1.zip to /home/arch/.cache/lutris/installer/roblox
DEBUG 2023-05-18 14:58:56,956 [commands._killable_process:548]:Process <function extract_archive at 0x7fdaf93a6980> returned: ('/home/arch/.cache/lutris/installer/roblox/grapejuice/grapejuice-v7.2.1.zip', '/home/arch/.cache/lutris/installer/roblox')
DEBUG 2023-05-18 14:58:56,959 [commands.extract:200]:Extract done
DEBUG 2023-05-18 14:58:56,959 [interpreter._iter_commands:361]:Installer command: {'merge': {'dst': '$GAMEDIR', 'src': '$CACHE'}}
DEBUG 2023-05-18 14:58:56,962 [commands.merge:268]:Merging /home/arch/.cache/lutris/installer/roblox into /home/arch/Games/roblox
DEBUG 2023-05-18 14:58:56,966 [system.merge_folders:293]:Merging /home/arch/.cache/lutris/installer/roblox into /home/arch/Games/roblox
DEBUG 2023-05-18 14:58:56,967 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src
DEBUG 2023-05-18 14:58:56,967 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/.gitlab
DEBUG 2023-05-18 14:58:56,967 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/tests
DEBUG 2023-05-18 14:58:56,967 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/ci_scripts
DEBUG 2023-05-18 14:58:56,967 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/documentation
DEBUG 2023-05-18 14:58:56,967 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/robloxwine
DEBUG 2023-05-18 14:58:56,967 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/grapejuice
DEBUG 2023-05-18 14:58:56,969 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_dev_tools
DEBUG 2023-05-18 14:58:56,969 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common
DEBUG 2023-05-18 14:58:56,970 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_packaging
DEBUG 2023-05-18 14:58:56,970 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/gtk
DEBUG 2023-05-18 14:58:56,970 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/wine
DEBUG 2023-05-18 14:58:56,970 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/features
DEBUG 2023-05-18 14:58:56,970 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/assets
DEBUG 2023-05-18 14:58:56,970 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/util
DEBUG 2023-05-18 14:58:56,971 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/abstraction
DEBUG 2023-05-18 14:58:56,971 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/recipes
DEBUG 2023-05-18 14:58:56,971 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/hardware_info
DEBUG 2023-05-18 14:58:56,971 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/logs
DEBUG 2023-05-18 14:58:56,971 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/models
DEBUG 2023-05-18 14:58:56,972 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/gtk/components
DEBUG 2023-05-18 14:58:56,975 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/assets/images
DEBUG 2023-05-18 14:58:56,975 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/assets/mime_xml
DEBUG 2023-05-18 14:58:56,975 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/assets/po
DEBUG 2023-05-18 14:58:56,975 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/assets/glade
DEBUG 2023-05-18 14:58:56,975 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/assets/desktop
DEBUG 2023-05-18 14:58:56,976 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/assets/icons
DEBUG 2023-05-18 14:58:56,978 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/assets/icons/hicolor
DEBUG 2023-05-18 14:58:56,979 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/assets/icons/hicolor/32x32
DEBUG 2023-05-18 14:58:56,979 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/assets/icons/hicolor/scalable
DEBUG 2023-05-18 14:58:56,979 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/assets/icons/hicolor/128x128
DEBUG 2023-05-18 14:58:56,979 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/assets/icons/hicolor/48x48
DEBUG 2023-05-18 14:58:56,979 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/assets/icons/hicolor/16x16
DEBUG 2023-05-18 14:58:56,979 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/assets/icons/hicolor/256x256
DEBUG 2023-05-18 14:58:56,979 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/assets/icons/hicolor/24x24
DEBUG 2023-05-18 14:58:56,979 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/assets/icons/hicolor/64x64
DEBUG 2023-05-18 14:58:56,980 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/assets/icons/hicolor/32x32/apps
DEBUG 2023-05-18 14:58:56,980 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/assets/icons/hicolor/scalable/apps
DEBUG 2023-05-18 14:58:56,980 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/assets/icons/hicolor/128x128/apps
DEBUG 2023-05-18 14:58:56,981 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/assets/icons/hicolor/48x48/apps
DEBUG 2023-05-18 14:58:56,981 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/assets/icons/hicolor/16x16/apps
DEBUG 2023-05-18 14:58:56,982 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/assets/icons/hicolor/256x256/apps
DEBUG 2023-05-18 14:58:56,982 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/assets/icons/hicolor/24x24/apps
DEBUG 2023-05-18 14:58:56,983 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_common/assets/icons/hicolor/64x64/apps
DEBUG 2023-05-18 14:58:56,988 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_packaging/packaging_resources
DEBUG 2023-05-18 14:58:56,988 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_packaging/util
DEBUG 2023-05-18 14:58:56,988 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_packaging/builders
DEBUG 2023-05-18 14:58:56,989 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice_packaging/packaging_resources/bin
DEBUG 2023-05-18 14:58:56,990 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice/cli
DEBUG 2023-05-18 14:58:56,990 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice/components
DEBUG 2023-05-18 14:58:56,991 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice/windows
DEBUG 2023-05-18 14:58:56,991 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/src/grapejuice/helpers
DEBUG 2023-05-18 14:58:56,994 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/.gitlab/issue_templates
DEBUG 2023-05-18 14:58:56,994 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/ci_scripts/signing_keys
DEBUG 2023-05-18 14:58:56,995 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/documentation/tools
DEBUG 2023-05-18 14:58:56,995 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/documentation/src
DEBUG 2023-05-18 14:58:56,996 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/documentation/src/images
DEBUG 2023-05-18 14:58:56,996 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/documentation/src/components
DEBUG 2023-05-18 14:58:56,996 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/documentation/src/styles
DEBUG 2023-05-18 14:58:56,996 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/documentation/src/docs
DEBUG 2023-05-18 14:58:56,996 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/documentation/src/layout
DEBUG 2023-05-18 14:58:56,997 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/documentation/src/images/favicon
DEBUG 2023-05-18 14:58:56,998 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/documentation/src/styles/for-page
DEBUG 2023-05-18 14:58:56,998 [system.merge_folders:302]:creating dir: /home/arch/Games/roblox/documentation/src/styles/for-page/docs
DEBUG 2023-05-18 14:58:57,001 [commands._killable_process:548]:Process <function merge_folders at 0x7fdaf930c220> returned: None
DEBUG 2023-05-18 14:58:57,003 [interpreter._iter_commands:361]:Installer command: {'merge': {'dst': '$GAMEDIR', 'src': 'robloxwine'}}
DEBUG 2023-05-18 14:58:57,005 [commands.merge:268]:Merging /home/arch/.cache/lutris/installer/roblox/robloxwine/robloxwine.py into /home/arch/Games/roblox
DEBUG 2023-05-18 14:58:57,010 [commands._killable_process:548]:Process <function copy at 0x7fdafe830e00> returned: /home/arch/Games/roblox/robloxwine.py
DEBUG 2023-05-18 14:58:57,013 [interpreter._iter_commands:361]:Installer command: {'chmodx': '$GAMEDIR/install.py'}
DEBUG 2023-05-18 14:58:57,015 [interpreter._iter_commands:361]:Installer command: {'execute': {'env': {'key': 'python3 install.py'}, 'file': '$GAMEDIR/install.py', 'terminal': False}}
DEBUG 2023-05-18 14:58:57,017 [command.start:141]:LD_LIBRARY_PATH="/home/arch/.local/share/lutris/runtime/Ubuntu-18.04-i686:/home/arch/.local/share/lutris/runtime/steam/i386/lib/i386-linux-gnu:/home/arch/.local/share/lutris/runtime/steam/i386/lib:/home/arch/.local/share/lutris/runtime/steam/i386/usr/lib/i386-linux-gnu:/home/arch/.local/share/lutris/runtime/steam/i386/usr/lib:/home/arch/.local/share/lutris/runtime/Ubuntu-18.04-x86_64:/home/arch/.local/share/lutris/runtime/steam/amd64/lib/x86_64-linux-gnu:/home/arch/.local/share/lutris/runtime/steam/amd64/lib:/home/arch/.local/share/lutris/runtime/steam/amd64/usr/lib/x86_64-linux-gnu:/home/arch/.local/share/lutris/runtime/steam/amd64/usr/lib"
DEBUG 2023-05-18 14:58:57,018 [command.start:141]:PATH="/home/arch/.local/share/lutris/runtime/network-tools:/usr/local/bin:/usr/bin:/usr/local/sbin:/var/lib/flatpak/exports/bin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl"
DEBUG 2023-05-18 14:58:57,018 [command.start:141]:key="python3 install.py"
DEBUG 2023-05-18 14:58:57,018 [command.start:141]:PYTHONPATH="/usr/lib/lutris:/usr/bin:/usr/lib/python311.zip:/usr/lib/python3.11:/usr/lib/python3.11/lib-dynload:/home/arch/.local/lib/python3.11/site-packages:/usr/lib/python3.11/site-packages"
DEBUG 2023-05-18 14:58:57,018 [command.start:141]:LUTRIS_GAME_UUID="f9904607-9a9e-40e6-bb55-92af3155b472"
Started initial process 4699 from /home/arch/Games/roblox/install.py
Start monitoring process.
INFO:root:running install_locally
INFO:Install Grapejuice locally:Running task sequence
INFO:Install Grapejuice locally:Task status: ???????
INFO:Install Grapejuice locally:-- Running task -> Build package of supplemental files --
INFO:Build Linux Package:Running task sequence
INFO:Build Linux Package:Task status: ?????
INFO:Build Linux Package:-- Running task -> Compile mo files --
INFO:Build Linux Package:Using locale directory: build/supplemental_package/.local/share/locale
INFO:grapejuice_common.util.mo_util:Compiling mo files into build/supplemental_package/.local/share/locale
INFO:grapejuice_common.util.mo_util:Using LINGUAS /home/arch/Games/roblox/src/grapejuice_common/assets/po/LINGUAS
INFO:Build Linux Package:-- End of task --
INFO:Build Linux Package:Task status: Y????
INFO:Build Linux Package:-- Running task -> Copy MIME files --
INFO:Build Linux Package:Using mime packages directory: build/supplemental_package/.local/share/mime/packages
INFO:Build Linux Package:Task status: YY???
INFO:Build Linux Package:-- Running task -> Copy icons --
INFO:Build Linux Package:Using icons directory: build/supplemental_package/.local/share/icons
INFO:Build Linux Package:Task status: YYY??
INFO:Build Linux Package:-- Running task -> Copy desktop entries --
INFO:Build Linux Package:Using XDG applications directory: build/supplemental_package/.local/share/applications
INFO:Build Linux Package:Task status: YYYY?
INFO:Build Linux Package:-- Running task -> Copy binary entries --
INFO:Build Linux Package:Using bin directory: build/supplemental_package/.local/bin
INFO:Build Linux Package:Task status: YYYYY
INFO:Build Linux Package:Build Linux Package OK
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/locale/pt/LC_MESSAGES/grapejuice.mo -> .local/share/locale/pt/LC_MESSAGES/grapejuice.mo
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/locale/ro/LC_MESSAGES/grapejuice.mo -> .local/share/locale/ro/LC_MESSAGES/grapejuice.mo
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/locale/es/LC_MESSAGES/grapejuice.mo -> .local/share/locale/es/LC_MESSAGES/grapejuice.mo
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/locale/fr/LC_MESSAGES/grapejuice.mo -> .local/share/locale/fr/LC_MESSAGES/grapejuice.mo
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/locale/sr/LC_MESSAGES/grapejuice.mo -> .local/share/locale/sr/LC_MESSAGES/grapejuice.mo
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/mime/packages/x-grapejuice-roblox.xml -> .local/share/mime/packages/x-grapejuice-roblox.xml
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/icons/hicolor/32x32/apps/grapejuice.png -> .local/share/icons/hicolor/32x32/apps/grapejuice.png
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/icons/hicolor/32x32/apps/grapejuice-roblox-studio.png -> .local/share/icons/hicolor/32x32/apps/grapejuice-roblox-studio.png
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/icons/hicolor/32x32/apps/grapejuice-roblox-player.png -> .local/share/icons/hicolor/32x32/apps/grapejuice-roblox-player.png
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/icons/hicolor/scalable/apps/grapejuice.svg -> .local/share/icons/hicolor/scalable/apps/grapejuice.svg
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/icons/hicolor/128x128/apps/grapejuice.png -> .local/share/icons/hicolor/128x128/apps/grapejuice.png
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/icons/hicolor/128x128/apps/grapejuice-roblox-studio.png -> .local/share/icons/hicolor/128x128/apps/grapejuice-roblox-studio.png
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/icons/hicolor/128x128/apps/grapejuice-roblox-player.png -> .local/share/icons/hicolor/128x128/apps/grapejuice-roblox-player.png
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/icons/hicolor/48x48/apps/grapejuice.png -> .local/share/icons/hicolor/48x48/apps/grapejuice.png
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/icons/hicolor/48x48/apps/grapejuice-roblox-studio.png -> .local/share/icons/hicolor/48x48/apps/grapejuice-roblox-studio.png
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/icons/hicolor/48x48/apps/grapejuice-roblox-player.png -> .local/share/icons/hicolor/48x48/apps/grapejuice-roblox-player.png
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/icons/hicolor/16x16/apps/grapejuice.png -> .local/share/icons/hicolor/16x16/apps/grapejuice.png
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/icons/hicolor/16x16/apps/grapejuice-roblox-studio.png -> .local/share/icons/hicolor/16x16/apps/grapejuice-roblox-studio.png
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/icons/hicolor/16x16/apps/grapejuice-roblox-player.png -> .local/share/icons/hicolor/16x16/apps/grapejuice-roblox-player.png
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/icons/hicolor/256x256/apps/grapejuice.png -> .local/share/icons/hicolor/256x256/apps/grapejuice.png
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/icons/hicolor/256x256/apps/grapejuice-roblox-studio.png -> .local/share/icons/hicolor/256x256/apps/grapejuice-roblox-studio.png
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/icons/hicolor/256x256/apps/grapejuice-roblox-player.png -> .local/share/icons/hicolor/256x256/apps/grapejuice-roblox-player.png
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/icons/hicolor/24x24/apps/grapejuice.png -> .local/share/icons/hicolor/24x24/apps/grapejuice.png
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/icons/hicolor/24x24/apps/grapejuice-roblox-studio.png -> .local/share/icons/hicolor/24x24/apps/grapejuice-roblox-studio.png
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/icons/hicolor/24x24/apps/grapejuice-roblox-player.png -> .local/share/icons/hicolor/24x24/apps/grapejuice-roblox-player.png
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/icons/hicolor/64x64/apps/grapejuice.png -> .local/share/icons/hicolor/64x64/apps/grapejuice.png
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/icons/hicolor/64x64/apps/grapejuice-roblox-studio.png -> .local/share/icons/hicolor/64x64/apps/grapejuice-roblox-studio.png
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/icons/hicolor/64x64/apps/grapejuice-roblox-player.png -> .local/share/icons/hicolor/64x64/apps/grapejuice-roblox-player.png
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/applications/grapejuice.desktop -> .local/share/applications/grapejuice.desktop
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/applications/roblox-studio-auth.desktop -> .local/share/applications/roblox-studio-auth.desktop
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/applications/roblox-player.desktop -> .local/share/applications/roblox-player.desktop
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/applications/roblox-app.desktop -> .local/share/applications/roblox-app.desktop
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/share/applications/roblox-studio.desktop -> .local/share/applications/roblox-studio.desktop
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/bin/grapejuice-gui -> .local/bin/grapejuice-gui
INFO:grapejuice_packaging.builders.linux_package_builder:Adding to tar.gz: /home/arch/Games/roblox/build/supplemental_package/.local/bin/grapejuice -> .local/bin/grapejuice
INFO:Install Grapejuice locally:-- End of task --
INFO:Install Grapejuice locally:Task status: Y??????
INFO:Install Grapejuice locally:-- Running task -> Install supplemental packages --
INFO:Install Grapejuice locally:Installing supplemental package dist/supplemental_package/grapejuice-7.2.1.tar.gz
INFO:Install Grapejuice locally:Task status: YY?????
INFO:Install Grapejuice locally:-- Running task -> Install Grapejuice package --
Processing /home/arch/Games/roblox
Preparing metadata (setup.py): started
Preparing metadata (setup.py): finished with status 'done'
Requirement already satisfied: psutil in /usr/lib/python3.11/site-packages (from grapejuice==7.2.1) (5.9.5)
Requirement already satisfied: pip in /usr/lib/python3.11/site-packages (from grapejuice==7.2.1) (23.1.2)
Requirement already satisfied: PyGObject in /usr/lib/python3.11/site-packages (from grapejuice==7.2.1) (3.44.1)
Requirement already satisfied: packaging in /usr/lib/python3.11/site-packages (from grapejuice==7.2.1) (23.1)
Requirement already satisfied: wheel in /usr/lib/python3.11/site-packages (from grapejuice==7.2.1) (0.40.0)
Requirement already satisfied: setuptools in /usr/lib/python3.11/site-packages (from grapejuice==7.2.1) (67.7.0)
Requirement already satisfied: requests in /usr/lib/python3.11/site-packages (from grapejuice==7.2.1) (2.28.2)
Requirement already satisfied: Unidecode in /usr/lib/python3.11/site-packages (from grapejuice==7.2.1) (1.3.6)
Requirement already satisfied: Click in /usr/lib/python3.11/site-packages (from grapejuice==7.2.1) (8.1.3)
Requirement already satisfied: pydantic in /usr/lib/python3.11/site-packages (from grapejuice==7.2.1) (1.10.7)
Requirement already satisfied: typing-extensions>=4.2.0 in /usr/lib/python3.11/site-packages (from pydantic->grapejuice==7.2.1) (4.5.0)
Requirement already satisfied: idna<4,>=2.5 in /usr/lib/python3.11/site-packages (from requests->grapejuice==7.2.1) (3.4)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/lib/python3.11/site-packages (from requests->grapejuice==7.2.1) (1.26.15)
Requirement already satisfied: platformdirs in /usr/lib/python3.11/site-packages (from setuptools->grapejuice==7.2.1) (3.5.1)
Requirement already satisfied: jaraco.text in /usr/lib/python3.11/site-packages (from setuptools->grapejuice==7.2.1) (3.11.1)
Requirement already satisfied: more-itertools in /usr/lib/python3.11/site-packages (from setuptools->grapejuice==7.2.1) (9.1.0)
Requirement already satisfied: ordered-set in /usr/lib/python3.11/site-packages (from setuptools->grapejuice==7.2.1) (4.1.0)
Requirement already satisfied: tomli in /usr/lib/python3.11/site-packages (from setuptools->grapejuice==7.2.1) (2.0.1)
Requirement already satisfied: validate-pyproject in /usr/lib/python3.11/site-packages (from setuptools->grapejuice==7.2.1) (0.12.2.post1.dev0+g2940279.d20230508)
Requirement already satisfied: jaraco.functools in /usr/lib/python3.11/site-packages (from jaraco.text->setuptools->grapejuice==7.2.1) (3.6.0)
Requirement already satisfied: jaraco.context>=4.1 in /usr/lib/python3.11/site-packages (from jaraco.text->setuptools->grapejuice==7.2.1) (4.3.0)
Requirement already satisfied: autocommand in /usr/lib/python3.11/site-packages (from jaraco.text->setuptools->grapejuice==7.2.1) (2.2.2)
Requirement already satisfied: inflect in /usr/lib/python3.11/site-packages (from jaraco.text->setuptools->grapejuice==7.2.1) (6.0.4)
Requirement already satisfied: fastjsonschema<=3,>=2.16.2 in /usr/lib/python3.11/site-packages (from validate-pyproject->setuptools->grapejuice==7.2.1) (2.16.3)
Building wheels for collected packages: grapejuice
Building wheel for grapejuice (setup.py): started
Building wheel for grapejuice (setup.py): finished with status 'done'
Created wheel for grapejuice: filename=grapejuice-7.2.1-py3-none-any.whl size=350636 sha256=83f05fc3f8af7aa08d2597a2501c78dbce7966b1487434ee855449b58357a3c0
Stored in directory: /tmp/pip-ephem-wheel-cache-ttr__zu5/wheels/bf/95/91/c8569852f5283a0149fa41256090a8f82c9b0d9728773e6f6b
Successfully built grapejuice
Installing collected packages: grapejuice
Attempting uninstall: grapejuice
Found existing installation: grapejuice 7.2.1
Uninstalling grapejuice-7.2.1:
ERROR: Could not install packages due to an OSError: [Errno 13] Permission denied: '/usr/bin/grapejuice'
Check the permissions.
File "/home/arch/Games/roblox/setup.py", line 76, in <module>
main()
File "/home/arch/Games/roblox/setup.py", line 33, in main
setup(
File "/usr/lib/python3.11/site-packages/setuptools/__init__.py", line 107, in setup
return distutils.core.setup(**attrs)
File "/usr/lib/python3.11/site-packages/setuptools/_distutils/core.py", line 185, in setup
return run_commands(dist)
File "/usr/lib/python3.11/site-packages/setuptools/_distutils/core.py", line 201, in run_commands
dist.run_commands()
File "/usr/lib/python3.11/site-packages/setuptools/_distutils/dist.py", line 969, in run_commands
self.run_command(cmd)
File "/usr/lib/python3.11/site-packages/setuptools/dist.py", line 1243, in run_command
super().run_command(command)
File "/usr/lib/python3.11/site-packages/setuptools/_distutils/dist.py", line 988, in run_command
cmd_obj.run()
File "/home/arch/Games/roblox/src/grapejuice_packaging/local_install.py", line 126, in run
_do_install(self.user_options)
File "/home/arch/Games/roblox/src/grapejuice_packaging/local_install.py", line 112, in _do_install
install.run()
File "/home/arch/Games/roblox/src/grapejuice_packaging/util/task_sequence.py", line 56, in run
task_func(self._log)
File "/home/arch/Games/roblox/src/grapejuice_packaging/local_install.py", line 76, in install_package
subprocess.check_call([
File "/usr/lib/python3.11/subprocess.py", line 413, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['/usr/bin/python3', '-m', 'pip', 'install', '.', '--user', '--upgrade']' returned non-zero exit status 1.
File "/home/arch/Games/roblox/install.py", line 115, in <module>
perform_install()
File "/home/arch/Games/roblox/install.py", line 30, in perform_install
subprocess.check_call([sys.executable, "setup.py", "install_locally"])
subprocess.CalledProcessError: Command '['/usr/bin/python3', 'setup.py', 'install_locally']' returned non-zero exit status 1.
Monitored process exited.
Initial process has exited (return code: 256)
All processes have quit
Exit with return code 256
DEBUG 2023-05-18 14:58:59,515 [command.on_stop:195]:Process 4693 has terminated with code 256
DEBUG 2023-05-18 14:59:00,020 [commands._monitor_task:444]:Return code: 256
ERROR 2023-05-18 14:59:00,021 [errors.__init__:18]:Command exited with code 256
ERROR 2023-05-18 14:59:00,021 [exceptions.wrapper:63]:Command exited with code 256
File "/usr/lib/python3.11/site-packages/lutris/exceptions.py", line 61, in wrapper
return function(*args, **kwargs)
File "/usr/lib/python3.11/site-packages/lutris/installer/commands.py", line 446, in _monitor_task
raise ScriptingError(_("Command exited with code %s") % command.return_code)
lutris.installer.errors.ScriptingError: Command exited with code 256
### System Information
```shell
[System]
OS: Arch Linux
Arch: x86_64
Kernel: 6.3.2-arch1-1
Desktop: GNOME
Display Server: x11
[CPU]
Vendor: GenuineIntel
Model: Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz
Physical cores: 4
Logical cores: 4
[Memory]
RAM: 7.7 GB
Swap: 8.0 GB
[Graphics]
Vendor: NVIDIA Corporation
OpenGL Renderer: GeForce 605/PCIe/SSE2
OpenGL Version: 4.6.0 NVIDIA 390.157
OpenGL Core: 4.6.0 NVIDIA 390.157
OpenGL ES: OpenGL ES 3.2 NVIDIA 390.157
Vulkan: Not Supported
### Media (optional)
_No response_
### Checklist:
- [x] I'm not asking for support with a game or the wine runner.
- [X] I have followed the above mentioned guides and have all the graphics and wine dependencies installed.
- [X] I have checked for existing issues that describe my problem prior to opening this one.
- [X] I understand that improperly formatted bug reports may be closed without explanation.
