Unfortunately my printer does not install, I installed the correct drivers epson-inkjet-printer-escpr2 from the AUR but it does not show up.
Kernel: 5.19.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=4864a3c8-46d2-484f-a00e-dadee6f8125b
rw rootflags=subvol=@ quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
resume=UUID=f9f97696-36cd-43fe-997c-e5a8c084df36 loglevel=3
Desktop: KDE Plasma v: 5.25.4 tk: Qt v: 5.15.5 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Micro-Star model: B450-A PRO MAX (MS-7B86) v: 4.0
serial: <superuser required> UEFI: American Megatrends LLC. v: M.H0 date: 07/26/2022
Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3 gen: 4
built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000D
Topology: cpus: 1x cores: 6 tpc: 2 threads: 12 smt: enabled cache: L1: 384 KiB desc: d-6x32
KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4102 high: 4442 min/max: 1400/4464 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 3557 2: 4442 3: 3653 4: 4442 5: 3569
6: 4442 7: 3552 8: 4442 9: 4093 10: 4438 11: 4168 12: 4437 bogomips: 93426
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, IBRS_FW, STIBP: always-on, RSB
filling, PBRSB-eIBRS: Not affected
Device-1: AMD Cezanne driver: amdgpu v: kernel arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm)
built: 2018-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: DP-1 empty: DP-2,DVI-D-1,HDMI-A-1 bus-ID: 30:00.0 chip-ID: 1002:1638 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
Monitor-1: DP-1 mapped: DisplayPort-0 model: Acer VG270 serial: <filter> built: 2021
res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27")
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.47 5.19.5-zen1-1-zen) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 30:00.1
Device-2: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 30:00.6
Sound Server-1: ALSA v: k5.19.5-zen1-1-zen running: yes
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 22:00.0
Local Storage: total: 2.28 TiB used: 14.68 GiB (0.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 500GB size: 465.76 GiB
block-size: physical: 51
2 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 2B4QFXO7 temp: 27.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-75M2NA0 size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: DT01ACA100 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A750
ID-4: /dev/sdg maj-min: 8:96 type: USB model: FLASH Drive SM USB20 size: 7.54 GiB block-size:
physical: 512 B logical: 512 B type: SSD serial: <filter> rev: 1100 scheme: GPT
ID-1: / raw-size: 435.44 GiB size: 435.44 GiB (100.00%) used: 14.68 GiB (3.4%) fs: btrfs
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 608 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 435.44 GiB size: 435.44 GiB (100.00%) used: 14.68 GiB (3.4%) fs: btrfs
ID-4: /var/log raw-size: 435.44 GiB size: 435.44 GiB (100.00%) used: 14.68 GiB (3.4%)
ID-5: /var/tmp raw-size: 435.44 GiB size: 435.44 GiB (100.00%) used: 14.68 GiB (3.4%)
ID-1: swap-1 type: zram size: 27.3 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 30.03 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 36.8 C mobo: N/A gpu: amdgpu temp: 33.0 C
Processes: 328 Uptime: 1h 38m wakeups: 0 Memory: 27.3 GiB used: 3.46 GiB (12.7%) Init: systemd
v: 251 default: graphical tool: systemctl Compilers: gcc: 12.2.0 Packages: pacman: 1289 lib: 314
Client: shell wrapper v: 5.1.16-release inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2022-08-31
Last full system update: 2022-08-31
