Enabling VFIO assistance
Not sure what Iam missing, I had to do a clean install today and start over due to hardware failure. For the life of me I am missing someting in trying to get VFIO passthru working. Qemu tells me its not enabled. lscpi shows its not being enabled. Any tops on what I am missing would be great.
dmesg | grep -i vfio
[    0.000000] Command line: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=c31be1c8-8b6d-4962-95cf-1bed6c6e8ce7 rw rootflags=subvol=@ rd.driver.pre=vfio_pci quiet loglevel=3 vfio_pci.ids=10de:1c82,10de:0fb9 pcie_acs_override=downstream,multifunction video=efifb:off iommu=pt ibt=off
[    0.040786] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=c31be1c8-8b6d-4962-95cf-1bed6c6e8ce7 rw rootflags=subvol=@ rd.driver.pre=vfio_pci quiet loglevel=3 vfio_pci.ids=10de:1c82,10de:0fb9 pcie_acs_override=downstream,multifunction video=efifb:off iommu=pt ibt=off
[    0.912788] VFIO - User Level meta-driver version: 0.3
[    0.918528] vfio-pci 0000:04:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=io+mem:owns=none
[    0.918556] vfio-pci 0000:04:00.0: probe with driver vfio-pci failed with error -22
[    0.918559] vfio_pci: add [10de:1c82[ffffffff:ffffffff]] class 0x000000/00000000
[    0.918571] vfio-pci 0000:04:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=io+mem:owns=none
[    0.918582] vfio-pci 0000:04:00.0: probe with driver vfio-pci failed with error -22
[    0.918651] vfio-pci 0000:04:00.1: probe with driver vfio-pci failed with error -22
[    0.918653] vfio_pci: add [10de:0fb9[ffffffff:ffffffff]] class 0x000000/00000000
╭─root@I9 in /etc/dracut.conf.d as 🧙 took 0s
╰─λ garuda-inxi
Kernel: 6.12.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
Desktop: KDE Plasma v: 6.2.3 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Mobo: ASUSTeK model: TUF GAMING Z590-PLUS WIFI v: Rev 1.xx
serial: <filter> part-nu: SKU uuid: a9dd70fc-8670-2c1c-c0b7-f02f74550ad3
UEFI: American Megatrends v: 1801 date: 12/26/2022
Device-1: hid-0003:256F:C62E.0008-battery model: 3Dconnexion SpaceMouse
Wireless serial: N/A charge: N/A status: discharging
Info: model: 11th Gen Intel Core i9-11900KF socket: LGA1200 bits: 64
type: MT MCP arch: Rocket Lake gen: core 11 level: v4 note: check
built: 2021+ process: Intel 14nm family: 6 model-id: 0xA7 (167)
stepping: 1 microcode: 0x62
smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB
Speed (MHz): avg: 800 min/max: 800/5100:5300 base/boost: 3500/8500
scaling: driver: intel_pstate governor: powersave volts: 0.9 V
ext-clock: 100 MHz cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
bogomips: 112128
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: Dell
driver: nvidia v: 565.57.01 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: DP-2,DP-3,HDMI-A-1 empty: DP-1
bus-ID: 01:00.0 chip-ID: 10de:2504 class-ID: 0300
Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
status: current (as of 2024-09; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none off: HDMI-A-2
empty: DP-4,DVI-D-1 bus-ID: 04:00.0 chip-ID: 10de:1c82 class-ID: 0300
Device-3: Adomax Nuroum C40
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.4.2:12 chip-ID: 0627:a6bf
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.4.3:14
Display: unspecified server: X.Org v: 24.1.4 with: Xwayland v: 24.1.4
display-ID: :1 screens: 1
Screen-1: 0 s-res: 8320x1440 s-dpi: 96 s-size: 2201x381mm (86.65x15.00")
s-diag: 2234mm (87.94")
Monitor-1: DP-2 note: disabled pos: 2-1 model: HP 27es serial: <filter>
built: 2016 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
max: 1920x1080 min: 640x480
Monitor-2: DP-3 note: disabled pos: primary,1-2
model: Gigabyte AORUS FI32Q serial: <filter> built: 2021 res: 2560x1440
hz: 144 dpi: 93 gamma: 1.2 size: 698x392mm (27.48x15.43")
diag: 801mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 640x480
Monitor-3: HDMI-A-1 note: disabled pos: 2-3 model: HP 27es
serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
Monitor-4: HDMI-A-2 note: disabled pos: 2-4 model: AOC 28E850 built: 2017
res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2 size: 480x270mm (18.9x10.63")
diag: 707mm (27.8") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 1
drv: nvidia device: 4 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia
x11: drv: nvidia inactive: wayland,device-2,device-3
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 565.57.01
memory: 11.72 GiB
API: Vulkan v: 1.3.295 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 565.57.01
device-ID: 10de:2504 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1050 Ti driver: nvidia v: 565.57.01
device-ID: 10de:1c82 surfaces: N/A
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: Dell
Device-3: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
link-max: lanes: 16 bus-ID: 04:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-4: GN Netcom Jabra Engage 75 driver: jabra,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4.4.1:9
chip-ID: 0b0e:1112 class-ID: 0300 serial: <filter>
Device-5: Adomax Nuroum C40
Device-6: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
Device-7: Giga-Byte ESS SABRE HiFi USB Audio Device
lanes: 1 mode: 2.0 bus-ID: 1-9.2:11 chip-ID: 0414:a00c class-ID: 0300
Device-8: Giga-Byte USB Audio driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9.3:17 chip-ID: 0414:a008
API: ALSA v: k6.12.1-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.6 status: n/a (root, process) with:
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:15 chip-ID: 8087:0026
Local Storage: total: 9.48 TiB used: 17.81 GiB (0.2%)
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 233010WD temp: 27.9 C scheme: MBR
SMART: yes health: PASSED on: 2y 142d 0h cycles: 885
read-units: 12,810,299 [6.55 TB] written-units: 16,457,614 [8.42 TB]
ID-2: /dev/nvme1n1 maj-min: 259:9 model: PCIe SSD size: 931.51 GiB
tech: SSD serial: <filter> fw-rev: EHFM60.0 temp: 28.9 C scheme: MBR
SMART: yes health: PASSED on: 216d 3h cycles: 407
read-units: 3,520,938 [1.80 TB] written-units: 5,606,536 [2.87 TB]
ID-3: /dev/nvme2n1 maj-min: 259:3 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 34.9 C
SMART: yes health: PASSED on: 2y 3d 7h cycles: 1,830
read-units: 124,029,577 [63.5 TB] written-units: 82,855,671 [42.4 TB]
ID-4: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 1000GB
family: Marvell based SSDs size: 931.52 GiB block-size: physical: 512 B
logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 00RL temp: 35 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 172d 11h cycles: 773
ID-5: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD PLUS 1000GB
fw-rev: 00RL temp: 30 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 366d 8h cycles: 1000
ID-6: /dev/sdc maj-min: 8:32 vendor: SanDisk model: SDSSDH3 512G
size: 476.94 GiB block-size: physical: 512 B logical: 512 B sata: 3.3
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 1000 temp: 29 C
scheme: MBR
SMART: yes state: enabled health: PASSED on: 4y 120d 3h cycles: 1044
read: 1.4 MiB written: 2 MiB
ID-7: /dev/sdd maj-min: 8:48 vendor: ASMedia model: T ASM236X NVME
size: 119.24 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
drive serial: <filter> fw-rev: E8FK11.C temp: 72 Celsius C scheme: GPT
SMART: yes health: PASSED on: 342d 19h cycles: 603
read-units: 2,653,889 [1.35 TB] written-units: 2,707,619 [1.38 TB]
ID-8: /dev/sde maj-min: 8:64 model: External USB3.0 drive model: SATA SSD
size: 476.94 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
drive serial: <filter> fw-rev: 0301 drive-rev: 0964 temp: 33 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 322d 12h cycles: 56
written: 429 KiB
ID-9: /dev/sdf maj-min: 8:80 model: SATA SSD size: 223.57 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1
mode: 3.2 gen-1x1 tech: SSD serial: <filter> fw-rev: 0301 drive-rev: 0964
written: 429 KiB
ID-10: /dev/sdg maj-min: 8:96 model: External USB3.0 drive model: WD Blue
SA510 2.5 1000GB size: 476.94 GiB block-size: physical: 512 B
logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: N/A serial: <filter> drive serial: <filter> fw-rev: 0301
drive-rev: 0964 temp: 23 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 66 hrs cycles: 93
read: 954 KiB written: 2.2 MiB
ID-11: /dev/sdh maj-min: 8:112 model: External USB3.0
drive model: SDSSDX240GG25 family: Driven SSDs size: 931.51 GiB block-size:
mode: 3.2 gen-1x1 tech: N/A serial: <filter> drive serial: <filter>
fw-rev: 0301 drive-rev: 0964 temp: 128 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 7y 314d 9h cycles: 276
read: 12145 GiB written: 17777 GiB Pre-Fail: retired block: 100 threshold: 3
ID-12: /dev/sdi maj-min: 8:128 vendor: Samsung model: SSD 860 EVO 500G
size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 0301 scheme: GPT
ID-13: /dev/sdj maj-min: 8:144 vendor: Samsung model: SSD 860 EVO 500G
ID-14: /dev/sdk maj-min: 8:160 vendor: Samsung model: SSD 860 EVO 500G
ID-15: /dev/sdl maj-min: 8:176 vendor: Samsung model: SSD 860 EVO 500GB
ID-16: /dev/sdm maj-min: 8:192 vendor: Samsung model: SSD 850 PRO 256GB
family: based SSDs size: 238.47 GiB block-size: physical: 512 B
logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: SSD serial: <filter> fw-rev: 0103 drive-rev: EXM04B6Q temp: 24 C
scheme: MBR
SMART: yes state: enabled health: PASSED on: 7y 127d 16h cycles: 460
written: 10.77 TiB Pre-Fail: reallocated sector: 99 threshold: 10
ID-17: /dev/sdn maj-min: 8:208 vendor: Samsung model: SSD 850 PRO 256GB
sata: 3.1 speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0103
drive-rev: EXM02B6Q temp: 25 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 8y 297d 14h cycles: 79
written: 19.65 TiB
ID-1: / raw-size: 205.13 GiB size: 205.13 GiB (100.00%)
used: 17.79 GiB (8.7%) fs: btrfs block-size: 4096 B dev: /dev/nvme2n1p5
maj-min: 259:8
used: 26.2 MiB (27.3%) fs: vfat block-size: 512 B dev: /dev/nvme2n1p1
maj-min: 259:4
ID-3: /home raw-size: 205.13 GiB size: 205.13 GiB (100.00%)
maj-min: 259:8
ID-4: /var/log raw-size: 205.13 GiB size: 205.13 GiB (100.00%)
maj-min: 259:8
ID-5: /var/tmp raw-size: 205.13 GiB size: 205.13 GiB (100.00%)
maj-min: 259:8
ID-1: swap-1 type: zram size: 31.15 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 31.0 C mobo: N/A
Memory: total: 32 GiB available: 31.15 GiB used: 4.03 GiB (12.9%)
Processes: 435 Power: uptime: 4m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.41 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1663 libs: 445 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi (sudo) default: fish v: 3.7.1
System install date:     2024-11-23
Last full system update: 2024-11-23
Windows dual boot:       Yes
Solved, I just needed to post here for it magicly start working. Not sure what happen.
