After a fresh instalation of garuda xfce i can not upgrade my system
plymouth-git has bad signature or something missing.
My solution was download this file from garuda servers | plymouth-git-22.02.122.r48.g9e72df3d-1-x86_64.pkg.tar.zst
source https://cf-builds.garudalinux.org/repos/chaotic-aur/x86_64/plymouth-git-22.02.122.r48.g9e72df3d-1-x86_64.pkg.tar.zst
and then place it in /var/cache/pacman/pkg
i think many users are stuck on that
after putting in plymouth-git-22.02.122.r48.g9e72df3d-1-x86_64.pkg.tar.zst on /var/cache/pacman/pkg
you can do pacman -Syy and pacman -Syu
Thank you Mr SGS
My solution was to place plymouth-git-22.02.122.r48.g9e72df3d-1-x86_64.pkg.tar.zst on /var/cache/pacman/pkg
-garuda-update- didnt work. Thanks again
SGS
#4
If your pacman's work, garuda-update must work too.
Sometimes you must try it two times.
If you got next time errors, explain what you did today.
Deal. Thank you Mr SGS. i dint know the double check trick.
system
closed
#6
